#1 2023-05-18 18:40:06
Panda1100
usb pendrive always mounted as read-only
Hello everyone, i'm using Daedalus with Linux 6.1.0-1-amd64. Two months ago i had problems with a pendrive: i couldn't write to it because the kernel mounted it as read-only (and until the day before the pendrive was always mounted as read-write); i thought it was an hardware failure of the pendrive (anyway i'm always careful to unmount drives correctly), so i forgot about it. Few days ago the problem returned with another pendrive.
I show you mkfs and kernel logs:
root@FM2:~# mkfs.ext2 -c /dev/sdb
mke2fs 1.47.0 (5-Feb-2023)
Found a dos partition table in /dev/sdb
Proceed anyway? (y,N) y
Creating filesystem with 987136 4k blocks and 247008 inodes
Filesystem UUID: 75560978-8c85-462b-9234-24723938cc17
Superblock backups stored on blocks:
        32768, 98304, 163840, 229376, 294912, 819200, 884736
Checking for bad blocks (read-only test): done
Allocating group tables: done
Writing inode tables: done
Writing superblocks and filesystem accounting information: mkfs.ext2: Input/output error while writing out and closing file system
[ 7876.166469] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7876.166485] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7876.166493] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7876.166502] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 5e 00 00 00 80 00
[ 7876.166507] I/O error, dev sdb, sector 744960 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7877.031966] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7877.031983] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7877.031991] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7877.032000] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 5e 80 00 00 80 00
[ 7877.032006] I/O error, dev sdb, sector 745088 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7878.345345] scsi_io_completion_action: 2 callbacks suppressed
[ 7878.345368] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7878.345384] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7878.345392] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7878.345401] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 5f 00 00 00 80 00
[ 7878.345406] blk_print_req_error: 2 callbacks suppressed
[ 7878.345411] I/O error, dev sdb, sector 745216 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7878.702343] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7878.702360] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7878.702368] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7878.702377] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 5f 80 00 00 80 00
[ 7878.702383] I/O error, dev sdb, sector 745344 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7878.790352] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7878.790368] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7878.790376] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7878.790384] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 5f 80 00 00 80 00
[ 7878.790390] I/O error, dev sdb, sector 745344 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7879.657102] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7879.657121] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7879.657129] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7879.657139] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 60 00 00 00 80 00
[ 7879.657145] I/O error, dev sdb, sector 745472 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7880.014454] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7880.014471] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7880.014479] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7880.014488] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 60 00 00 00 80 00
[ 7880.014494] I/O error, dev sdb, sector 745472 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7880.102333] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7880.102346] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7880.102354] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7880.102362] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 60 80 00 00 80 00
[ 7880.102367] I/O error, dev sdb, sector 745600 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7880.970239] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7880.970258] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7880.970267] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7880.970276] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 60 80 00 00 80 00
[ 7880.970282] I/O error, dev sdb, sector 745600 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7881.326344] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7881.326359] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7881.326367] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7881.326376] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 61 00 00 00 80 00
[ 7881.326381] I/O error, dev sdb, sector 745728 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7881.414325] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7881.414341] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7881.414349] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7881.414357] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 61 00 00 00 80 00
[ 7881.414363] I/O error, dev sdb, sector 745728 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7882.281113] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7882.281129] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7882.281138] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7882.281147] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 61 80 00 00 80 00
[ 7882.281153] I/O error, dev sdb, sector 745856 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7883.593084] scsi_io_completion_action: 2 callbacks suppressed
[ 7883.593108] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7883.593124] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7883.593132] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7883.593141] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 62 00 00 00 80 00
[ 7883.593146] blk_print_req_error: 2 callbacks suppressed
[ 7883.593150] I/O error, dev sdb, sector 745984 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7883.950316] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7883.950333] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7883.950341] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7883.950349] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 62 80 00 00 80 00
[ 7883.950354] I/O error, dev sdb, sector 746112 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7884.038328] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7884.038346] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7884.038355] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7884.038364] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 62 80 00 00 80 00
[ 7884.038370] I/O error, dev sdb, sector 746112 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7884.905117] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7884.905133] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7884.905140] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7884.905149] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 63 00 00 00 80 00
[ 7884.905155] I/O error, dev sdb, sector 746240 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7885.262315] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7885.262333] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7885.262341] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7885.262350] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 63 00 00 00 80 00
[ 7885.262355] I/O error, dev sdb, sector 746240 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7885.350325] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7885.350337] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7885.350345] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7885.350353] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 63 80 00 00 80 00
[ 7885.350358] I/O error, dev sdb, sector 746368 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7886.217311] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7886.217329] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7886.217337] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7886.217345] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 63 80 00 00 80 00
[ 7886.217351] I/O error, dev sdb, sector 746368 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7886.574308] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7886.574324] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7886.574332] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7886.574340] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 64 00 00 00 80 00
[ 7886.574345] I/O error, dev sdb, sector 746496 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7886.662314] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7886.662330] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7886.662338] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7886.662346] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 64 00 00 00 80 00
[ 7886.662352] I/O error, dev sdb, sector 746496 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7887.528824] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7887.528842] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7887.528849] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7887.528858] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 64 80 00 00 80 00
[ 7887.528864] I/O error, dev sdb, sector 746624 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7888.841670] scsi_io_completion_action: 2 callbacks suppressed
[ 7888.841690] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7888.841706] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7888.841714] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7888.841723] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 65 00 00 00 80 00
[ 7888.841728] blk_print_req_error: 2 callbacks suppressed
[ 7888.841733] I/O error, dev sdb, sector 746752 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7889.198304] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7889.198318] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7889.198326] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7889.198334] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 65 80 00 00 80 00
[ 7889.198339] I/O error, dev sdb, sector 746880 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7889.286299] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7889.286316] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7889.286324] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7889.286332] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 65 80 00 00 80 00
[ 7889.286338] I/O error, dev sdb, sector 746880 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7890.153052] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7890.153069] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7890.153077] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7890.153087] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 66 00 00 00 80 00
[ 7890.153092] I/O error, dev sdb, sector 747008 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7890.510168] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7890.510185] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7890.510194] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7890.510202] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 66 00 00 00 80 00
[ 7890.510207] I/O error, dev sdb, sector 747008 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7890.598173] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7890.598186] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7890.598193] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7890.598201] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 66 80 00 00 80 00
[ 7890.598206] I/O error, dev sdb, sector 747136 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7891.465063] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7891.465083] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7891.465091] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7891.465100] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 66 80 00 00 80 00
[ 7891.465106] I/O error, dev sdb, sector 747136 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7891.822304] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7891.822316] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7891.822324] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7891.822332] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 67 00 00 00 80 00
[ 7891.822337] I/O error, dev sdb, sector 747264 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7891.914183] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7891.914199] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7891.914207] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7891.914216] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 67 00 00 00 80 00
[ 7891.914221] I/O error, dev sdb, sector 747264 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7892.780184] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7892.780201] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7892.780209] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7892.780218] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 67 80 00 00 80 00
[ 7892.780224] I/O error, dev sdb, sector 747392 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7894.093415] scsi_io_completion_action: 2 callbacks suppressed
[ 7894.093434] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7894.093449] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7894.093457] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7894.093467] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 68 00 00 00 80 00
[ 7894.093471] blk_print_req_error: 2 callbacks suppressed
[ 7894.093476] I/O error, dev sdb, sector 747520 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7894.450175] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7894.450192] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7894.450200] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7894.450208] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 68 80 00 00 80 00
[ 7894.450214] I/O error, dev sdb, sector 747648 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7894.538166] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7894.538182] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7894.538190] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7894.538198] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 68 80 00 00 80 00
[ 7894.538204] I/O error, dev sdb, sector 747648 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7895.404537] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7895.404552] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7895.404560] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7895.404569] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 69 00 00 00 80 00
[ 7895.404574] I/O error, dev sdb, sector 747776 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7895.766155] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7895.766174] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7895.766182] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7895.766191] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 69 00 00 00 80 00
[ 7895.766197] I/O error, dev sdb, sector 747776 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7895.854164] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7895.854177] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7895.854185] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7895.854193] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 69 80 00 00 80 00
[ 7895.854198] I/O error, dev sdb, sector 747904 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7896.721164] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7896.721182] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7896.721190] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7896.721199] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 69 80 00 00 80 00
[ 7896.721205] I/O error, dev sdb, sector 747904 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7897.078153] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7897.078167] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7897.078174] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7897.078182] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6a 00 00 00 80 00
[ 7897.078188] I/O error, dev sdb, sector 748032 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7897.166163] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7897.166179] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7897.166187] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7897.166195] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6a 00 00 00 80 00
[ 7897.166200] I/O error, dev sdb, sector 748032 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7898.032287] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7898.032305] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7898.032312] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7898.032322] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6a 80 00 00 80 00
[ 7898.032327] I/O error, dev sdb, sector 748160 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7899.344886] scsi_io_completion_action: 2 callbacks suppressed
[ 7899.344906] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7899.344922] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7899.344929] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7899.344939] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6b 00 00 00 80 00
[ 7899.344944] blk_print_req_error: 2 callbacks suppressed
[ 7899.344949] I/O error, dev sdb, sector 748288 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7899.702281] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7899.702298] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7899.702306] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7899.702315] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6b 80 00 00 80 00
[ 7899.702320] I/O error, dev sdb, sector 748416 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7899.790147] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7899.790163] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7899.790171] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7899.790180] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6b 80 00 00 80 00
[ 7899.790185] I/O error, dev sdb, sector 748416 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7900.656645] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7900.656664] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7900.656671] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7900.656680] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6c 00 00 00 80 00
[ 7900.656686] I/O error, dev sdb, sector 748544 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7901.014259] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7901.014276] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7901.014284] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7901.014293] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6c 00 00 00 80 00
[ 7901.014299] I/O error, dev sdb, sector 748544 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7901.102129] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7901.102142] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7901.102150] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7901.102158] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6c 80 00 00 80 00
[ 7901.102163] I/O error, dev sdb, sector 748672 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7901.969402] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7901.969420] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7901.969429] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7901.969437] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6c 80 00 00 80 00
[ 7901.969443] I/O error, dev sdb, sector 748672 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7902.326148] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7902.326164] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7902.326172] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7902.326181] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6d 00 00 00 80 00
[ 7902.326186] I/O error, dev sdb, sector 748800 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7902.414129] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7902.414146] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7902.414155] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7902.414163] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6d 00 00 00 80 00
[ 7902.414168] I/O error, dev sdb, sector 748800 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7903.280633] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7903.280652] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7903.280661] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7903.280669] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6d 80 00 00 80 00
[ 7903.280675] I/O error, dev sdb, sector 748928 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7904.593371] scsi_io_completion_action: 2 callbacks suppressed
[ 7904.593391] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7904.593406] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7904.593414] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7904.593423] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6e 00 00 00 80 00
[ 7904.593428] blk_print_req_error: 2 callbacks suppressed
[ 7904.593433] I/O error, dev sdb, sector 749056 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7904.953996] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7904.954012] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7904.954020] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7904.954028] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6e 80 00 00 80 00
[ 7904.954034] I/O error, dev sdb, sector 749184 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7905.042014] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7905.042030] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7905.042038] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7905.042047] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6e 80 00 00 80 00
[ 7905.042052] I/O error, dev sdb, sector 749184 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7905.908385] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7905.908401] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7905.908409] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7905.908418] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6f 00 00 00 80 00
[ 7905.908423] I/O error, dev sdb, sector 749312 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7906.265994] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7906.266012] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7906.266020] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7906.266029] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6f 00 00 00 80 00
