#1 2023-05-21 20:28:54
Ron
[SOLVED] Can't figure out how to play DVDs
As the subject line states, I can't figure out how to play DVDs. I am trying it using SMPlayer (I don't want to install another app if I can help it). The first thing I did was try every option under SMPlayer Preferences >> Drives >> Select your DVD device. None of them worked. Then I read on another forum to download libdvd-pkg, but that didn't help either. Is it impossible to play commercial DVDs on a Linux machine? I'm pretty sure I've done it before (maybe).
#2 2023-05-22 01:08:10
alexkemp
Re: [SOLVED] Can't figure out how to play DVDs
I'm using updated Chimaera & VLC Media Player gives me the best results. The one thing that I need to settle to is very little in terms of the interactive DVD menu.
(there are a staggering number of VLC-Plugins; perhaps one of those will fix the bad dvd-menu):
$ apt search vlc
Sorting... Done
Full Text Search... Done
vlc/stable,stable-security,now 3.0.18-0+deb11u1 amd64 [installed]
  multimedia player and streamer
vlc-bin/stable,stable-security,now 3.0.18-0+deb11u1 amd64 [installed]
  binaries from VLC
vlc-data/stable,stable-security,now 3.0.18-0+deb11u1 all [installed,automatic]
  common data for VLC
#3 2023-05-22 02:18:07
SMPlayer is a front-end for MPlayer and mpv, so look for those plugins if required.
make sure you have permission to use the device by being in the same group ... 'games' group, for xample.
I only use cd s in my laptop.
I hope that helps
#4 2023-05-22 04:33:02
wdq
As far as I remember .....
Support for DVD menus has been removed in mpv. So disable the option to use DVD menus in Preferences -> Drives.
If it still doesn't work, select mplayer as multimedia engine in Preferences -> General.
Give that a GO ....
Just a simple man!
#5 2023-05-22 12:43:57
Most commercial DVDs are encrypted with "css" and decryption libraries are needed to play them.
I remember remarks on the vlc web site (dvdcss or decss). The DVD-player-software loads the library(s), if present. css is broken since years and some keys are public, even printed on T-shirts. Not sure about the current legal state, but I don't think this will ever make it into debian officially.
#6 2023-05-22 13:44:22
Kelsoo
libdvdread is required as well as libdvd iirc
#7 2023-05-22 13:48:26
alexkemp
Note Before:
DVD & Blu-Ray discs are problematic under Linux for many reasons, and special steps need to be taken before Linux apps can play them.
I thought that it might be useful to expand this post to serve as a reference, since at first I could not remember myself all the steps I took.
delgado wrote:
encrypted with "css" and decryption libraries are needed to play them … don't think this will ever make it into debian officially.
References:
Narrative:
CDs were first issued in 1982 and mostly held music files. The digital files on the media were NOT scrambled & quickly everyone learned to ‘rip’ the music from the disc and load it onto other electronic players. That became a nightmare for the Music Industry when the Internet got going in the 1990s.
DVDs were first released in 1996 and were designed to store larger files than Music required. The industry was determined NOT to make the same mistake as with CDs, and introduced both Regions (to try to restrict distribution regionally) and encryption (CSS) to restrict playing to officially-endorsed machines. The media became popular for both entertainment- (films, games) and software-distribution. CSS was brain-dead and easy to decrypt, but the combo of both endemic disc-players that contained zero hardware-decryption + industry-sponsored law (DMCA (Digital Millennium Copyright Act)), threatening fines and/or incarceration, was a nightmare for Linux users.
Blu-Ray was originated in 2002 & became a standard in 2008. It was designed to store very much larger digital files (required by larger domestic TV screens). In every way it is DVDs with knobs-on.
DVDs:
The modern advice from both Windows & Linux is “Install VLC”.
VLC states “VLC media player binaries are distributed with the libdvdcss library included” (that library is the one that decrypts the DVD-stream). That should mean that, once VLC is installed under Devuan, that other apps in the system should also be able to access the same library & decrypt the same streams. However, life is often not perfect, so here is what to do if glitches appear (it looks like the libdvdcss binary may be pre-installed under Windows but not Linux):–
With more ancient Debian/Ubuntu 15.04 it was sudo apt-get install libdvdread4 then sudo /usr/share/doc/libdvdread4/install-css.sh. My Chimaera still has /usr/share/doc/libdvdread4/README.css within it. However, the current advice is a little different:–
  1. sudo apt install libdvd-pkg
  2. sudo dpkg-reconfigure libdvd-pkg
The second step will download, build and install the latest libdvdcss source on your machine. At that point *all* libdvdcss-aware apps in your system — such as MPlayer, MPV + Handbrake — will be able to play DVDs.
