#1 2023-06-12 11:47:22
lea2501
new daedalus install show warnings in apt for non-free-firmware
Hi! yesterday i have installed daedalus (netinstall) because my graphics card (amd 6700xt) does not work with chimera, and everything is running perfectly, but i see this warning messages when using apt, it's expected as daedalus get ready for release? or do i need to do something for those warnings to not show?
i already tried commenting those ''non-free-firmware' from the /etc/apt/sources.list and the error stop showing, but i need that repo cause of my graphics card.
thank you all in advance!
$ doas apt update && doas apt upgrade
Get:1 http://deb.devuan.org/merged daedalus InRelease [38.9 kB]
Get:2 http://deb.devuan.org/merged daedalus-security InRelease [17.4 kB]
Get:3 http://deb.devuan.org/merged daedalus-updates InRelease [21.9 kB]
Get:4 http://deb.devuan.org/merged daedalus-security/main Sources [9064 B]
Get:5 http://deb.devuan.org/merged daedalus-security/main amd64 Packages [17.4 kB]
Fetched 105 kB in 3s (33.7 kB/s)
All packages are up to date.
W: Skipping acquire of configured file 'non-free-firmware/source/Sources' as repository 'http://deb.devuan.org/merged daedalus-security InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/binary-amd64/Packages' as repository 'http://deb.devuan.org/merged daedalus-security InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-es' as repository 'http://deb.devuan.org/merged daedalus-security InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en' as repository 'http://deb.devuan.org/merged daedalus-security InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
Calculating upgrade... Done
EDIT: i forgot to write that i installed the "spanish" language locale during installation.
#2 2023-06-12 16:03:31
Re: new daedalus install show warnings in apt for non-free-firmware
Hello. Check your source list. It should look like this
deb http://deb.devuan.org/merged daedalus main non-free-firmware contrib non-free
#3 2023-06-12 18:14:09
As simple as it is, currently there is no "daedalus-security" yet as long as Daedalus still is in the testing stage.
#4 2023-07-26 21:24:52
alexkemp
Adding 'non-free-firmware' gives continuous errors in Chimaera:
W: Skipping acquire of configured file 'non-free-firmware/binary-amd64/Packages' as repository 'http://deb.devuan.org/merged chimaera InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en_GB' as repository 'http://deb.devuan.org/merged chimaera InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en' as repository 'http://deb.devuan.org/merged chimaera InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/binary-amd64/Packages' as repository 'http://deb.devuan.org/merged chimaera-security InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en_GB' as repository 'http://deb.devuan.org/merged chimaera-security InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en' as repository 'http://deb.devuan.org/merged chimaera-security InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/binary-amd64/Packages' as repository 'http://deb.devuan.org/merged chimaera-updates InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en' as repository 'http://deb.devuan.org/merged chimaera-updates InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en_GB' as repository 'http://deb.devuan.org/merged chimaera-updates InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/binary-amd64/Packages' as repository 'http://deb.devuan.org/merged chimaera-proposed-updates InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en_GB' as repository 'http://deb.devuan.org/merged chimaera-proposed-updates InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en' as repository 'http://deb.devuan.org/merged chimaera-proposed-updates InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/binary-amd64/Packages' as repository 'http://deb.devuan.org/merged chimaera-backports InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en_GB' as repository 'http://deb.devuan.org/merged chimaera-backports InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'non-free-firmware/i18n/Translation-en' as repository 'http://deb.devuan.org/merged chimaera-backports InRelease' doesn't have the component 'non-free-firmware' (component misspelt in sources.list?)
$ cat /etc/apt/sources.list
# 2023-02-01 added non-free-firmware; see https://dev1galaxy.org/viewtopic.php?pid=40751
# 2023-02-01 above removed as not active in Chimaera
deb http://deb.devuan.org/merged/ chimaera main contrib non-free
deb http://deb.devuan.org/merged/ chimaera-security main contrib non-free
deb http://deb.devuan.org/merged/ chimaera-updates main contrib non-free
# changed next line following https://dev1galaxy.org/viewtopic.php?pid=38033#p38033
# deb http://deb.devuan.org/devuan/ chimaera-proposed-updates contrib non-free main
deb http://deb.devuan.org/merged/ chimaera-proposed-updates main contrib non-free
deb http://deb.devuan.org/merged/ chimaera-backports main contrib non-free
Gah!
#5 2023-07-26 22:16:38
boughtonp
Which isn't a surprise, because there is no separate non-free-firmware repo in Chimaera.
This thread is about Daedalus, not Chimaera.
3.1415P265E589T932E846R64338
#6 2023-07-27 07:10:52
alexkemp
I'm actually reasonably capable of reading the thread title. However, if I can pass over that & like an idiot try to implement it in Chimaera (for the second time), so can others. Hence my post to try to help others not do that.
#7 2023-07-27 13:30:18
boughtonp
No part of your post conveyed itself as being advice to others, and a block of unrelated warnings and an unrelated sources.list just adds noise and the potential for confusion.
If you wanted to help such people, a simple sentence saying "p.s. non-free-firmware is new to Daedalus and shouldn't be added to Chimaera" could achieve that more directly and successfully.
(Although why anyone would arbitrarily follow a suggestion given to someone else, when not experiencing the same described issue, is beyond my comprehension.)
#8 2023-07-27 15:29:39
alexkemp
Lord, but these threads are full of noise. Please stop it.