[ 7906.266035] I/O error, dev sdb, sector 749312 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7906.353988] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7906.354003] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7906.354010] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7906.354018] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6f 80 00 00 80 00
[ 7906.354024] I/O error, dev sdb, sector 749440 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7907.220631] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7907.220648] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7907.220656] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7907.220665] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6f 80 00 00 80 00
[ 7907.220671] I/O error, dev sdb, sector 749440 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7907.578112] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7907.578128] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7907.578136] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7907.578144] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 70 00 00 00 80 00
[ 7907.578150] I/O error, dev sdb, sector 749568 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7907.666120] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7907.666136] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7907.666144] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7907.666152] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 70 00 00 00 80 00
[ 7907.666158] I/O error, dev sdb, sector 749568 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7908.532370] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7908.532389] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7908.532397] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7908.532406] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 70 80 00 00 80 00
[ 7908.532411] I/O error, dev sdb, sector 749696 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7909.845470] scsi_io_completion_action: 2 callbacks suppressed
[ 7909.845489] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7909.845505] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7909.845513] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7909.845522] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 71 00 00 00 80 00
[ 7909.845527] blk_print_req_error: 2 callbacks suppressed
[ 7909.845532] I/O error, dev sdb, sector 749824 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7910.201995] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7910.202012] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7910.202020] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7910.202028] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 71 80 00 00 80 00
[ 7910.202033] I/O error, dev sdb, sector 749952 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7910.289989] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7910.290005] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7910.290013] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7910.290022] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 71 80 00 00 80 00
[ 7910.290027] I/O error, dev sdb, sector 749952 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7911.156622] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7911.156641] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7911.156649] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7911.156658] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 72 00 00 00 80 00
[ 7911.156663] I/O error, dev sdb, sector 750080 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7911.513992] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7911.514010] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7911.514018] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7911.514027] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 72 00 00 00 80 00
[ 7911.514033] I/O error, dev sdb, sector 750080 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7911.601967] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7911.601979] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7911.601987] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7911.601995] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 72 80 00 00 80 00
[ 7911.602000] I/O error, dev sdb, sector 750208 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7912.469848] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7912.469867] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7912.469876] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7912.469885] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 72 80 00 00 80 00
[ 7912.469890] I/O error, dev sdb, sector 750208 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7912.825966] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7912.825979] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7912.825987] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7912.825995] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 73 00 00 00 80 00
[ 7912.826000] I/O error, dev sdb, sector 750336 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7912.913970] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7912.913986] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7912.913994] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7912.914003] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 73 00 00 00 80 00
[ 7912.914008] I/O error, dev sdb, sector 750336 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7913.780470] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7913.780488] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7913.780496] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7913.780505] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 73 80 00 00 80 00
[ 7913.780511] I/O error, dev sdb, sector 750464 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7915.109459] scsi_io_completion_action: 2 callbacks suppressed
[ 7915.109479] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7915.109495] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7915.109503] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7915.109511] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 74 00 00 00 80 00
[ 7915.109516] blk_print_req_error: 2 callbacks suppressed
[ 7915.109522] I/O error, dev sdb, sector 750592 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7915.465981] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7915.465998] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7915.466006] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7915.466015] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 74 80 00 00 80 00
[ 7915.466020] I/O error, dev sdb, sector 750720 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7915.553962] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7915.553978] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7915.553987] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7915.553995] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 74 80 00 00 80 00
[ 7915.554000] I/O error, dev sdb, sector 750720 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7916.420464] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7916.420479] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7916.420487] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7916.420495] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 75 00 00 00 80 00
[ 7916.420501] I/O error, dev sdb, sector 750848 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7916.782091] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7916.782109] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7916.782117] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7916.782126] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 75 00 00 00 80 00
[ 7916.782132] I/O error, dev sdb, sector 750848 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7916.870083] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7916.870095] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7916.870102] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7916.870110] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 75 80 00 00 80 00
[ 7916.870115] I/O error, dev sdb, sector 750976 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7917.738098] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7917.738116] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7917.738124] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7917.738133] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 75 80 00 00 80 00
[ 7917.738139] I/O error, dev sdb, sector 750976 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7918.093967] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7918.093980] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7918.093988] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7918.093996] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 76 00 00 00 80 00
[ 7918.094001] I/O error, dev sdb, sector 751104 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7918.181953] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7918.181969] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7918.181977] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7918.181985] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 76 00 00 00 80 00
[ 7918.181991] I/O error, dev sdb, sector 751104 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7919.048460] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7919.048477] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7919.048485] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7919.048494] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 76 80 00 00 80 00
[ 7919.048500] I/O error, dev sdb, sector 751232 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7920.361205] scsi_io_completion_action: 2 callbacks suppressed
[ 7920.361225] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7920.361240] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7920.361248] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7920.361257] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 77 00 00 00 80 00
[ 7920.361262] blk_print_req_error: 2 callbacks suppressed
[ 7920.361267] I/O error, dev sdb, sector 751360 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7920.717829] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7920.717844] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7920.717852] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7920.717861] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 77 80 00 00 80 00
[ 7920.717866] I/O error, dev sdb, sector 751488 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7920.805830] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7920.805846] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7920.805855] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7920.805863] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 77 80 00 00 80 00
[ 7920.805869] I/O error, dev sdb, sector 751488 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7921.672603] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7921.672622] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7921.672629] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7921.672638] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 78 00 00 00 80 00
[ 7921.672644] I/O error, dev sdb, sector 751616 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7922.029814] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7922.029831] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7922.029839] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7922.029848] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 78 00 00 00 80 00
[ 7922.029853] I/O error, dev sdb, sector 751616 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7922.117818] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7922.117830] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7922.117838] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7922.117846] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 78 80 00 00 80 00
[ 7922.117851] I/O error, dev sdb, sector 751744 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7922.986315] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7922.986333] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7922.986341] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7922.986350] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 78 80 00 00 80 00
[ 7922.986356] I/O error, dev sdb, sector 751744 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7923.345812] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7923.345827] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7923.345835] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7923.345844] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 79 00 00 00 80 00
[ 7923.345849] I/O error, dev sdb, sector 751872 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7923.433816] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7923.433832] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7923.433840] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7923.433848] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 79 00 00 00 80 00
[ 7923.433854] I/O error, dev sdb, sector 751872 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7924.301573] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7924.301591] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7924.301599] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7924.301608] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 79 80 00 00 80 00
[ 7924.301614] I/O error, dev sdb, sector 752000 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7925.618668] scsi_io_completion_action: 2 callbacks suppressed
[ 7925.618689] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7925.618705] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7925.618713] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7925.618722] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7a 00 00 00 80 00
[ 7925.618727] blk_print_req_error: 2 callbacks suppressed
[ 7925.618732] I/O error, dev sdb, sector 752128 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7925.977799] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7925.977816] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7925.977824] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7925.977833] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7a 80 00 00 80 00
[ 7925.977838] I/O error, dev sdb, sector 752256 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7926.069820] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7926.069837] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7926.069844] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7926.069853] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7a 80 00 00 80 00
[ 7926.069859] I/O error, dev sdb, sector 752256 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7926.936814] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7926.936830] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7926.936838] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7926.936846] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7b 00 00 00 80 00
[ 7926.936852] I/O error, dev sdb, sector 752384 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7927.297817] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7927.297836] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7927.297844] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7927.297854] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7b 00 00 00 80 00
[ 7927.297859] I/O error, dev sdb, sector 752384 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7927.385796] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7927.385810] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7927.385818] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7927.385827] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7b 80 00 00 80 00
[ 7927.385832] I/O error, dev sdb, sector 752512 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7928.252690] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7928.252709] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7928.252717] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7928.252726] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7b 80 00 00 80 00
[ 7928.252731] I/O error, dev sdb, sector 752512 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7928.609792] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7928.609806] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7928.609814] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7928.609822] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7c 00 00 00 80 00
[ 7928.609828] I/O error, dev sdb, sector 752640 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7928.697798] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7928.697814] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7928.697822] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7928.697831] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7c 00 00 00 80 00
[ 7928.697836] I/O error, dev sdb, sector 752640 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7929.564432] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7929.564450] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7929.564458] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7929.564496] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7c 80 00 00 80 00
[ 7929.564503] I/O error, dev sdb, sector 752768 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7930.877170] scsi_io_completion_action: 2 callbacks suppressed
[ 7930.877190] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7930.877205] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7930.877214] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7930.877223] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7d 00 00 00 80 00
[ 7930.877228] blk_print_req_error: 2 callbacks suppressed
[ 7930.877232] I/O error, dev sdb, sector 752896 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7931.233804] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7931.233820] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7931.233828] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7931.233837] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7d 80 00 00 80 00
[ 7931.233842] I/O error, dev sdb, sector 753024 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7931.321783] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7931.321799] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7931.321808] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7931.321816] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7d 80 00 00 80 00
[ 7931.321822] I/O error, dev sdb, sector 753024 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7932.188910] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7932.188928] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7932.188937] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7932.188946] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7e 00 00 00 80 00
[ 7932.188951] I/O error, dev sdb, sector 753152 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7932.549780] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7932.549796] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7932.549804] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7932.549813] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7e 00 00 00 80 00
[ 7932.549819] I/O error, dev sdb, sector 753152 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7932.637901] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7932.637913] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7932.637921] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7932.637929] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7e 80 00 00 80 00
[ 7932.637934] I/O error, dev sdb, sector 753280 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7933.505029] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7933.505047] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7933.505055] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7933.505064] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7e 80 00 00 80 00
[ 7933.505070] I/O error, dev sdb, sector 753280 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7933.861779] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7933.861791] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7933.861799] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7933.861807] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7f 00 00 00 80 00
[ 7933.861812] I/O error, dev sdb, sector 753408 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7933.949782] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7933.949799] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7933.949807] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7933.949815] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7f 00 00 00 80 00
[ 7933.949821] I/O error, dev sdb, sector 753408 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7934.816169] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7934.816186] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7934.816194] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7934.816203] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7f 80 00 00 80 00
[ 7934.816208] I/O error, dev sdb, sector 753536 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7936.128403] scsi_io_completion_action: 2 callbacks suppressed
[ 7936.128422] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7936.128438] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7936.128445] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7936.128454] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 80 00 00 00 80 00
[ 7936.128460] blk_print_req_error: 2 callbacks suppressed
[ 7936.128465] I/O error, dev sdb, sector 753664 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7936.485646] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7936.485664] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7936.485671] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7936.485680] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 80 80 00 00 80 00
[ 7936.485685] I/O error, dev sdb, sector 753792 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7936.573641] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7936.573658] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7936.573665] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7936.573675] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 80 80 00 00 80 00
[ 7936.573680] I/O error, dev sdb, sector 753792 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7937.439779] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7937.439794] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7937.439802] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7937.439810] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 81 00 00 00 80 00
[ 7937.439815] I/O error, dev sdb, sector 753920 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7937.797783] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7937.797800] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7937.797809] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7937.797818] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 81 00 00 00 80 00
