#1 2023-06-03 20:54:35
alexkemp
[SOLVED] Chromium Upgrade: 3 Packages have been Kept Back
A one-line script is run every day under my Chimaera 4 system:
sudo apt update && sudo apt install -f && sudo apt upgrade
No problems until today, when it reports that 3 of 4 available packages will be held back:
$ ~/.local/sbin/update
Hit:1 https://josm.openstreetmap.de/apt alldist InRelease
Hit:2 http://deb.devuan.org/merged chimaera InRelease
Get:3 http://deb.devuan.org/merged chimaera-security InRelease [26.2 kB]
Get:4 http://deb.devuan.org/merged chimaera-updates InRelease [26.1 kB]
Get:5 http://deb.devuan.org/merged chimaera-proposed-updates InRelease [26.6 kB]
Hit:6 http://deb.devuan.org/merged chimaera-backports InRelease
Fetched 78.9 kB in 3s (28.9 kB/s)
4 packages can be upgraded. Run 'apt list --upgradable' to see them.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Calculating upgrade... Done
  chromium chromium-common chromium-sandbox
  josm-latest
1 upgraded, 0 newly installed, 0 to remove and 3 not upgraded.
Need to get 15.7 MB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] n
Abort.
Cue frantic DDG searches.
A 12-year old question has good suggestions:
$ sudo apt-get --with-new-pkgs upgrade chromium chromium-common chromium-sandbox josm-latest
[sudo] password for alexk:
 chromium-l10n : Depends: chromium (< 113.0.5672.126-1~deb11u1.1~) but 114.0.5735.90-2~deb11u1 is to be installed
E: Broken packages
next:
$ sudo apt-get install chromium chromium-common chromium-sandbox josm-latest
Suggested packages:
  chromium-l10n chromium-shell chromium-driver
  chromium-l10n
4 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
Need to get 89.3 MB of archives.
After this operation, 80.6 MB disk space will be freed.
Abort.
Nope; not ready for it to be removed yet.
These are the problematic packages waiting to be upgraded:
$ apt list --upgradable
Listing... Done
chromium-common/stable-security 114.0.5735.90-2~deb11u1 amd64 [upgradable from: 113.0.5672.126-1~deb11u1]
chromium-sandbox/stable-security 114.0.5735.90-2~deb11u1 amd64 [upgradable from: 113.0.5672.126-1~deb11u1]
chromium/stable-security 114.0.5735.90-2~deb11u1 amd64 [upgradable from: 113.0.5672.126-1~deb11u1]
josm-latest/unknown 1.5.svn18746 all [upgradable from: 1.5.svn18744]
So, after that blizzard of code, what to do? Is it likely that chromium-l10n may finally get updated if I am patient, or is there any other solution?
#2 2023-06-04 07:46:35
soren
Re: [SOLVED] Chromium Upgrade: 3 Packages have been Kept Back
Have you tried the following command?
sudo apt --fix-broken install
I find it odd that stable wants to install chromium 114 as im on unstable and its still only at 113?
#3 2023-06-04 09:57:16
alexkemp
Essentially, I got the same as the previous attempts:
$ sudo apt --fix-broken install chromium-l10n chromium-shell chromium-driver chromium chromium-common chromium-sandbox josm-latest
chromium-l10n is already the newest version (113.0.5672.126-1~deb11u1).
The latest version (albeit Windows) is 116.0.5812.0 (Sunday, June 4, 2023 Revision: 1152969).
#4 2023-06-04 10:00:17
soren
Just use the command as so without packages, it should/might give options.
#5 2023-06-04 14:12:46
boughtonp
Unstable (Ceres/Sid) is on 114 too, it's Testing (Daedalus/Bookworm) that is on 113.
Stable (Chimaera/Bullseye) is on 112, except there's a 114 in the Stable security repo - but not for the locale package.
This can be seen at https://pkginfo.devuan.org/chromium and https://pkginfo.devuan.org/chromium-l10n
Since Chromium is not a Devuan-specific package, this is not a Devuan issue.
Specific versions can be seen in Debian's tracker, as can the fact that v114 entered stable-security yesterday:
https://tracker.debian.org/pkg/chromium
The page also mentions a bug in the chromium-l10n package, which is about this issue:
https://bugs.debian.org/cgi-bin/bugrepo … ug=1037087
In other words, it seems for whatever reason only 5 of the 6 binary packages have been built/deployed - once the Debian Maintainer for Chromium sees the issue they will presumably rectify that.