$ apt search libdvd-pkg
Sorting... Done
libdvd-pkg/stable,now 1.4.2-1-1 all [installed]
  DVD-Video playing library - installer
$ apt search libdvdcss
Sorting... Done
libdvdcss-dev/now 1.4.2-1~local amd64 [installed,local]
  library for accessing encrypted DVDs - development files
libdvdcss2/now 1.4.2-1~local amd64 [installed,local]
libdvdcss2-dbgsym/now 1.4.2-1~local amd64 [installed,local]
  debug symbols for libdvdcss2
libdvdread4/now 6.0.1-1 amd64 [installed,local]
  library for reading DVDs
libdvdread8/stable,now 6.1.1-2 amd64 [installed,automatic]
Blu-Ray
Blue-Ray presents yet more problems. Once again, refer to How to Play DVDs and Blu-rays on Linux:
  1. sudo apt-get install vlc libaacs0 libbluray-bdj libbluray1
  2. mkdir -p ~/.config/aacs/
  3. cd ~/.config/aacs/ && wget http://vlc-bluray.whoknowsmy.name/files/KEYDB.cfg
$ apt search libbluray
Sorting... Done
libbluray-bdj/stable,now 1:1.2.1-4+deb11u2 all [installed]
  Blu-ray Disc Java support library (BD-J library)
libbluray-bin/stable 1:1.2.1-4+deb11u2 amd64
  Blu-ray disc playback support library (tools)
libbluray-dev/stable 1:1.2.1-4+deb11u2 amd64
  Blu-ray disc playback support library (development files)
libbluray-doc/stable 1:1.2.1-4+deb11u2 all
  Blu-ray disc playback support library (documentation)
libbluray2/stable,now 1:1.2.1-4+deb11u2 amd64 [installed]
  Blu-ray disc playback support library (shared library)
All the above works fine in my Chimaera system.
Updated:
May 23: Added a fuller narrative on installing libdvdcss.
Added info on the command (libdvd-pkg) to install libdvdcss in order to be able to play DVDs.
#8 2023-05-22 16:59:38
Andre4freedom
Excellent comment, alexkemp.
To play DVDs, vlc and libdvdcss2 did the trick for quite some time already, in most Linux distros.
Bluray is a completely different story! Thank you for your hints!
#9 2023-05-22 22:55:18
Ron
So I installed VLC but it still didn't work. I found this page, and ran the two commands below "Get libdvdcss." Now it works. Thanks everyone for pointing me in the right direction.
#10 2023-10-23 14:33:17
Thanks for the solution @alexkemp! Works on Daedalus too. For VLC at least.
#11 2025-11-27 19:57:30
lhp
I just installed vlc on a laptop freshly installed with Excalibur. libdvdcss2 is show as a suggested package, but I get this when I try to install:
lhp@ogygia:~$ sudo apt install libdvdcss2
Package libdvdcss2 is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
Error: Package 'libdvdcss2' has no installation candidate
lhp@ogygia:~$ sudo apt install libdvd-pkg
Error: Unable to locate package libdvd-pkg
Is this post obsolete, and if so, what is the status of DVDCSS on Excalibur? No longer needed?
#12 2025-11-27 21:39:31
Ron
It worked for me when I update to Excalibur. Not sure why it's not working for you. Did you try any DVDs yet?
#13 2025-11-27 21:44:39
You install libdvd-pkg. It provides libdvdcss2.
#14 2025-11-27 22:54:26
g4sra
@lhp,
have you appended 'contrib' in your sources.list ?
#15 2025-11-28 00:48:32
alexkemp
$ apt info libdvd-pkg
Package: libdvd-pkg
Version: 1.4.3-1-1.1
Priority: optional
Section: contrib/utils
Maintainer: Debian Multimedia Maintainers <debian-multimedia@lists.debian.org>
Installed-Size: 89.1 kB
Provides: libdvdcss-dev, libdvdcss2
Depends: debconf (>= 0.5) | debconf-2.0, build-essential, wget | devscripts, debhelper-compat (= 13)
Recommends: libcap2-bin
Download-Size: 16.9 kB
APT-Manual-Installed: yes
APT-Sources: http://deb.devuan.org/merged excalibur/contrib amd64 Packages
Description: DVD-Video playing library - installer
 This package provides libraries that are needed for playing video DVDs
 with a media player (such as VLC, SMplayer, Totem, etc.). It automates
 the process of downloading source files, compiling them, and installing
 the binary packages.