[ 7937.797824] I/O error, dev sdb, sector 753920 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7937.885764] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7937.885776] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7937.885784] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7937.885792] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 81 80 00 00 80 00
[ 7937.885797] I/O error, dev sdb, sector 754048 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7938.752888] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7938.752907] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7938.752915] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7938.752925] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 81 80 00 00 80 00
[ 7938.752930] I/O error, dev sdb, sector 754048 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7939.109634] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7939.109648] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7939.109655] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7939.109663] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 82 00 00 00 80 00
[ 7939.109668] I/O error, dev sdb, sector 754176 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7939.197649] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7939.197666] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7939.197673] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7939.197682] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 82 00 00 00 80 00
[ 7939.197687] I/O error, dev sdb, sector 754176 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7940.063765] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7940.063784] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7940.063792] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7940.063801] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 82 80 00 00 80 00
[ 7940.063806] I/O error, dev sdb, sector 754304 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7941.376501] scsi_io_completion_action: 2 callbacks suppressed
[ 7941.376521] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7941.376536] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7941.376546] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7941.376555] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 83 00 00 00 80 00
[ 7941.376560] blk_print_req_error: 2 callbacks suppressed
[ 7941.376565] I/O error, dev sdb, sector 754432 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7941.733637] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7941.733650] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7941.733658] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7941.733666] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 83 80 00 00 80 00
[ 7941.733671] I/O error, dev sdb, sector 754560 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7941.821766] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7941.821782] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7941.821790] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7941.821798] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 83 80 00 00 80 00
[ 7941.821804] I/O error, dev sdb, sector 754560 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7942.688628] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7942.688646] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7942.688654] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7942.688663] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 84 00 00 00 80 00
[ 7942.688669] I/O error, dev sdb, sector 754688 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7943.045637] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7943.045654] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7943.045661] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7943.045670] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 84 00 00 00 80 00
[ 7943.045676] I/O error, dev sdb, sector 754688 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7943.133745] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7943.133758] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7943.133765] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7943.133773] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 84 80 00 00 80 00
[ 7943.133778] I/O error, dev sdb, sector 754816 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7944.001254] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7944.001272] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7944.001281] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7944.001290] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 84 80 00 00 80 00
[ 7944.001295] I/O error, dev sdb, sector 754816 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7944.357632] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7944.357647] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7944.357655] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7944.357664] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 85 00 00 00 80 00
[ 7944.357669] I/O error, dev sdb, sector 754944 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7944.449622] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7944.449638] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7944.449645] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7944.449655] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 85 00 00 00 80 00
[ 7944.449660] I/O error, dev sdb, sector 754944 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7945.316527] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7945.316544] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7945.316552] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7945.316561] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 85 80 00 00 80 00
[ 7945.316566] I/O error, dev sdb, sector 755072 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7946.628848] scsi_io_completion_action: 2 callbacks suppressed
[ 7946.628867] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7946.628882] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7946.628890] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7946.628899] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 86 00 00 00 80 00
[ 7946.628904] blk_print_req_error: 2 callbacks suppressed
[ 7946.628908] I/O error, dev sdb, sector 755200 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7946.985482] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7946.985499] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7946.985507] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7946.985516] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 86 80 00 00 80 00
[ 7946.985521] I/O error, dev sdb, sector 755328 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7947.073624] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7947.073641] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7947.073649] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7947.073658] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 86 80 00 00 80 00
[ 7947.073663] I/O error, dev sdb, sector 755328 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7947.940120] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7947.940136] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7947.940144] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7947.940152] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 87 00 00 00 80 00
[ 7947.940158] I/O error, dev sdb, sector 755456 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7948.297479] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7948.297497] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7948.297505] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7948.297515] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 87 00 00 00 80 00
[ 7948.297520] I/O error, dev sdb, sector 755456 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7948.385603] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7948.385617] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7948.385625] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7948.385633] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 87 80 00 00 80 00
[ 7948.385638] I/O error, dev sdb, sector 755584 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7949.251618] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7949.251636] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7949.251644] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7949.251653] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 87 80 00 00 80 00
[ 7949.251658] I/O error, dev sdb, sector 755584 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7949.609614] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7949.609629] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7949.609637] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7949.609646] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 88 00 00 00 80 00
[ 7949.609651] I/O error, dev sdb, sector 755712 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7949.697598] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7949.697614] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7949.697622] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7949.697631] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 88 00 00 00 80 00
[ 7949.697636] I/O error, dev sdb, sector 755712 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7950.564238] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7950.564256] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7950.564265] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7950.564273] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 88 80 00 00 80 00
[ 7950.564279] I/O error, dev sdb, sector 755840 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7951.876358] scsi_io_completion_action: 2 callbacks suppressed
[ 7951.876378] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7951.876394] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7951.876402] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7951.876411] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 89 00 00 00 80 00
[ 7951.876416] blk_print_req_error: 2 callbacks suppressed
[ 7951.876421] I/O error, dev sdb, sector 755968 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7952.241463] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7952.241480] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7952.241489] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7952.241497] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 89 80 00 00 80 00
[ 7952.241503] I/O error, dev sdb, sector 756096 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7952.329481] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7952.329498] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7952.329506] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7952.329515] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 89 80 00 00 80 00
[ 7952.329520] I/O error, dev sdb, sector 756096 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7953.195000] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7953.195018] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7953.195026] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7953.195035] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8a 00 00 00 80 00
[ 7953.195041] I/O error, dev sdb, sector 756224 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7953.553478] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7953.553493] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7953.553501] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7953.553509] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8a 00 00 00 80 00
[ 7953.553515] I/O error, dev sdb, sector 756224 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7953.641452] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7953.641465] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7953.641472] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7953.641480] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8a 80 00 00 80 00
[ 7953.641485] I/O error, dev sdb, sector 756352 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7954.507852] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7954.507871] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7954.507879] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7954.507888] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8a 80 00 00 80 00
[ 7954.507893] I/O error, dev sdb, sector 756352 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7954.865468] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7954.865482] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7954.865490] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7954.865498] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8b 00 00 00 80 00
[ 7954.865503] I/O error, dev sdb, sector 756480 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7954.953462] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7954.953478] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7954.953486] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7954.953494] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8b 00 00 00 80 00
[ 7954.953500] I/O error, dev sdb, sector 756480 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7955.819347] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7955.819365] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7955.819373] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7955.819382] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8b 80 00 00 80 00
[ 7955.819388] I/O error, dev sdb, sector 756608 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7957.131704] scsi_io_completion_action: 2 callbacks suppressed
[ 7957.131723] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7957.131739] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7957.131746] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7957.131755] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8c 00 00 00 80 00
[ 7957.131760] blk_print_req_error: 2 callbacks suppressed
[ 7957.131764] I/O error, dev sdb, sector 756736 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7957.489466] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7957.489484] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7957.489492] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7957.489501] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8c 80 00 00 80 00
[ 7957.489506] I/O error, dev sdb, sector 756864 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7957.577447] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7957.577464] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7957.577472] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7957.577481] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8c 80 00 00 80 00
[ 7957.577486] I/O error, dev sdb, sector 756864 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7958.443825] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7958.443841] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7958.443848] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7958.443857] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8d 00 00 00 80 00
[ 7958.443862] I/O error, dev sdb, sector 756992 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7958.801444] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7958.801463] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7958.801471] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7958.801480] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8d 00 00 00 80 00
[ 7958.801485] I/O error, dev sdb, sector 756992 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7958.889436] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7958.889449] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7958.889456] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7958.889465] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8d 80 00 00 80 00
[ 7958.889470] I/O error, dev sdb, sector 757120 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7959.756210] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7959.756228] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7959.756236] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7959.756245] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8d 80 00 00 80 00
[ 7959.756251] I/O error, dev sdb, sector 757120 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7960.113578] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7960.113593] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7960.113600] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7960.113609] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8e 00 00 00 80 00
[ 7960.113614] I/O error, dev sdb, sector 757248 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7960.201562] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7960.201579] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7960.201587] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7960.201596] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8e 00 00 00 80 00
[ 7960.201601] I/O error, dev sdb, sector 757248 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7961.067447] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7961.067465] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7961.067473] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7961.067482] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8e 80 00 00 80 00
[ 7961.067488] I/O error, dev sdb, sector 757376 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7962.379554] scsi_io_completion_action: 2 callbacks suppressed
[ 7962.379574] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7962.379590] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7962.379598] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7962.379607] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8f 00 00 00 80 00
[ 7962.379612] blk_print_req_error: 2 callbacks suppressed
[ 7962.379617] I/O error, dev sdb, sector 757504 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7962.737301] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7962.737314] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7962.737322] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7962.737330] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8f 80 00 00 80 00
[ 7962.737335] I/O error, dev sdb, sector 757632 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7962.825442] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7962.825459] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7962.825467] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7962.825476] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8f 80 00 00 80 00
[ 7962.825482] I/O error, dev sdb, sector 757632 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7963.690945] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7963.690962] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7963.690969] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7963.690979] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 90 00 00 00 80 00
[ 7963.690984] I/O error, dev sdb, sector 757760 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7964.049317] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7964.049336] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7964.049344] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7964.049353] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 90 00 00 00 80 00
[ 7964.049358] I/O error, dev sdb, sector 757760 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7964.133435] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7964.133448] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7964.133455] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7964.133464] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 90 80 00 00 80 00
[ 7964.133469] I/O error, dev sdb, sector 757888 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7964.998941] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7964.998959] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7964.998968] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7964.998977] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 90 80 00 00 80 00
[ 7964.998983] I/O error, dev sdb, sector 757888 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7965.353312] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7965.353329] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7965.353337] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7965.353345] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 91 00 00 00 80 00
[ 7965.353351] I/O error, dev sdb, sector 758016 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7965.441294] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7965.441310] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7965.441318] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7965.441327] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 91 00 00 00 80 00
[ 7965.441332] I/O error, dev sdb, sector 758016 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7966.306420] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7966.306438] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7966.306446] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7966.306454] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 91 80 00 00 80 00
[ 7966.306460] I/O error, dev sdb, sector 758144 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7967.615915] scsi_io_completion_action: 2 callbacks suppressed
[ 7967.615935] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7967.615949] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7967.615957] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7967.615966] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 92 00 00 00 80 00
[ 7967.615971] blk_print_req_error: 2 callbacks suppressed
[ 7967.615975] I/O error, dev sdb, sector 758272 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7967.973293] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7967.973310] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7967.973317] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7967.973326] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 92 80 00 00 80 00
[ 7967.973331] I/O error, dev sdb, sector 758400 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7968.061285] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7968.061304] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7968.061312] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7968.061321] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 92 80 00 00 80 00
[ 7968.061326] I/O error, dev sdb, sector 758400 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7968.926942] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7968.926958] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7968.926966] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7968.926975] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 93 00 00 00 80 00
[ 7968.926980] I/O error, dev sdb, sector 758528 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7969.285301] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7969.285319] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7969.285327] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7969.285336] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 93 00 00 00 80 00
