#1 2023-05-31 11:45:12
steelpillow
Webcam numpty
Running Beowulf + MATE.
Just been given a USB webcam (IMILAB CMSXJ22A). The idea is so that I can use it with Firefox for Teams etc. meetings. This is definitely not my comfort zone.
The user manual says it is plug-n-play compatible with Linux 2.6.24.
So I plugged it in and its power and wireless indicators lit up.
I cannot find any sign of it on my desktop, but then I don't know where to look.
Will it magically spring to life when someone sets up a meeting? Absolutely not a clue. How do I test that beforehand, anyway?
Not much better with bash, but I tried:
~$ lsusb -v
and it identifies the manufacturer as Microdia, but otherwise "couldn't open the device" whatever that means.
I have no idea what to do next. Total numpty. Can anybody guide me through the darkness?
— Cheers
#2 2023-05-31 12:23:03
soren
Re: Webcam numpty
Archlinux wiki has a bit of info that may help.
https://wiki.archlinux.org/title/webcam_setup
Note: The Linux kernel to userspace API used to control webcams is named Video4Linux2, v4l2 for short. All applications which support v4l2 will work with the kernel's drivers.
Install v4l-utils
sudo apt install v4l-utils
Then in a terminal post the results of the below command.
v4l2-ctl --list-devices
Another link that may help...
https://askubuntu.com/questions/348838/ … mmand-line
#3 2023-05-31 12:37:42
Kelsoo
Re: Webcam numpty
#4 2023-05-31 12:40:59
Re: Webcam numpty
or if you prefer to avoid microsoft, you can test with https://meet.jit.si/steelpillow
#5 2023-05-31 19:17:41
steelpillow
Re: Webcam numpty
Thanks! That looks like it worked. I got to see myself onscreen. It said the mic was working so I'll take it's word for that.
Can I take it from this that if I join say a Teams meeting, it will "just work" there too?
fwiw I used Synaptic to search for v4l-utils in the Beowulf repos and it's not there. So I'm really glad I don't have to fight my way into that rabbit-hole.
Then I found to do:
~$ usb-devices
which told me a bit more and gave the drivers as uvcvideo and snd-usb-audio, which is reassuring.
— Cheers