3.1415P265E589T932E846R64338
#6 2023-06-04 15:59:44
alexkemp
soren wrote:
Nope (but thanks for trying).
Clearly that is the issue; it is the precise error previously reported by me above. The bug report was made today (I was searching for such a report yesterday but of course, could find nothing
#7 2023-06-05 08:14:53
soren
Thats what I meant to say (testing, Daedaulus). Sorry for the confusion.
#8 2023-06-06 01:04:36
alexkemp
There is now a chromium-l10n update & this one is SOLVED.
/.local/sbin/update
Hit:1 http://deb.devuan.org/merged chimaera InRelease
Hit:2 http://deb.devuan.org/merged chimaera-security InRelease
Hit:3 http://deb.devuan.org/merged chimaera-updates InRelease
Hit:4 http://deb.devuan.org/merged chimaera-proposed-updates InRelease
Hit:5 http://deb.devuan.org/merged chimaera-backports InRelease
Hit:6 https://josm.openstreetmap.de/apt alldist InRelease
5 packages can be upgraded. Run 'apt list --upgradable' to see them.
0 upgraded, 0 newly installed, 0 to remove and 5 not upgraded.
  chromium chromium-common chromium-l10n chromium-sandbox josm-latest
5 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 95.5 MB of archives.
After this operation, 2,050 kB of additional disk space will be used.
Do you want to continue? [Y/n] Y
Get:1 http://deb.devuan.org/merged chimaera-security/main amd64 chromium-l10n all 114.0.5735.90-2~deb11u1 [6,184 kB]
Get:5 https://josm.openstreetmap.de/apt alldist/universe amd64 josm-latest all 1.5.svn18746 [15.7 MB]
Get:2 http://deb.devuan.org/merged chimaera-security/main amd64 chromium amd64 114.0.5735.90-2~deb11u1 [68.5 MB]
Get:3 http://deb.devuan.org/merged chimaera-security/main amd64 chromium-common amd64 114.0.5735.90-2~deb11u1 [4,970 kB]
Get:4 http://deb.devuan.org/merged chimaera-security/main amd64 chromium-sandbox amd64 114.0.5735.90-2~deb11u1 [134 kB]
Fetched 95.5 MB in 9s (10.1 MB/s)
Reading changelogs... Done
(Reading database ... 201190 files and directories currently installed.)
Preparing to unpack .../chromium-l10n_114.0.5735.90-2~deb11u1_all.deb ...
Unpacking chromium-l10n (114.0.5735.90-2~deb11u1) over (113.0.5672.126-1~deb11u1) ...
Preparing to unpack .../chromium_114.0.5735.90-2~deb11u1_amd64.deb ...
Unpacking chromium (114.0.5735.90-2~deb11u1) over (113.0.5672.126-1~deb11u1) ...
Preparing to unpack .../chromium-common_114.0.5735.90-2~deb11u1_amd64.deb ...
Unpacking chromium-common (114.0.5735.90-2~deb11u1) over (113.0.5672.126-1~deb11u1) ...
Preparing to unpack .../chromium-sandbox_114.0.5735.90-2~deb11u1_amd64.deb ...
Unpacking chromium-sandbox (114.0.5735.90-2~deb11u1) over (113.0.5672.126-1~deb11u1) ...
Preparing to unpack .../josm-latest_1.5.svn18746_all.deb ...
Unpacking josm-latest (1.5.svn18746) over (1.5.svn18744) ...
Setting up chromium-sandbox (114.0.5735.90-2~deb11u1) ...
Setting up chromium-common (114.0.5735.90-2~deb11u1) ...
Setting up chromium (114.0.5735.90-2~deb11u1) ...
Setting up josm-latest (1.5.svn18746) ...
Setting up chromium-l10n (114.0.5735.90-2~deb11u1) ...
Processing triggers for mailcap (3.69) ...
Processing triggers for desktop-file-utils (0.26-1) ...
Processing triggers for hicolor-icon-theme (0.17-2) ...
Processing triggers for man-db (2.9.4-2) ...
Processing triggers for shared-mime-info (2.0-1) ...
Processing triggers for menu (2.1.48) ...