[ 7969.285342] I/O error, dev sdb, sector 758528 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7969.369294] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7969.369306] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7969.369314] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7969.369322] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 93 80 00 00 80 00
[ 7969.369327] I/O error, dev sdb, sector 758656 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7970.235779] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7970.235797] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7970.235805] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7970.235814] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 93 80 00 00 80 00
[ 7970.235820] I/O error, dev sdb, sector 758656 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7970.593401] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7970.593416] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7970.593424] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7970.593432] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 94 00 00 00 80 00
[ 7970.593438] I/O error, dev sdb, sector 758784 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7970.685293] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7970.685309] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7970.685317] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7970.685325] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 94 00 00 00 80 00
[ 7970.685330] I/O error, dev sdb, sector 758784 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7971.551899] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7971.551917] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7971.551925] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7971.551934] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 94 80 00 00 80 00
[ 7971.551940] I/O error, dev sdb, sector 758912 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7972.864146] scsi_io_completion_action: 2 callbacks suppressed
[ 7972.864165] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7972.864181] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7972.864189] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7972.864198] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 95 00 00 00 80 00
[ 7972.864203] blk_print_req_error: 2 callbacks suppressed
[ 7972.864208] I/O error, dev sdb, sector 759040 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7973.221268] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7973.221284] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7973.221293] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7973.221301] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 95 80 00 00 80 00
[ 7973.221307] I/O error, dev sdb, sector 759168 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7973.309268] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7973.309284] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7973.309292] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7973.309301] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 95 80 00 00 80 00
[ 7973.309306] I/O error, dev sdb, sector 759168 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7974.176149] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7974.176166] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7974.176174] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7974.176183] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 96 00 00 00 80 00
[ 7974.176189] I/O error, dev sdb, sector 759296 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7974.533264] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7974.533283] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7974.533291] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7974.533300] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 96 00 00 00 80 00
[ 7974.533305] I/O error, dev sdb, sector 759296 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7974.621277] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7974.621291] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7974.621299] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7974.621307] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 96 80 00 00 80 00
[ 7974.621312] I/O error, dev sdb, sector 759424 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7975.487034] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7975.487052] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7975.487060] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7975.487069] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 96 80 00 00 80 00
[ 7975.487075] I/O error, dev sdb, sector 759424 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7975.845148] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7975.845160] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7975.845168] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7975.845176] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 97 00 00 00 80 00
[ 7975.845181] I/O error, dev sdb, sector 759552 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7975.941145] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7975.941161] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7975.941169] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7975.941177] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 97 00 00 00 80 00
[ 7975.941183] I/O error, dev sdb, sector 759552 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7976.807385] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7976.807404] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7976.807412] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7976.807421] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 97 80 00 00 80 00
[ 7976.807426] I/O error, dev sdb, sector 759680 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7978.119867] scsi_io_completion_action: 2 callbacks suppressed
[ 7978.119918] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7978.119931] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7978.119939] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7978.119949] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 98 00 00 00 80 00
[ 7978.119954] blk_print_req_error: 2 callbacks suppressed
[ 7978.119959] I/O error, dev sdb, sector 759808 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7978.477126] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7978.477144] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7978.477152] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7978.477161] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 98 80 00 00 80 00
[ 7978.477167] I/O error, dev sdb, sector 759936 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7978.565256] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7978.565273] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7978.565281] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7978.565289] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 98 80 00 00 80 00
[ 7978.565295] I/O error, dev sdb, sector 759936 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7979.431389] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7979.431405] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7979.431413] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7979.431422] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 99 00 00 00 80 00
[ 7979.431427] I/O error, dev sdb, sector 760064 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7979.789141] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7979.789161] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7979.789169] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7979.789179] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 99 00 00 00 80 00
[ 7979.789184] I/O error, dev sdb, sector 760064 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7979.877120] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7979.877135] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7979.877143] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7979.877152] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 99 80 00 00 80 00
[ 7979.877157] I/O error, dev sdb, sector 760192 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7980.743620] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7980.743639] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7980.743647] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7980.743657] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 99 80 00 00 80 00
[ 7980.743663] I/O error, dev sdb, sector 760192 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 8045.423538] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8045.423558] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8045.423566] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8045.423575] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f a0 00 00 10 00
[ 8045.423581] I/O error, dev sdb, sector 4000 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8045.423601] Buffer I/O error on dev sdb1, logical block 1952, lost async page write
[ 8045.423615] Buffer I/O error on dev sdb1, logical block 1953, lost async page write
[ 8045.423623] Buffer I/O error on dev sdb1, logical block 1954, lost async page write
[ 8045.423632] Buffer I/O error on dev sdb1, logical block 1955, lost async page write
[ 8045.423640] Buffer I/O error on dev sdb1, logical block 1956, lost async page write
[ 8045.423648] Buffer I/O error on dev sdb1, logical block 1957, lost async page write
[ 8045.423656] Buffer I/O error on dev sdb1, logical block 1958, lost async page write
[ 8045.423664] Buffer I/O error on dev sdb1, logical block 1959, lost async page write
[ 8045.423683] Buffer I/O error on dev sdb1, logical block 1960, lost async page write
[ 8045.423693] Buffer I/O error on dev sdb1, logical block 1961, lost async page write
[ 8045.776294] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8045.776311] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8045.776320] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8045.776329] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f c0 00 00 10 00
[ 8045.776335] I/O error, dev sdb, sector 4032 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8051.564395] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8051.564413] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8051.564422] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8051.564432] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f a8 00 00 20 00
[ 8051.564439] I/O error, dev sdb, sector 4008 op 0x1:(WRITE) flags 0x100000 phys_seg 32 prio class 2
[ 8051.564458] buffer_io_error: 22 callbacks suppressed
[ 8051.564463] Buffer I/O error on dev sdb1, logical block 1960, lost async page write
[ 8051.564478] Buffer I/O error on dev sdb1, logical block 1961, lost async page write
[ 8051.564487] Buffer I/O error on dev sdb1, logical block 1962, lost async page write
[ 8051.564495] Buffer I/O error on dev sdb1, logical block 1963, lost async page write
[ 8051.564503] Buffer I/O error on dev sdb1, logical block 1964, lost async page write
[ 8051.564511] Buffer I/O error on dev sdb1, logical block 1965, lost async page write
[ 8051.564520] Buffer I/O error on dev sdb1, logical block 1966, lost async page write
[ 8051.564528] Buffer I/O error on dev sdb1, logical block 1967, lost async page write
[ 8051.564546] Buffer I/O error on dev sdb1, logical block 1968, lost async page write
[ 8051.564555] Buffer I/O error on dev sdb1, logical block 1969, lost async page write
[ 8051.768780] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8051.768799] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8051.768807] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8051.768817] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 30 00 00 08 00
[ 8051.768823] I/O error, dev sdb, sector 4144 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8056.684258] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8056.684278] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8056.684286] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8056.684296] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f b0 00 00 48 00
[ 8056.684302] I/O error, dev sdb, sector 4016 op 0x1:(WRITE) flags 0x100000 phys_seg 72 prio class 2
[ 8056.684322] buffer_io_error: 30 callbacks suppressed
[ 8056.684327] Buffer I/O error on dev sdb1, logical block 1968, lost async page write
[ 8056.684342] Buffer I/O error on dev sdb1, logical block 1969, lost async page write
[ 8056.684350] Buffer I/O error on dev sdb1, logical block 1970, lost async page write
[ 8056.684359] Buffer I/O error on dev sdb1, logical block 1971, lost async page write
[ 8056.684367] Buffer I/O error on dev sdb1, logical block 1972, lost async page write
[ 8056.684375] Buffer I/O error on dev sdb1, logical block 1973, lost async page write
[ 8056.684383] Buffer I/O error on dev sdb1, logical block 1974, lost async page write
[ 8056.684391] Buffer I/O error on dev sdb1, logical block 1975, lost async page write
[ 8056.684409] Buffer I/O error on dev sdb1, logical block 1976, lost async page write
[ 8056.684418] Buffer I/O error on dev sdb1, logical block 1977, lost async page write
[ 8062.126899] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8062.578893] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8063.026866] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8063.482889] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8063.930882] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8064.382856] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8064.543620] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=2s
[ 8064.543637] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f f8 00 00 48 00
[ 8064.543644] I/O error, dev sdb, sector 4088 op 0x1:(WRITE) flags 0x100000 phys_seg 72 prio class 2
[ 8064.543663] buffer_io_error: 62 callbacks suppressed
[ 8064.543669] Buffer I/O error on dev sdb1, logical block 2040, lost async page write
[ 8064.543683] Buffer I/O error on dev sdb1, logical block 2041, lost async page write
[ 8064.543692] Buffer I/O error on dev sdb1, logical block 2042, lost async page write
[ 8064.543700] Buffer I/O error on dev sdb1, logical block 2043, lost async page write
[ 8064.543708] Buffer I/O error on dev sdb1, logical block 2044, lost async page write
[ 8064.543716] Buffer I/O error on dev sdb1, logical block 2045, lost async page write
[ 8064.543724] Buffer I/O error on dev sdb1, logical block 2046, lost async page write
[ 8064.543732] Buffer I/O error on dev sdb1, logical block 2047, lost async page write
[ 8064.543749] Buffer I/O error on dev sdb1, logical block 2048, lost async page write
[ 8064.543758] Buffer I/O error on dev sdb1, logical block 2049, lost async page write
[ 8070.128071] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8070.128088] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8070.128096] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8070.128105] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f a8 00 00 08 00
[ 8070.128111] I/O error, dev sdb, sector 4008 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8070.128129] buffer_io_error: 62 callbacks suppressed
[ 8070.128134] Buffer I/O error on dev sdb1, logical block 1960, lost async page write
[ 8070.128149] Buffer I/O error on dev sdb1, logical block 1961, lost async page write
[ 8070.128157] Buffer I/O error on dev sdb1, logical block 1962, lost async page write
[ 8070.128165] Buffer I/O error on dev sdb1, logical block 1963, lost async page write
[ 8070.128173] Buffer I/O error on dev sdb1, logical block 1964, lost async page write
[ 8070.128181] Buffer I/O error on dev sdb1, logical block 1965, lost async page write
[ 8070.128189] Buffer I/O error on dev sdb1, logical block 1966, lost async page write
[ 8070.128196] Buffer I/O error on dev sdb1, logical block 1967, lost async page write
[ 8070.208083] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8070.208097] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8070.208104] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8070.208113] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f c0 00 00 10 00
[ 8070.208118] I/O error, dev sdb, sector 4032 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8070.208134] Buffer I/O error on dev sdb1, logical block 1984, lost async page write
[ 8070.208145] Buffer I/O error on dev sdb1, logical block 1985, lost async page write
[ 8070.925955] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8070.925974] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8070.925983] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8070.925992] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f d8 00 00 08 00
[ 8070.925998] I/O error, dev sdb, sector 4056 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8071.408070] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8071.408089] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8071.408098] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8071.408107] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f f0 00 00 08 00
[ 8071.408113] I/O error, dev sdb, sector 4080 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8071.488069] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8071.488083] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8071.488091] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8071.488100] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 08 00 00 10 00
[ 8071.488106] I/O error, dev sdb, sector 4104 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8072.073956] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8072.073973] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8072.073981] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8072.073990] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 20 00 00 10 00
[ 8072.073996] I/O error, dev sdb, sector 4128 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8072.700065] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8072.700082] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8072.700090] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8072.700099] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 40 00 00 08 00
[ 8072.700105] I/O error, dev sdb, sector 4160 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8072.796085] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8072.796103] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8072.796111] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8072.796121] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 a8 00 00 08 00
[ 8072.796127] I/O error, dev sdb, sector 4264 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8073.000441] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8073.000458] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8073.000466] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8073.000476] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 70 00 00 08 00
[ 8073.000481] I/O error, dev sdb, sector 4208 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8073.726325] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8073.726342] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8073.726350] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8073.726359] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 88 00 00 08 00
[ 8073.726365] I/O error, dev sdb, sector 4232 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8080.240043] scsi_io_completion_action: 3 callbacks suppressed
[ 8080.240063] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8080.240078] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8080.240086] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8080.240095] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 48 00 00 08 00
[ 8080.240100] blk_print_req_error: 3 callbacks suppressed
[ 8080.240105] I/O error, dev sdb, sector 4168 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8080.240123] buffer_io_error: 118 callbacks suppressed
[ 8080.240127] Buffer I/O error on dev sdb1, logical block 2120, lost async page write
[ 8080.240140] Buffer I/O error on dev sdb1, logical block 2121, lost async page write
[ 8080.240149] Buffer I/O error on dev sdb1, logical block 2122, lost async page write
[ 8080.240157] Buffer I/O error on dev sdb1, logical block 2123, lost async page write
[ 8080.240165] Buffer I/O error on dev sdb1, logical block 2124, lost async page write
[ 8080.240173] Buffer I/O error on dev sdb1, logical block 2125, lost async page write
[ 8080.240182] Buffer I/O error on dev sdb1, logical block 2126, lost async page write
[ 8080.240190] Buffer I/O error on dev sdb1, logical block 2127, lost async page write
[ 8089.692278] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8089.692298] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8089.692306] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8089.692316] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 50 00 00 48 00
[ 8089.692322] I/O error, dev sdb, sector 4176 op 0x1:(WRITE) flags 0x100000 phys_seg 72 prio class 2
[ 8089.692341] Buffer I/O error on dev sdb1, logical block 2128, lost async page write
[ 8089.692354] Buffer I/O error on dev sdb1, logical block 2129, lost async page write
[ 8089.692363] Buffer I/O error on dev sdb1, logical block 2130, lost async page write
[ 8089.692372] Buffer I/O error on dev sdb1, logical block 2131, lost async page write
[ 8089.692380] Buffer I/O error on dev sdb1, logical block 2132, lost async page write
[ 8089.692388] Buffer I/O error on dev sdb1, logical block 2133, lost async page write
[ 8089.692396] Buffer I/O error on dev sdb1, logical block 2134, lost async page write
[ 8089.692405] Buffer I/O error on dev sdb1, logical block 2135, lost async page write
[ 8089.692419] Buffer I/O error on dev sdb1, logical block 2136, lost async page write
[ 8089.692429] Buffer I/O error on dev sdb1, logical block 2137, lost async page write
[ 8094.727761] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8094.727781] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8094.727790] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8094.727799] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 98 00 00 18 00
[ 8094.727805] I/O error, dev sdb, sector 4248 op 0x1:(WRITE) flags 0x100000 phys_seg 24 prio class 2
[ 8094.727825] buffer_io_error: 62 callbacks suppressed
[ 8094.727830] Buffer I/O error on dev sdb1, logical block 2200, lost async page write
[ 8094.727844] Buffer I/O error on dev sdb1, logical block 2201, lost async page write
[ 8094.727853] Buffer I/O error on dev sdb1, logical block 2202, lost async page write
[ 8094.727861] Buffer I/O error on dev sdb1, logical block 2203, lost async page write
[ 8094.727869] Buffer I/O error on dev sdb1, logical block 2204, lost async page write
[ 8094.727877] Buffer I/O error on dev sdb1, logical block 2205, lost async page write
[ 8094.727885] Buffer I/O error on dev sdb1, logical block 2206, lost async page write
[ 8094.727894] Buffer I/O error on dev sdb1, logical block 2207, lost async page write
[ 8094.727908] Buffer I/O error on dev sdb1, logical block 2208, lost async page write
[ 8094.727917] Buffer I/O error on dev sdb1, logical block 2209, lost async page write