So, it *is* available & is inside contrib.
#16 2025-11-28 00:52:57
alexkemp
[added later]:
Here is my sources.list for Excaliber:
$ grep ^[^#] /etc/apt/sources.list /etc/apt/sources.list.d/*
/etc/apt/sources.list:deb http://deb.devuan.org/merged excalibur                 main non-free-firmware non-free contrib
/etc/apt/sources.list:deb http://deb.devuan.org/merged excalibur-updates         main non-free-firmware non-free contrib
/etc/apt/sources.list:deb http://deb.devuan.org/merged excalibur-security        main non-free-firmware non-free contrib
hth
#17 2025-11-28 01:20:53
Weird. My install of Daedalus from 2023 shows libdvdcss2 as a package, but in the current debian repo it doesn't show it for bookworm, it shows it as provided by the libdvd-pkg package.
It's aggravating, harkens back to the issues with mp3 back in the day. It's really only one small .so file, if you make one it's actually portable at least across daedalus installs, you can just drop the .so in and it works.
#18 2025-11-29 05:46:06
lhp
g4sra, I installed Excalibur using the installer on the live DVD, and this is my sources:
lhp@shangrila:~$ cat /etc/apt/sources.list /etc/apt/sources.list.d/*
# Package repositories
#deb http://deb.devuan.org/merged excalibur-proposed-updates main non-free-firmware
#deb http://deb.devuan.org/merged excalibur-backports main non-free-firmware
# Source repositories
#deb-src http://deb.devuan.org/merged excalibur main non-free-firmware
#deb-src http://deb.devuan.org/merged excalibur-updates main non-free-firmware
#deb-src http://deb.devuan.org/merged excalibur-security main non-free-firmware
#deb-src http://deb.devuan.org/merged excalibur-backports main non-free-firmware
cat: '/etc/apt/sources.list.d/*': No such file or directory
These are unaltered, the way they were after the installation. I am obviously missing contrib.
After adding contrib to the three uncommented lines, I can now install libdvd-pkg. It also helps a different problem that confused me - trying to install the suggested packages for gcc, several packages were not available, but they also seem to be in contrib.
Perhaps contrib should be included in the default installed sources.list?
#19 2025-11-29 14:14:38
alexkemp
This is sources.list within the Upgrade to Excalibur page (devuan.org):
"Modify sources.list to look like the one provided. Comment out all other lines."
Then, just to confuse you (Devuan is good at shooting itself & you in the foot), the page says:
Just add the non-free-firmware, non-free and contrib components to the appropriate line(s) in /etc/apt/sources.list as required:
It is the last line above that you need within sources.list, with duplicate lines added for excalibur, excalibur-updates, excalibur-security + excalibur-backports as required. I would suggest the 1st 3  initially, and all 4 if you are comfortable adding backports.
#20 2025-11-30 20:49:00
lhp
Well, I don't really mind being shot in the foot occasionally - I heal fast. ;-) And thank you. I think I ended up with something that is mostly right.
What is the term for these - distributions? (They do remind me a bit of Usenet news distributions, in being parallel to the category hierarchy.)
Back when I was using pkgsrc on NetBSD, pkgsrc was versioned IIRC, so you could use a stable pkgsrc config for most stuff, but still install HEAD from CVS and install your choice of packages at the most recent version, or even from pkgsrc-wip if you were daring. I guess no matter which system one uses, there will be some sort of problem. The nicest software installer I have used is probably the inst program fro SGI IRIX. The most obnoxious was probably SMIT. :-)
I wonder if it would be possible to have a "meta-" installer, that showed which versions were in which distribution. Is there any priority/ordering to them? Like suppose main has a well supported version of Firefox, but contrib has a more recent version, but less well tested, will apt install firefox install the former or the latter? Also, when showing dependencies and suggested packages, it is a bit confusing that packages are shown that do not belong to the sources set configured. Well, I guess I'll be reading up on APT one day.
#21 2025-11-30 23:06:46
The labels "excalibur", "excalibur-security", "excalibur-updates", etc are known as "codenames" and as such they identify "repositories" (not "distributions"). Each system (yours or mine) is set up with a package system that looks into one or more repositories for packages, which it (i.e. your system or my system) organises by package versions so as to get "the most recent version" of any package across those repositories.
A "distribution" is rather some particular collage of packages from some particular collective of repositories, that is formed and published so as to make a particular end user experience (and typically allowing for a smaller range of variations in experience).
HTH, Ralph.
