#1 2023-06-08 23:26:44
[SOLVED] git program for easy automated fixes
I wanted to know, if antyone knows of a way to either A: remove git patches quickly that don't work for a specific compilation, explained below:
In my case, there is this one uxp patch that I have that is broken and refuses to apply because of a few things that are no longer relevant.
I want to either A: bypass them, so I can apply the needed ones to the repo.
or B: remove the problematic ones in the patch that no longer are needed.
I want an automated way to do this, because otherwise I have to sort 1000+ patches on a stupidly regular basis lol.
In my case the patch file in question looks like this:
https://upload.disroot.org/r/wGTfuasx#k … 6/Gac3lxs=
I attached it to this upload area.
I need to remove all mentions that don't work now.
Does anyone know a way to remove the problematic changes, aka the ones that cannot or do not apply
Or be able to force only the patches that work to apply
Thanks in advance for whomever can help.
PS, I don't care if this program is on Devuan or Hyperbola. I have both so... yeah
wink
#2 2023-06-09 09:04:37
soren
Re: [SOLVED] git program for easy automated fixes
Do you mean remove mentions in that file with 12K lines of all the mentions that dont work?
You would need to get a list of the ones that dont work and comment them out in that file so they dont run.
#3 2023-06-09 13:04:52
boughtonp
3.1415P265E589T932E846R64338
#4 2023-06-10 15:03:13
Yes exactly
#5 2023-06-10 15:05:01
boughtonp wrote:
AH! I just found git apply --reject
thank you 1000%