[ 8095.095748] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8095.095766] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8095.095774] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8095.095783] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 58 00 00 10 00
[ 8095.095789] I/O error, dev sdb, sector 4440 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8095.195872] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8095.195884] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8095.195892] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8095.195900] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 70 00 00 48 00
[ 8095.195905] I/O error, dev sdb, sector 4464 op 0x1:(WRITE) flags 0x100000 phys_seg 72 prio class 2
[ 8095.531007] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8095.531023] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8095.531031] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8095.531039] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 c0 00 00 18 00
[ 8095.531045] I/O error, dev sdb, sector 4544 op 0x1:(WRITE) flags 0x100000 phys_seg 24 prio class 2
[ 8104.311727] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8104.311747] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8104.311755] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8104.311764] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 1f 30 00 00 08 00
[ 8104.311770] I/O error, dev sdb, sector 7984 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8104.311790] buffer_io_error: 126 callbacks suppressed
[ 8104.311795] Buffer I/O error on dev sdb1, logical block 5936, lost async page write
[ 8104.311809] Buffer I/O error on dev sdb1, logical block 5937, lost async page write
[ 8104.311818] Buffer I/O error on dev sdb1, logical block 5938, lost async page write
[ 8104.311826] Buffer I/O error on dev sdb1, logical block 5939, lost async page write
[ 8104.311834] Buffer I/O error on dev sdb1, logical block 5940, lost async page write
[ 8104.311842] Buffer I/O error on dev sdb1, logical block 5941, lost async page write
[ 8104.311851] Buffer I/O error on dev sdb1, logical block 5942, lost async page write
[ 8104.311859] Buffer I/O error on dev sdb1, logical block 5943, lost async page write
[ 8117.091538] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8117.091558] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8117.091566] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8117.091576] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 24 b8 00 00 08 00
[ 8117.091581] I/O error, dev sdb, sector 9400 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8117.091600] Buffer I/O error on dev sdb1, logical block 7352, lost async page write
[ 8117.091612] Buffer I/O error on dev sdb1, logical block 7353, lost async page write
[ 8117.091621] Buffer I/O error on dev sdb1, logical block 7354, lost async page write
[ 8117.091629] Buffer I/O error on dev sdb1, logical block 7355, lost async page write
[ 8117.091637] Buffer I/O error on dev sdb1, logical block 7356, lost async page write
[ 8117.091645] Buffer I/O error on dev sdb1, logical block 7357, lost async page write
[ 8117.091653] Buffer I/O error on dev sdb1, logical block 7358, lost async page write
[ 8117.091660] Buffer I/O error on dev sdb1, logical block 7359, lost async page write
[ 8117.295924] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8117.295937] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8117.295944] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8117.295952] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 2f a0 00 00 08 00
[ 8117.295957] I/O error, dev sdb, sector 12192 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8117.295972] Buffer I/O error on dev sdb1, logical block 10144, lost async page write
[ 8117.295983] Buffer I/O error on dev sdb1, logical block 10145, lost async page write
[ 8123.499393] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8123.499413] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8123.499421] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8123.499430] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f a0 00 00 08 00
[ 8123.499436] I/O error, dev sdb, sector 4000 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8123.499455] buffer_io_error: 6 callbacks suppressed
[ 8123.499460] Buffer I/O error on dev sdb1, logical block 1952, lost async page write
[ 8123.499473] Buffer I/O error on dev sdb1, logical block 1953, lost async page write
[ 8123.499481] Buffer I/O error on dev sdb1, logical block 1954, lost async page write
[ 8123.499489] Buffer I/O error on dev sdb1, logical block 1955, lost async page write
[ 8123.499497] Buffer I/O error on dev sdb1, logical block 1956, lost async page write
[ 8123.499505] Buffer I/O error on dev sdb1, logical block 1957, lost async page write
[ 8123.499513] Buffer I/O error on dev sdb1, logical block 1958, lost async page write
[ 8123.499521] Buffer I/O error on dev sdb1, logical block 1959, lost async page write
[ 8123.703794] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8123.703806] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8123.703814] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8123.703822] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 b0 00 00 08 00
[ 8123.703827] I/O error, dev sdb, sector 4272 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8123.703841] Buffer I/O error on dev sdb1, logical block 2224, lost async page write
[ 8123.703852] Buffer I/O error on dev sdb1, logical block 2225, lost async page write
[ 8124.427146] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8124.427164] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8124.427171] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8124.427180] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 1f 30 00 00 08 00
[ 8124.427186] I/O error, dev sdb, sector 7984 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8124.779392] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8124.779411] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8124.779419] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8124.779428] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 20 00 00 00 08 00
[ 8124.779434] I/O error, dev sdb, sector 8192 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8124.859392] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8124.859411] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8124.859419] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8124.859429] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0c 0f a0 00 00 08 00
[ 8124.859435] I/O error, dev sdb, sector 790432 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8166.498880] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8166.498899] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8166.498907] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8166.498916] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f a0 00 00 18 00
[ 8166.498922] I/O error, dev sdb, sector 4000 op 0x1:(WRITE) flags 0x100000 phys_seg 24 prio class 2
[ 8166.498942] buffer_io_error: 30 callbacks suppressed
[ 8166.498947] Buffer I/O error on dev sdb1, logical block 1952, lost async page write
[ 8166.498961] Buffer I/O error on dev sdb1, logical block 1953, lost async page write
[ 8166.498970] Buffer I/O error on dev sdb1, logical block 1954, lost async page write
[ 8166.498978] Buffer I/O error on dev sdb1, logical block 1955, lost async page write
[ 8166.498986] Buffer I/O error on dev sdb1, logical block 1956, lost async page write
[ 8166.498995] Buffer I/O error on dev sdb1, logical block 1957, lost async page write
[ 8166.499003] Buffer I/O error on dev sdb1, logical block 1958, lost async page write
[ 8166.499011] Buffer I/O error on dev sdb1, logical block 1959, lost async page write
[ 8166.499030] Buffer I/O error on dev sdb1, logical block 1960, lost async page write
[ 8166.499038] Buffer I/O error on dev sdb1, logical block 1961, lost async page write
[ 8166.703261] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8166.703280] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8166.703289] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8166.703298] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 1f 30 00 00 08 00
[ 8166.703304] I/O error, dev sdb, sector 7984 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8171.890885] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8171.890902] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8171.890910] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8171.890919] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f b8 00 00 20 00
[ 8171.890925] I/O error, dev sdb, sector 4024 op 0x1:(WRITE) flags 0x100000 phys_seg 32 prio class 2
[ 8171.890944] buffer_io_error: 22 callbacks suppressed
[ 8171.890949] Buffer I/O error on dev sdb1, logical block 1976, lost async page write
[ 8171.890969] Buffer I/O error on dev sdb1, logical block 1977, lost async page write
[ 8171.890978] Buffer I/O error on dev sdb1, logical block 1978, lost async page write
[ 8171.890986] Buffer I/O error on dev sdb1, logical block 1979, lost async page write
[ 8171.890994] Buffer I/O error on dev sdb1, logical block 1980, lost async page write
[ 8171.891002] Buffer I/O error on dev sdb1, logical block 1981, lost async page write
[ 8171.891010] Buffer I/O error on dev sdb1, logical block 1982, lost async page write
[ 8171.891018] Buffer I/O error on dev sdb1, logical block 1983, lost async page write
[ 8171.891036] Buffer I/O error on dev sdb1, logical block 1984, lost async page write
[ 8171.891045] Buffer I/O error on dev sdb1, logical block 1985, lost async page write
[ 8177.375234] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8177.375252] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8177.375260] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8177.375270] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f d8 00 00 28 00
[ 8177.375276] I/O error, dev sdb, sector 4056 op 0x1:(WRITE) flags 0x100000 phys_seg 40 prio class 2
[ 8177.375297] buffer_io_error: 22 callbacks suppressed
[ 8177.375302] Buffer I/O error on dev sdb1, logical block 2008, lost async page write
[ 8177.375317] Buffer I/O error on dev sdb1, logical block 2009, lost async page write
[ 8177.375326] Buffer I/O error on dev sdb1, logical block 2010, lost async page write
[ 8177.375334] Buffer I/O error on dev sdb1, logical block 2011, lost async page write
[ 8177.375343] Buffer I/O error on dev sdb1, logical block 2012, lost async page write
[ 8177.375351] Buffer I/O error on dev sdb1, logical block 2013, lost async page write
[ 8177.375359] Buffer I/O error on dev sdb1, logical block 2014, lost async page write
[ 8177.375367] Buffer I/O error on dev sdb1, logical block 2015, lost async page write
[ 8177.375386] Buffer I/O error on dev sdb1, logical block 2016, lost async page write
[ 8177.375395] Buffer I/O error on dev sdb1, logical block 2017, lost async page write
[ 8182.638723] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8182.638742] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8182.638750] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8182.638759] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 00 00 00 20 00
[ 8182.638765] I/O error, dev sdb, sector 4096 op 0x1:(WRITE) flags 0x100000 phys_seg 32 prio class 2
[ 8182.638786] buffer_io_error: 30 callbacks suppressed
[ 8182.638791] Buffer I/O error on dev sdb1, logical block 2048, lost async page write
[ 8182.638806] Buffer I/O error on dev sdb1, logical block 2049, lost async page write
[ 8182.638815] Buffer I/O error on dev sdb1, logical block 2050, lost async page write
[ 8182.638823] Buffer I/O error on dev sdb1, logical block 2051, lost async page write
[ 8182.638831] Buffer I/O error on dev sdb1, logical block 2052, lost async page write
[ 8182.638839] Buffer I/O error on dev sdb1, logical block 2053, lost async page write
[ 8182.638847] Buffer I/O error on dev sdb1, logical block 2054, lost async page write
[ 8182.638855] Buffer I/O error on dev sdb1, logical block 2055, lost async page write
[ 8182.638873] Buffer I/O error on dev sdb1, logical block 2056, lost async page write
[ 8182.638882] Buffer I/O error on dev sdb1, logical block 2057, lost async page write
[ 8188.639205] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8188.639223] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8188.639231] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8188.639240] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 20 00 00 30 00
[ 8188.639246] I/O error, dev sdb, sector 4128 op 0x1:(WRITE) flags 0x100000 phys_seg 48 prio class 2
[ 8188.639267] buffer_io_error: 22 callbacks suppressed
[ 8188.639272] Buffer I/O error on dev sdb1, logical block 2080, lost async page write
[ 8188.639286] Buffer I/O error on dev sdb1, logical block 2081, lost async page write
[ 8188.639295] Buffer I/O error on dev sdb1, logical block 2082, lost async page write
[ 8188.639303] Buffer I/O error on dev sdb1, logical block 2083, lost async page write
[ 8188.639312] Buffer I/O error on dev sdb1, logical block 2084, lost async page write
[ 8188.639320] Buffer I/O error on dev sdb1, logical block 2085, lost async page write
[ 8188.639328] Buffer I/O error on dev sdb1, logical block 2086, lost async page write
[ 8188.639336] Buffer I/O error on dev sdb1, logical block 2087, lost async page write
[ 8188.639353] Buffer I/O error on dev sdb1, logical block 2088, lost async page write
[ 8188.639362] Buffer I/O error on dev sdb1, logical block 2089, lost async page write
[ 8194.170689] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8194.170707] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8194.170715] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8194.170724] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 50 00 00 28 00
[ 8194.170730] I/O error, dev sdb, sector 4176 op 0x1:(WRITE) flags 0x100000 phys_seg 40 prio class 2
[ 8194.170750] buffer_io_error: 38 callbacks suppressed
[ 8194.170755] Buffer I/O error on dev sdb1, logical block 2128, lost async page write
[ 8194.170769] Buffer I/O error on dev sdb1, logical block 2129, lost async page write
[ 8194.170779] Buffer I/O error on dev sdb1, logical block 2130, lost async page write
[ 8194.170787] Buffer I/O error on dev sdb1, logical block 2131, lost async page write
[ 8194.170795] Buffer I/O error on dev sdb1, logical block 2132, lost async page write
[ 8194.170803] Buffer I/O error on dev sdb1, logical block 2133, lost async page write
[ 8194.170811] Buffer I/O error on dev sdb1, logical block 2134, lost async page write
[ 8194.170819] Buffer I/O error on dev sdb1, logical block 2135, lost async page write
[ 8194.170837] Buffer I/O error on dev sdb1, logical block 2136, lost async page write
[ 8194.170846] Buffer I/O error on dev sdb1, logical block 2137, lost async page write
[ 8199.395055] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8199.395074] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8199.395082] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8199.395092] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 78 00 00 38 00
[ 8199.395098] I/O error, dev sdb, sector 4216 op 0x1:(WRITE) flags 0x100000 phys_seg 56 prio class 2
[ 8199.395118] buffer_io_error: 30 callbacks suppressed
[ 8199.395124] Buffer I/O error on dev sdb1, logical block 2168, lost async page write
[ 8199.395138] Buffer I/O error on dev sdb1, logical block 2169, lost async page write
[ 8199.395147] Buffer I/O error on dev sdb1, logical block 2170, lost async page write
[ 8199.395156] Buffer I/O error on dev sdb1, logical block 2171, lost async page write
[ 8199.395164] Buffer I/O error on dev sdb1, logical block 2172, lost async page write
[ 8199.395172] Buffer I/O error on dev sdb1, logical block 2173, lost async page write
[ 8199.395181] Buffer I/O error on dev sdb1, logical block 2174, lost async page write
[ 8199.395189] Buffer I/O error on dev sdb1, logical block 2175, lost async page write
[ 8199.395206] Buffer I/O error on dev sdb1, logical block 2176, lost async page write
[ 8199.395215] Buffer I/O error on dev sdb1, logical block 2177, lost async page write
[ 8200.117711] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8200.117730] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8200.117740] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8200.117749] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 b8 00 00 b8 00
[ 8200.117755] I/O error, dev sdb, sector 4280 op 0x1:(WRITE) flags 0x100000 phys_seg 184 prio class 2
[ 8205.674391] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8205.674411] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8205.674419] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8205.674429] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 70 00 00 30 00
[ 8205.674436] I/O error, dev sdb, sector 4464 op 0x1:(WRITE) flags 0x100000 phys_seg 48 prio class 2
[ 8205.674456] buffer_io_error: 230 callbacks suppressed
[ 8205.674461] Buffer I/O error on dev sdb1, logical block 2416, lost async page write
[ 8205.674476] Buffer I/O error on dev sdb1, logical block 2417, lost async page write
[ 8205.674485] Buffer I/O error on dev sdb1, logical block 2418, lost async page write
[ 8205.674493] Buffer I/O error on dev sdb1, logical block 2419, lost async page write
[ 8205.674501] Buffer I/O error on dev sdb1, logical block 2420, lost async page write
[ 8205.674509] Buffer I/O error on dev sdb1, logical block 2421, lost async page write
[ 8205.674517] Buffer I/O error on dev sdb1, logical block 2422, lost async page write
[ 8205.674526] Buffer I/O error on dev sdb1, logical block 2423, lost async page write
[ 8205.674543] Buffer I/O error on dev sdb1, logical block 2424, lost async page write
[ 8205.674551] Buffer I/O error on dev sdb1, logical block 2425, lost async page write
[ 8211.166859] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8211.166879] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8211.166887] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8211.166896] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 a0 00 00 20 00
[ 8211.166902] I/O error, dev sdb, sector 4512 op 0x1:(WRITE) flags 0x100000 phys_seg 32 prio class 2
[ 8211.166921] buffer_io_error: 38 callbacks suppressed
[ 8211.166926] Buffer I/O error on dev sdb1, logical block 2464, lost async page write
[ 8211.166940] Buffer I/O error on dev sdb1, logical block 2465, lost async page write
[ 8211.166948] Buffer I/O error on dev sdb1, logical block 2466, lost async page write
[ 8211.166956] Buffer I/O error on dev sdb1, logical block 2467, lost async page write
[ 8211.166964] Buffer I/O error on dev sdb1, logical block 2468, lost async page write
[ 8211.166972] Buffer I/O error on dev sdb1, logical block 2469, lost async page write
[ 8211.166980] Buffer I/O error on dev sdb1, logical block 2470, lost async page write
[ 8211.166988] Buffer I/O error on dev sdb1, logical block 2471, lost async page write
[ 8211.167001] Buffer I/O error on dev sdb1, logical block 2472, lost async page write
[ 8211.167010] Buffer I/O error on dev sdb1, logical block 2473, lost async page write
[ 8214.902362] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8214.902379] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8214.902388] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8214.902397] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 08 08 00 00 08 00
[ 8214.902403] I/O error, dev sdb, sector 2056 op 0x1:(WRITE) flags 0x800 phys_seg 8 prio class 2
[ 8215.106848] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8215.106865] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8215.106873] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8215.106883] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f 90 00 00 10 00
[ 8215.106888] I/O error, dev sdb, sector 3984 op 0x1:(WRITE) flags 0x800 phys_seg 16 prio class 2
[ 8215.828844] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8215.828863] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8215.828871] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8215.828880] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 b0 00 00 08 00
[ 8215.828886] I/O error, dev sdb, sector 4272 op 0x1:(WRITE) flags 0x800 phys_seg 8 prio class 2
[ 8216.182354] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8216.182370] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8216.182378] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8216.182387] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 c0 00 00 18 00
[ 8216.182392] I/O error, dev sdb, sector 4544 op 0x1:(WRITE) flags 0x800 phys_seg 24 prio class 2
[ 8216.182409] buffer_io_error: 54 callbacks suppressed
[ 8216.182414] Buffer I/O error on dev sdb1, logical block 2496, lost async page write
[ 8216.182428] Buffer I/O error on dev sdb1, logical block 2497, lost async page write
[ 8216.182437] Buffer I/O error on dev sdb1, logical block 2498, lost async page write
[ 8216.182445] Buffer I/O error on dev sdb1, logical block 2499, lost async page write
[ 8216.182453] Buffer I/O error on dev sdb1, logical block 2500, lost async page write
[ 8216.182461] Buffer I/O error on dev sdb1, logical block 2501, lost async page write
[ 8216.182469] Buffer I/O error on dev sdb1, logical block 2502, lost async page write
[ 8216.182477] Buffer I/O error on dev sdb1, logical block 2503, lost async page write
[ 8216.182492] Buffer I/O error on dev sdb1, logical block 2504, lost async page write
[ 8216.182501] Buffer I/O error on dev sdb1, logical block 2505, lost async page write
[ 8216.262328] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8216.262341] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8216.262349] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8216.262357] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 20 00 00 00 18 00
[ 8216.262363] I/O error, dev sdb, sector 8192 op 0x1:(WRITE) flags 0x800 phys_seg 24 prio class 2
[ 8216.979101] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8216.979119] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8216.979127] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8216.979136] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 04 0f 90 00 00 10 00
[ 8216.979141] I/O error, dev sdb, sector 266128 op 0x1:(WRITE) flags 0x800 phys_seg 16 prio class 2
[ 8217.462221] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8217.462237] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8217.462245] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8217.462254] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 08 08 00 00 00 10 00
[ 8217.462260] I/O error, dev sdb, sector 526336 op 0x1:(WRITE) flags 0x800 phys_seg 16 prio class 2
[ 8217.542199] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8217.542212] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8217.542219] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8217.542227] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0c 0f 90 00 00 18 00
[ 8217.542232] I/O error, dev sdb, sector 790416 op 0x1:(WRITE) flags 0x800 phys_seg 24 prio class 2
Then i must suppose that my usb ports and/or pendrives are going to break? I've got a Lenovo Thinkpad T400.
I've tried to run also mkfs.ext2 -F -F, but still with no success.
Another thing; i've also tried to format with Gparted and i noticed this: in the drive selection window the program tell me /dev/sdb, while in the partition selection window i see /dev/sdb1. It's some problem between the kernel and my hardware?
