#1 2023-06-02 16:54:18
kapqa
libssl1.0-dev ?
Hello ,
i use at home also macintosh computer,
and wanted to extract a .pkg package under linux for further processing.
would like to install "xar" package
https://www.oueta.com/linux/extract-pkg … -on-linux/
however,
building fails, with error
configure: error: Cannot build without libcrypto (OpenSSL)
now it seems on Devuan Chimaera, the libssl1.0-dev is not available, but instead there is installed libssl-dev.
can i just install libssl1.0-dev from Debian Stretch or will this cause problems with libssl-dev?
thanks.
#2 2023-06-02 17:07:29
kapqa
Re: libssl1.0-dev ?
thanks, it seems it is not possible to install libssl1.0-dev without uninstalling libssl-dev first,
which is too risky to me,
so i resorted to help from internet,
it is possible to extract also with the package "pkg-config".
#3 2023-06-02 21:25:28
Re: libssl1.0-dev ?
Hi, I wonder if you can just unpack the .deb, same as a compressed archive.
there is 2 folders, data and control.
I often unpack them using the GUI and a file manager like Dolphin (kde5)
Currently I have libssl.1 libssl3 and libssl and openssl(3) At this point I do not have the -dev packag installed, so your mileage may vary.
I hope this helps, but I'm not sure about all you need for encryption...