I got Gparted screenshot anyway (which i pointed out this drive/partition name difference), but i don't know how to attach it to this post.
Thank you for your help!
#2 2023-05-18 18:58:06
Re: usb pendrive always mounted as read-only
root@FM2:~# mkfs.ext2 -c /dev/sdb
Is this the command you used, or did you try writing to /dev/sdb1 (a partition) instead of the whole device?
#3 2023-05-18 20:32:28
Panda1100 wrote:
I show you mkfs and kernel ...
Please post terminal output/printout as code.
In the bar above you will see, among other options, 'code' (between brackets).
Click on it and you will get 'code' and '/code' both beween brackets.
Post all the terminal output between 'code' and '/code' (each is between brackets).
Use the 'Preview' button below to check.
Thanks.
#4 2023-05-19 10:43:55
Panda1100
Sorry, here the logs:
mke2fs 1.47.0 (5-Feb-2023)
Found a dos partition table in /dev/sdb
Proceed anyway? (y,N) y
Creating filesystem with 987136 4k blocks and 247008 inodes
Filesystem UUID: 75560978-8c85-462b-9234-24723938cc17
Superblock backups stored on blocks:
	32768, 98304, 163840, 229376, 294912, 819200, 884736
Checking for bad blocks (read-only test): done
Allocating group tables: done
Writing inode tables: done
Writing superblocks and filesystem accounting information: mkfs.ext2: Input/output error while writing out and closing file system
[ 7876.166469] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7876.166485] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7876.166493] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7876.166502] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 5e 00 00 00 80 00
[ 7876.166507] I/O error, dev sdb, sector 744960 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7877.031966] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7877.031983] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7877.031991] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7877.032000] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 5e 80 00 00 80 00
[ 7877.032006] I/O error, dev sdb, sector 745088 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7878.345345] scsi_io_completion_action: 2 callbacks suppressed
[ 7878.345368] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7878.345384] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7878.345392] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7878.345401] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 5f 00 00 00 80 00
[ 7878.345406] blk_print_req_error: 2 callbacks suppressed
[ 7878.345411] I/O error, dev sdb, sector 745216 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7878.702343] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7878.702360] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7878.702368] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7878.702377] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 5f 80 00 00 80 00
[ 7878.702383] I/O error, dev sdb, sector 745344 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7878.790352] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7878.790368] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7878.790376] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7878.790384] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 5f 80 00 00 80 00
[ 7878.790390] I/O error, dev sdb, sector 745344 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7879.657102] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7879.657121] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7879.657129] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7879.657139] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 60 00 00 00 80 00
[ 7879.657145] I/O error, dev sdb, sector 745472 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7880.014454] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7880.014471] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7880.014479] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7880.014488] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 60 00 00 00 80 00
[ 7880.014494] I/O error, dev sdb, sector 745472 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7880.102333] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7880.102346] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7880.102354] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7880.102362] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 60 80 00 00 80 00
[ 7880.102367] I/O error, dev sdb, sector 745600 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7880.970239] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7880.970258] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7880.970267] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7880.970276] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 60 80 00 00 80 00
[ 7880.970282] I/O error, dev sdb, sector 745600 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7881.326344] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7881.326359] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7881.326367] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7881.326376] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 61 00 00 00 80 00
[ 7881.326381] I/O error, dev sdb, sector 745728 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7881.414325] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7881.414341] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7881.414349] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7881.414357] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 61 00 00 00 80 00
[ 7881.414363] I/O error, dev sdb, sector 745728 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7882.281113] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7882.281129] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7882.281138] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7882.281147] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 61 80 00 00 80 00
[ 7882.281153] I/O error, dev sdb, sector 745856 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7883.593084] scsi_io_completion_action: 2 callbacks suppressed
[ 7883.593108] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7883.593124] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7883.593132] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7883.593141] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 62 00 00 00 80 00
[ 7883.593146] blk_print_req_error: 2 callbacks suppressed
[ 7883.593150] I/O error, dev sdb, sector 745984 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7883.950316] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7883.950333] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7883.950341] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7883.950349] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 62 80 00 00 80 00
[ 7883.950354] I/O error, dev sdb, sector 746112 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7884.038328] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7884.038346] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7884.038355] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7884.038364] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 62 80 00 00 80 00
[ 7884.038370] I/O error, dev sdb, sector 746112 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7884.905117] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7884.905133] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7884.905140] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7884.905149] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 63 00 00 00 80 00
[ 7884.905155] I/O error, dev sdb, sector 746240 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7885.262315] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7885.262333] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7885.262341] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7885.262350] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 63 00 00 00 80 00
[ 7885.262355] I/O error, dev sdb, sector 746240 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7885.350325] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7885.350337] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7885.350345] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7885.350353] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 63 80 00 00 80 00
[ 7885.350358] I/O error, dev sdb, sector 746368 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7886.217311] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7886.217329] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7886.217337] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7886.217345] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 63 80 00 00 80 00
[ 7886.217351] I/O error, dev sdb, sector 746368 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7886.574308] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7886.574324] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7886.574332] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7886.574340] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 64 00 00 00 80 00
[ 7886.574345] I/O error, dev sdb, sector 746496 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7886.662314] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7886.662330] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7886.662338] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7886.662346] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 64 00 00 00 80 00
[ 7886.662352] I/O error, dev sdb, sector 746496 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7887.528824] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7887.528842] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7887.528849] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7887.528858] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 64 80 00 00 80 00
[ 7887.528864] I/O error, dev sdb, sector 746624 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7888.841670] scsi_io_completion_action: 2 callbacks suppressed
[ 7888.841690] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7888.841706] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7888.841714] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7888.841723] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 65 00 00 00 80 00
[ 7888.841728] blk_print_req_error: 2 callbacks suppressed
[ 7888.841733] I/O error, dev sdb, sector 746752 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7889.198304] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7889.198318] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7889.198326] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7889.198334] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 65 80 00 00 80 00
[ 7889.198339] I/O error, dev sdb, sector 746880 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7889.286299] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7889.286316] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7889.286324] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7889.286332] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 65 80 00 00 80 00
[ 7889.286338] I/O error, dev sdb, sector 746880 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7890.153052] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7890.153069] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7890.153077] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7890.153087] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 66 00 00 00 80 00
[ 7890.153092] I/O error, dev sdb, sector 747008 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7890.510168] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7890.510185] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7890.510194] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7890.510202] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 66 00 00 00 80 00
[ 7890.510207] I/O error, dev sdb, sector 747008 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7890.598173] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7890.598186] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7890.598193] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7890.598201] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 66 80 00 00 80 00
[ 7890.598206] I/O error, dev sdb, sector 747136 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7891.465063] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7891.465083] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7891.465091] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7891.465100] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 66 80 00 00 80 00
[ 7891.465106] I/O error, dev sdb, sector 747136 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7891.822304] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7891.822316] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7891.822324] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7891.822332] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 67 00 00 00 80 00
[ 7891.822337] I/O error, dev sdb, sector 747264 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7891.914183] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7891.914199] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7891.914207] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7891.914216] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 67 00 00 00 80 00
[ 7891.914221] I/O error, dev sdb, sector 747264 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7892.780184] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7892.780201] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7892.780209] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7892.780218] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 67 80 00 00 80 00
[ 7892.780224] I/O error, dev sdb, sector 747392 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7894.093415] scsi_io_completion_action: 2 callbacks suppressed
[ 7894.093434] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7894.093449] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7894.093457] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7894.093467] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 68 00 00 00 80 00
[ 7894.093471] blk_print_req_error: 2 callbacks suppressed
[ 7894.093476] I/O error, dev sdb, sector 747520 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7894.450175] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7894.450192] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7894.450200] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7894.450208] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 68 80 00 00 80 00
[ 7894.450214] I/O error, dev sdb, sector 747648 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7894.538166] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7894.538182] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7894.538190] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7894.538198] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 68 80 00 00 80 00
[ 7894.538204] I/O error, dev sdb, sector 747648 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7895.404537] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7895.404552] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7895.404560] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7895.404569] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 69 00 00 00 80 00
[ 7895.404574] I/O error, dev sdb, sector 747776 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7895.766155] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7895.766174] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7895.766182] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7895.766191] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 69 00 00 00 80 00
[ 7895.766197] I/O error, dev sdb, sector 747776 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7895.854164] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7895.854177] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7895.854185] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7895.854193] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 69 80 00 00 80 00
[ 7895.854198] I/O error, dev sdb, sector 747904 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7896.721164] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7896.721182] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7896.721190] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7896.721199] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 69 80 00 00 80 00
[ 7896.721205] I/O error, dev sdb, sector 747904 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7897.078153] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7897.078167] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7897.078174] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7897.078182] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6a 00 00 00 80 00
[ 7897.078188] I/O error, dev sdb, sector 748032 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7897.166163] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7897.166179] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7897.166187] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7897.166195] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6a 00 00 00 80 00
[ 7897.166200] I/O error, dev sdb, sector 748032 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7898.032287] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7898.032305] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7898.032312] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7898.032322] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6a 80 00 00 80 00
[ 7898.032327] I/O error, dev sdb, sector 748160 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7899.344886] scsi_io_completion_action: 2 callbacks suppressed
[ 7899.344906] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7899.344922] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7899.344929] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7899.344939] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6b 00 00 00 80 00
[ 7899.344944] blk_print_req_error: 2 callbacks suppressed
[ 7899.344949] I/O error, dev sdb, sector 748288 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7899.702281] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7899.702298] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7899.702306] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7899.702315] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6b 80 00 00 80 00
[ 7899.702320] I/O error, dev sdb, sector 748416 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7899.790147] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7899.790163] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7899.790171] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7899.790180] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6b 80 00 00 80 00
[ 7899.790185] I/O error, dev sdb, sector 748416 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7900.656645] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7900.656664] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7900.656671] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7900.656680] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6c 00 00 00 80 00
[ 7900.656686] I/O error, dev sdb, sector 748544 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7901.014259] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7901.014276] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7901.014284] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7901.014293] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6c 00 00 00 80 00
[ 7901.014299] I/O error, dev sdb, sector 748544 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7901.102129] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7901.102142] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7901.102150] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7901.102158] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6c 80 00 00 80 00
[ 7901.102163] I/O error, dev sdb, sector 748672 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7901.969402] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7901.969420] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7901.969429] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7901.969437] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6c 80 00 00 80 00
[ 7901.969443] I/O error, dev sdb, sector 748672 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7902.326148] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7902.326164] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7902.326172] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7902.326181] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6d 00 00 00 80 00
[ 7902.326186] I/O error, dev sdb, sector 748800 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7902.414129] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7902.414146] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7902.414155] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7902.414163] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6d 00 00 00 80 00
[ 7902.414168] I/O error, dev sdb, sector 748800 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7903.280633] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7903.280652] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7903.280661] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7903.280669] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6d 80 00 00 80 00
[ 7903.280675] I/O error, dev sdb, sector 748928 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7904.593371] scsi_io_completion_action: 2 callbacks suppressed
[ 7904.593391] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7904.593406] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7904.593414] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7904.593423] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6e 00 00 00 80 00
[ 7904.593428] blk_print_req_error: 2 callbacks suppressed
[ 7904.593433] I/O error, dev sdb, sector 749056 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7904.953996] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7904.954012] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7904.954020] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7904.954028] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6e 80 00 00 80 00
[ 7904.954034] I/O error, dev sdb, sector 749184 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7905.042014] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7905.042030] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7905.042038] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7905.042047] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6e 80 00 00 80 00
[ 7905.042052] I/O error, dev sdb, sector 749184 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7905.908385] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7905.908401] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7905.908409] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7905.908418] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6f 00 00 00 80 00
[ 7905.908423] I/O error, dev sdb, sector 749312 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7906.265994] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7906.266012] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7906.266020] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7906.266029] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6f 00 00 00 80 00
[ 7906.266035] I/O error, dev sdb, sector 749312 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7906.353988] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7906.354003] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7906.354010] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7906.354018] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6f 80 00 00 80 00
[ 7906.354024] I/O error, dev sdb, sector 749440 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7907.220631] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7907.220648] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7907.220656] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7907.220665] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 6f 80 00 00 80 00
[ 7907.220671] I/O error, dev sdb, sector 749440 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7907.578112] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7907.578128] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7907.578136] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7907.578144] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 70 00 00 00 80 00
[ 7907.578150] I/O error, dev sdb, sector 749568 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7907.666120] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7907.666136] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7907.666144] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7907.666152] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 70 00 00 00 80 00
[ 7907.666158] I/O error, dev sdb, sector 749568 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7908.532370] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7908.532389] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7908.532397] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7908.532406] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 70 80 00 00 80 00
[ 7908.532411] I/O error, dev sdb, sector 749696 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7909.845470] scsi_io_completion_action: 2 callbacks suppressed
[ 7909.845489] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7909.845505] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7909.845513] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7909.845522] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 71 00 00 00 80 00
[ 7909.845527] blk_print_req_error: 2 callbacks suppressed
[ 7909.845532] I/O error, dev sdb, sector 749824 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7910.201995] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7910.202012] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7910.202020] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7910.202028] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 71 80 00 00 80 00
[ 7910.202033] I/O error, dev sdb, sector 749952 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7910.289989] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7910.290005] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7910.290013] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7910.290022] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 71 80 00 00 80 00
[ 7910.290027] I/O error, dev sdb, sector 749952 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7911.156622] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7911.156641] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7911.156649] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7911.156658] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 72 00 00 00 80 00
[ 7911.156663] I/O error, dev sdb, sector 750080 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7911.513992] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7911.514010] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7911.514018] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7911.514027] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 72 00 00 00 80 00
[ 7911.514033] I/O error, dev sdb, sector 750080 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7911.601967] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7911.601979] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7911.601987] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7911.601995] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 72 80 00 00 80 00
[ 7911.602000] I/O error, dev sdb, sector 750208 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7912.469848] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7912.469867] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7912.469876] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7912.469885] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 72 80 00 00 80 00
[ 7912.469890] I/O error, dev sdb, sector 750208 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7912.825966] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7912.825979] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7912.825987] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7912.825995] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 73 00 00 00 80 00
[ 7912.826000] I/O error, dev sdb, sector 750336 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7912.913970] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7912.913986] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7912.913994] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7912.914003] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 73 00 00 00 80 00
[ 7912.914008] I/O error, dev sdb, sector 750336 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7913.780470] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7913.780488] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7913.780496] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7913.780505] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 73 80 00 00 80 00
[ 7913.780511] I/O error, dev sdb, sector 750464 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7915.109459] scsi_io_completion_action: 2 callbacks suppressed
[ 7915.109479] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7915.109495] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7915.109503] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7915.109511] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 74 00 00 00 80 00
[ 7915.109516] blk_print_req_error: 2 callbacks suppressed
[ 7915.109522] I/O error, dev sdb, sector 750592 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7915.465981] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7915.465998] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7915.466006] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7915.466015] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 74 80 00 00 80 00
[ 7915.466020] I/O error, dev sdb, sector 750720 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7915.553962] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7915.553978] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7915.553987] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7915.553995] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 74 80 00 00 80 00
[ 7915.554000] I/O error, dev sdb, sector 750720 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7916.420464] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7916.420479] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7916.420487] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7916.420495] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 75 00 00 00 80 00
[ 7916.420501] I/O error, dev sdb, sector 750848 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7916.782091] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7916.782109] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7916.782117] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7916.782126] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 75 00 00 00 80 00
[ 7916.782132] I/O error, dev sdb, sector 750848 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7916.870083] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7916.870095] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7916.870102] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7916.870110] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 75 80 00 00 80 00
[ 7916.870115] I/O error, dev sdb, sector 750976 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7917.738098] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7917.738116] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7917.738124] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7917.738133] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 75 80 00 00 80 00
[ 7917.738139] I/O error, dev sdb, sector 750976 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7918.093967] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7918.093980] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7918.093988] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7918.093996] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 76 00 00 00 80 00
[ 7918.094001] I/O error, dev sdb, sector 751104 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7918.181953] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7918.181969] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7918.181977] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7918.181985] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 76 00 00 00 80 00
[ 7918.181991] I/O error, dev sdb, sector 751104 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7919.048460] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7919.048477] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7919.048485] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7919.048494] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 76 80 00 00 80 00
[ 7919.048500] I/O error, dev sdb, sector 751232 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7920.361205] scsi_io_completion_action: 2 callbacks suppressed
[ 7920.361225] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7920.361240] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7920.361248] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7920.361257] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 77 00 00 00 80 00
[ 7920.361262] blk_print_req_error: 2 callbacks suppressed
[ 7920.361267] I/O error, dev sdb, sector 751360 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7920.717829] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7920.717844] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7920.717852] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7920.717861] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 77 80 00 00 80 00
[ 7920.717866] I/O error, dev sdb, sector 751488 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7920.805830] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7920.805846] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7920.805855] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7920.805863] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 77 80 00 00 80 00
[ 7920.805869] I/O error, dev sdb, sector 751488 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7921.672603] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7921.672622] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7921.672629] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7921.672638] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 78 00 00 00 80 00
[ 7921.672644] I/O error, dev sdb, sector 751616 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7922.029814] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7922.029831] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7922.029839] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7922.029848] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 78 00 00 00 80 00
[ 7922.029853] I/O error, dev sdb, sector 751616 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7922.117818] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7922.117830] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7922.117838] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7922.117846] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 78 80 00 00 80 00
[ 7922.117851] I/O error, dev sdb, sector 751744 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7922.986315] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7922.986333] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7922.986341] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7922.986350] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 78 80 00 00 80 00
[ 7922.986356] I/O error, dev sdb, sector 751744 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7923.345812] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7923.345827] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7923.345835] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7923.345844] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 79 00 00 00 80 00
[ 7923.345849] I/O error, dev sdb, sector 751872 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7923.433816] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7923.433832] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7923.433840] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7923.433848] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 79 00 00 00 80 00
[ 7923.433854] I/O error, dev sdb, sector 751872 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7924.301573] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7924.301591] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7924.301599] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7924.301608] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 79 80 00 00 80 00
[ 7924.301614] I/O error, dev sdb, sector 752000 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7925.618668] scsi_io_completion_action: 2 callbacks suppressed
[ 7925.618689] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7925.618705] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7925.618713] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7925.618722] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7a 00 00 00 80 00
[ 7925.618727] blk_print_req_error: 2 callbacks suppressed
[ 7925.618732] I/O error, dev sdb, sector 752128 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7925.977799] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7925.977816] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7925.977824] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7925.977833] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7a 80 00 00 80 00
[ 7925.977838] I/O error, dev sdb, sector 752256 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7926.069820] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7926.069837] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7926.069844] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7926.069853] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7a 80 00 00 80 00
[ 7926.069859] I/O error, dev sdb, sector 752256 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7926.936814] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7926.936830] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7926.936838] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7926.936846] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7b 00 00 00 80 00
[ 7926.936852] I/O error, dev sdb, sector 752384 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7927.297817] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7927.297836] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7927.297844] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7927.297854] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7b 00 00 00 80 00
[ 7927.297859] I/O error, dev sdb, sector 752384 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7927.385796] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7927.385810] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7927.385818] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7927.385827] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7b 80 00 00 80 00
[ 7927.385832] I/O error, dev sdb, sector 752512 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7928.252690] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7928.252709] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7928.252717] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7928.252726] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7b 80 00 00 80 00
[ 7928.252731] I/O error, dev sdb, sector 752512 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7928.609792] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7928.609806] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7928.609814] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7928.609822] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7c 00 00 00 80 00
[ 7928.609828] I/O error, dev sdb, sector 752640 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7928.697798] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7928.697814] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7928.697822] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7928.697831] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7c 00 00 00 80 00
[ 7928.697836] I/O error, dev sdb, sector 752640 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7929.564432] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7929.564450] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7929.564458] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7929.564496] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7c 80 00 00 80 00
[ 7929.564503] I/O error, dev sdb, sector 752768 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7930.877170] scsi_io_completion_action: 2 callbacks suppressed
[ 7930.877190] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7930.877205] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7930.877214] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7930.877223] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7d 00 00 00 80 00
[ 7930.877228] blk_print_req_error: 2 callbacks suppressed
[ 7930.877232] I/O error, dev sdb, sector 752896 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7931.233804] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7931.233820] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7931.233828] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7931.233837] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7d 80 00 00 80 00
[ 7931.233842] I/O error, dev sdb, sector 753024 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7931.321783] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7931.321799] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7931.321808] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7931.321816] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7d 80 00 00 80 00
[ 7931.321822] I/O error, dev sdb, sector 753024 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7932.188910] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7932.188928] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7932.188937] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7932.188946] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7e 00 00 00 80 00
[ 7932.188951] I/O error, dev sdb, sector 753152 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7932.549780] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7932.549796] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7932.549804] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7932.549813] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7e 00 00 00 80 00
[ 7932.549819] I/O error, dev sdb, sector 753152 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7932.637901] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7932.637913] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7932.637921] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7932.637929] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7e 80 00 00 80 00
[ 7932.637934] I/O error, dev sdb, sector 753280 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7933.505029] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7933.505047] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7933.505055] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7933.505064] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7e 80 00 00 80 00
[ 7933.505070] I/O error, dev sdb, sector 753280 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7933.861779] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7933.861791] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7933.861799] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7933.861807] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7f 00 00 00 80 00
[ 7933.861812] I/O error, dev sdb, sector 753408 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7933.949782] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7933.949799] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7933.949807] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7933.949815] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7f 00 00 00 80 00
[ 7933.949821] I/O error, dev sdb, sector 753408 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7934.816169] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7934.816186] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7934.816194] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7934.816203] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 7f 80 00 00 80 00
[ 7934.816208] I/O error, dev sdb, sector 753536 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7936.128403] scsi_io_completion_action: 2 callbacks suppressed
[ 7936.128422] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7936.128438] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7936.128445] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7936.128454] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 80 00 00 00 80 00
[ 7936.128460] blk_print_req_error: 2 callbacks suppressed
[ 7936.128465] I/O error, dev sdb, sector 753664 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7936.485646] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7936.485664] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7936.485671] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7936.485680] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 80 80 00 00 80 00
[ 7936.485685] I/O error, dev sdb, sector 753792 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7936.573641] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7936.573658] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7936.573665] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7936.573675] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 80 80 00 00 80 00
[ 7936.573680] I/O error, dev sdb, sector 753792 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7937.439779] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7937.439794] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7937.439802] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7937.439810] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 81 00 00 00 80 00
[ 7937.439815] I/O error, dev sdb, sector 753920 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7937.797783] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7937.797800] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7937.797809] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7937.797818] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 81 00 00 00 80 00
[ 7937.797824] I/O error, dev sdb, sector 753920 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7937.885764] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7937.885776] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7937.885784] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7937.885792] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 81 80 00 00 80 00
[ 7937.885797] I/O error, dev sdb, sector 754048 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7938.752888] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7938.752907] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7938.752915] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7938.752925] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 81 80 00 00 80 00
[ 7938.752930] I/O error, dev sdb, sector 754048 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7939.109634] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7939.109648] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7939.109655] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7939.109663] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 82 00 00 00 80 00
[ 7939.109668] I/O error, dev sdb, sector 754176 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7939.197649] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7939.197666] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7939.197673] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7939.197682] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 82 00 00 00 80 00
[ 7939.197687] I/O error, dev sdb, sector 754176 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7940.063765] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7940.063784] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7940.063792] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7940.063801] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 82 80 00 00 80 00
[ 7940.063806] I/O error, dev sdb, sector 754304 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7941.376501] scsi_io_completion_action: 2 callbacks suppressed
[ 7941.376521] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7941.376536] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7941.376546] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7941.376555] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 83 00 00 00 80 00
[ 7941.376560] blk_print_req_error: 2 callbacks suppressed
[ 7941.376565] I/O error, dev sdb, sector 754432 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7941.733637] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7941.733650] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7941.733658] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7941.733666] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 83 80 00 00 80 00
[ 7941.733671] I/O error, dev sdb, sector 754560 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7941.821766] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7941.821782] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7941.821790] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7941.821798] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 83 80 00 00 80 00
[ 7941.821804] I/O error, dev sdb, sector 754560 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7942.688628] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7942.688646] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7942.688654] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7942.688663] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 84 00 00 00 80 00
[ 7942.688669] I/O error, dev sdb, sector 754688 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7943.045637] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7943.045654] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7943.045661] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7943.045670] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 84 00 00 00 80 00
[ 7943.045676] I/O error, dev sdb, sector 754688 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7943.133745] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7943.133758] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7943.133765] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7943.133773] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 84 80 00 00 80 00
[ 7943.133778] I/O error, dev sdb, sector 754816 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7944.001254] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7944.001272] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7944.001281] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7944.001290] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 84 80 00 00 80 00
[ 7944.001295] I/O error, dev sdb, sector 754816 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7944.357632] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7944.357647] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7944.357655] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7944.357664] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 85 00 00 00 80 00
[ 7944.357669] I/O error, dev sdb, sector 754944 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7944.449622] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7944.449638] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7944.449645] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7944.449655] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 85 00 00 00 80 00
[ 7944.449660] I/O error, dev sdb, sector 754944 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7945.316527] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7945.316544] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7945.316552] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7945.316561] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 85 80 00 00 80 00
[ 7945.316566] I/O error, dev sdb, sector 755072 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7946.628848] scsi_io_completion_action: 2 callbacks suppressed
[ 7946.628867] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7946.628882] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7946.628890] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7946.628899] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 86 00 00 00 80 00
[ 7946.628904] blk_print_req_error: 2 callbacks suppressed
[ 7946.628908] I/O error, dev sdb, sector 755200 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7946.985482] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7946.985499] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7946.985507] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7946.985516] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 86 80 00 00 80 00
[ 7946.985521] I/O error, dev sdb, sector 755328 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7947.073624] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7947.073641] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7947.073649] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7947.073658] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 86 80 00 00 80 00
[ 7947.073663] I/O error, dev sdb, sector 755328 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7947.940120] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7947.940136] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7947.940144] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7947.940152] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 87 00 00 00 80 00
[ 7947.940158] I/O error, dev sdb, sector 755456 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7948.297479] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7948.297497] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7948.297505] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7948.297515] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 87 00 00 00 80 00
[ 7948.297520] I/O error, dev sdb, sector 755456 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7948.385603] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7948.385617] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7948.385625] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7948.385633] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 87 80 00 00 80 00
[ 7948.385638] I/O error, dev sdb, sector 755584 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7949.251618] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7949.251636] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7949.251644] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7949.251653] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 87 80 00 00 80 00
[ 7949.251658] I/O error, dev sdb, sector 755584 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7949.609614] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7949.609629] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7949.609637] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7949.609646] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 88 00 00 00 80 00
[ 7949.609651] I/O error, dev sdb, sector 755712 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7949.697598] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7949.697614] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7949.697622] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7949.697631] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 88 00 00 00 80 00
[ 7949.697636] I/O error, dev sdb, sector 755712 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7950.564238] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7950.564256] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7950.564265] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7950.564273] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 88 80 00 00 80 00
[ 7950.564279] I/O error, dev sdb, sector 755840 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7951.876358] scsi_io_completion_action: 2 callbacks suppressed
[ 7951.876378] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7951.876394] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7951.876402] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7951.876411] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 89 00 00 00 80 00
[ 7951.876416] blk_print_req_error: 2 callbacks suppressed
[ 7951.876421] I/O error, dev sdb, sector 755968 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7952.241463] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7952.241480] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7952.241489] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7952.241497] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 89 80 00 00 80 00
[ 7952.241503] I/O error, dev sdb, sector 756096 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7952.329481] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7952.329498] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7952.329506] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7952.329515] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 89 80 00 00 80 00
[ 7952.329520] I/O error, dev sdb, sector 756096 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7953.195000] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7953.195018] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7953.195026] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7953.195035] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8a 00 00 00 80 00
[ 7953.195041] I/O error, dev sdb, sector 756224 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7953.553478] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7953.553493] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7953.553501] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7953.553509] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8a 00 00 00 80 00
[ 7953.553515] I/O error, dev sdb, sector 756224 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7953.641452] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7953.641465] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7953.641472] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7953.641480] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8a 80 00 00 80 00
[ 7953.641485] I/O error, dev sdb, sector 756352 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7954.507852] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7954.507871] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7954.507879] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7954.507888] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8a 80 00 00 80 00
[ 7954.507893] I/O error, dev sdb, sector 756352 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7954.865468] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7954.865482] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7954.865490] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7954.865498] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8b 00 00 00 80 00
[ 7954.865503] I/O error, dev sdb, sector 756480 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7954.953462] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7954.953478] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7954.953486] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7954.953494] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8b 00 00 00 80 00
[ 7954.953500] I/O error, dev sdb, sector 756480 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7955.819347] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7955.819365] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7955.819373] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7955.819382] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8b 80 00 00 80 00
[ 7955.819388] I/O error, dev sdb, sector 756608 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7957.131704] scsi_io_completion_action: 2 callbacks suppressed
[ 7957.131723] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7957.131739] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7957.131746] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7957.131755] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8c 00 00 00 80 00
[ 7957.131760] blk_print_req_error: 2 callbacks suppressed
[ 7957.131764] I/O error, dev sdb, sector 756736 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7957.489466] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7957.489484] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7957.489492] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7957.489501] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8c 80 00 00 80 00
[ 7957.489506] I/O error, dev sdb, sector 756864 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7957.577447] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7957.577464] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7957.577472] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7957.577481] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8c 80 00 00 80 00
[ 7957.577486] I/O error, dev sdb, sector 756864 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7958.443825] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7958.443841] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7958.443848] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7958.443857] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8d 00 00 00 80 00
[ 7958.443862] I/O error, dev sdb, sector 756992 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7958.801444] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7958.801463] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7958.801471] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7958.801480] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8d 00 00 00 80 00
[ 7958.801485] I/O error, dev sdb, sector 756992 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7958.889436] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7958.889449] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7958.889456] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7958.889465] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8d 80 00 00 80 00
[ 7958.889470] I/O error, dev sdb, sector 757120 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7959.756210] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7959.756228] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7959.756236] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7959.756245] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8d 80 00 00 80 00
[ 7959.756251] I/O error, dev sdb, sector 757120 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7960.113578] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7960.113593] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7960.113600] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7960.113609] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8e 00 00 00 80 00
[ 7960.113614] I/O error, dev sdb, sector 757248 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7960.201562] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7960.201579] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7960.201587] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7960.201596] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8e 00 00 00 80 00
[ 7960.201601] I/O error, dev sdb, sector 757248 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7961.067447] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7961.067465] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7961.067473] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7961.067482] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8e 80 00 00 80 00
[ 7961.067488] I/O error, dev sdb, sector 757376 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7962.379554] scsi_io_completion_action: 2 callbacks suppressed
[ 7962.379574] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7962.379590] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7962.379598] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7962.379607] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8f 00 00 00 80 00
[ 7962.379612] blk_print_req_error: 2 callbacks suppressed
[ 7962.379617] I/O error, dev sdb, sector 757504 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7962.737301] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7962.737314] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7962.737322] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7962.737330] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8f 80 00 00 80 00
[ 7962.737335] I/O error, dev sdb, sector 757632 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7962.825442] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7962.825459] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7962.825467] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7962.825476] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 8f 80 00 00 80 00
[ 7962.825482] I/O error, dev sdb, sector 757632 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7963.690945] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7963.690962] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7963.690969] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7963.690979] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 90 00 00 00 80 00
[ 7963.690984] I/O error, dev sdb, sector 757760 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7964.049317] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7964.049336] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7964.049344] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7964.049353] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 90 00 00 00 80 00
[ 7964.049358] I/O error, dev sdb, sector 757760 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7964.133435] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7964.133448] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7964.133455] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7964.133464] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 90 80 00 00 80 00
[ 7964.133469] I/O error, dev sdb, sector 757888 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7964.998941] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7964.998959] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7964.998968] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7964.998977] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 90 80 00 00 80 00
[ 7964.998983] I/O error, dev sdb, sector 757888 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7965.353312] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7965.353329] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7965.353337] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7965.353345] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 91 00 00 00 80 00
[ 7965.353351] I/O error, dev sdb, sector 758016 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7965.441294] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7965.441310] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7965.441318] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7965.441327] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 91 00 00 00 80 00
[ 7965.441332] I/O error, dev sdb, sector 758016 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7966.306420] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7966.306438] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7966.306446] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7966.306454] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 91 80 00 00 80 00
[ 7966.306460] I/O error, dev sdb, sector 758144 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7967.615915] scsi_io_completion_action: 2 callbacks suppressed
[ 7967.615935] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7967.615949] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7967.615957] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7967.615966] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 92 00 00 00 80 00
[ 7967.615971] blk_print_req_error: 2 callbacks suppressed
[ 7967.615975] I/O error, dev sdb, sector 758272 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7967.973293] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7967.973310] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7967.973317] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7967.973326] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 92 80 00 00 80 00
[ 7967.973331] I/O error, dev sdb, sector 758400 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7968.061285] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7968.061304] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7968.061312] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7968.061321] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 92 80 00 00 80 00
[ 7968.061326] I/O error, dev sdb, sector 758400 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7968.926942] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7968.926958] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7968.926966] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7968.926975] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 93 00 00 00 80 00
[ 7968.926980] I/O error, dev sdb, sector 758528 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7969.285301] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7969.285319] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7969.285327] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7969.285336] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 93 00 00 00 80 00
[ 7969.285342] I/O error, dev sdb, sector 758528 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7969.369294] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7969.369306] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7969.369314] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7969.369322] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 93 80 00 00 80 00
[ 7969.369327] I/O error, dev sdb, sector 758656 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7970.235779] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7970.235797] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7970.235805] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7970.235814] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 93 80 00 00 80 00
[ 7970.235820] I/O error, dev sdb, sector 758656 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7970.593401] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7970.593416] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7970.593424] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7970.593432] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 94 00 00 00 80 00
[ 7970.593438] I/O error, dev sdb, sector 758784 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7970.685293] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7970.685309] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7970.685317] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7970.685325] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 94 00 00 00 80 00
[ 7970.685330] I/O error, dev sdb, sector 758784 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7971.551899] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7971.551917] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7971.551925] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7971.551934] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 94 80 00 00 80 00
[ 7971.551940] I/O error, dev sdb, sector 758912 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7972.864146] scsi_io_completion_action: 2 callbacks suppressed
[ 7972.864165] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7972.864181] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7972.864189] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7972.864198] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 95 00 00 00 80 00
[ 7972.864203] blk_print_req_error: 2 callbacks suppressed
[ 7972.864208] I/O error, dev sdb, sector 759040 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7973.221268] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7973.221284] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7973.221293] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7973.221301] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 95 80 00 00 80 00
[ 7973.221307] I/O error, dev sdb, sector 759168 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7973.309268] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7973.309284] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7973.309292] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7973.309301] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 95 80 00 00 80 00
[ 7973.309306] I/O error, dev sdb, sector 759168 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7974.176149] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7974.176166] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7974.176174] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7974.176183] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 96 00 00 00 80 00
[ 7974.176189] I/O error, dev sdb, sector 759296 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7974.533264] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7974.533283] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7974.533291] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7974.533300] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 96 00 00 00 80 00
[ 7974.533305] I/O error, dev sdb, sector 759296 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7974.621277] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7974.621291] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7974.621299] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7974.621307] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 96 80 00 00 80 00
[ 7974.621312] I/O error, dev sdb, sector 759424 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7975.487034] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7975.487052] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7975.487060] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7975.487069] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 96 80 00 00 80 00
[ 7975.487075] I/O error, dev sdb, sector 759424 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7975.845148] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7975.845160] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7975.845168] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7975.845176] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 97 00 00 00 80 00
[ 7975.845181] I/O error, dev sdb, sector 759552 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7975.941145] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7975.941161] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7975.941169] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7975.941177] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 97 00 00 00 80 00
[ 7975.941183] I/O error, dev sdb, sector 759552 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7976.807385] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7976.807404] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7976.807412] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7976.807421] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 97 80 00 00 80 00
[ 7976.807426] I/O error, dev sdb, sector 759680 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7978.119867] scsi_io_completion_action: 2 callbacks suppressed
[ 7978.119918] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7978.119931] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7978.119939] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7978.119949] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 98 00 00 00 80 00
[ 7978.119954] blk_print_req_error: 2 callbacks suppressed
[ 7978.119959] I/O error, dev sdb, sector 759808 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7978.477126] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7978.477144] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7978.477152] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7978.477161] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 98 80 00 00 80 00
[ 7978.477167] I/O error, dev sdb, sector 759936 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7978.565256] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7978.565273] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7978.565281] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7978.565289] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 98 80 00 00 80 00
[ 7978.565295] I/O error, dev sdb, sector 759936 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7979.431389] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7979.431405] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7979.431413] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7979.431422] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 99 00 00 00 80 00
[ 7979.431427] I/O error, dev sdb, sector 760064 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7979.789141] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7979.789161] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7979.789169] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7979.789179] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 99 00 00 00 80 00
[ 7979.789184] I/O error, dev sdb, sector 760064 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 7979.877120] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7979.877135] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7979.877143] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7979.877152] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 99 80 00 00 80 00
[ 7979.877157] I/O error, dev sdb, sector 760192 op 0x1:(WRITE) flags 0x8800 phys_seg 16 prio class 2
[ 7980.743620] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 7980.743639] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 7980.743647] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 7980.743657] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0b 99 80 00 00 80 00
[ 7980.743663] I/O error, dev sdb, sector 760192 op 0x1:(WRITE) flags 0x8800 phys_seg 15 prio class 2
[ 8045.423538] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8045.423558] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8045.423566] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8045.423575] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f a0 00 00 10 00
[ 8045.423581] I/O error, dev sdb, sector 4000 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8045.423601] Buffer I/O error on dev sdb1, logical block 1952, lost async page write
[ 8045.423615] Buffer I/O error on dev sdb1, logical block 1953, lost async page write
[ 8045.423623] Buffer I/O error on dev sdb1, logical block 1954, lost async page write
[ 8045.423632] Buffer I/O error on dev sdb1, logical block 1955, lost async page write
[ 8045.423640] Buffer I/O error on dev sdb1, logical block 1956, lost async page write
[ 8045.423648] Buffer I/O error on dev sdb1, logical block 1957, lost async page write
[ 8045.423656] Buffer I/O error on dev sdb1, logical block 1958, lost async page write
[ 8045.423664] Buffer I/O error on dev sdb1, logical block 1959, lost async page write
[ 8045.423683] Buffer I/O error on dev sdb1, logical block 1960, lost async page write
[ 8045.423693] Buffer I/O error on dev sdb1, logical block 1961, lost async page write
[ 8045.776294] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8045.776311] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8045.776320] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8045.776329] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f c0 00 00 10 00
[ 8045.776335] I/O error, dev sdb, sector 4032 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8051.564395] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8051.564413] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8051.564422] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8051.564432] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f a8 00 00 20 00
[ 8051.564439] I/O error, dev sdb, sector 4008 op 0x1:(WRITE) flags 0x100000 phys_seg 32 prio class 2
[ 8051.564458] buffer_io_error: 22 callbacks suppressed
[ 8051.564463] Buffer I/O error on dev sdb1, logical block 1960, lost async page write
[ 8051.564478] Buffer I/O error on dev sdb1, logical block 1961, lost async page write
[ 8051.564487] Buffer I/O error on dev sdb1, logical block 1962, lost async page write
[ 8051.564495] Buffer I/O error on dev sdb1, logical block 1963, lost async page write
[ 8051.564503] Buffer I/O error on dev sdb1, logical block 1964, lost async page write
[ 8051.564511] Buffer I/O error on dev sdb1, logical block 1965, lost async page write
[ 8051.564520] Buffer I/O error on dev sdb1, logical block 1966, lost async page write
[ 8051.564528] Buffer I/O error on dev sdb1, logical block 1967, lost async page write
[ 8051.564546] Buffer I/O error on dev sdb1, logical block 1968, lost async page write
[ 8051.564555] Buffer I/O error on dev sdb1, logical block 1969, lost async page write
[ 8051.768780] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8051.768799] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8051.768807] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8051.768817] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 30 00 00 08 00
[ 8051.768823] I/O error, dev sdb, sector 4144 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8056.684258] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8056.684278] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8056.684286] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8056.684296] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f b0 00 00 48 00
[ 8056.684302] I/O error, dev sdb, sector 4016 op 0x1:(WRITE) flags 0x100000 phys_seg 72 prio class 2
[ 8056.684322] buffer_io_error: 30 callbacks suppressed
[ 8056.684327] Buffer I/O error on dev sdb1, logical block 1968, lost async page write
[ 8056.684342] Buffer I/O error on dev sdb1, logical block 1969, lost async page write
[ 8056.684350] Buffer I/O error on dev sdb1, logical block 1970, lost async page write
[ 8056.684359] Buffer I/O error on dev sdb1, logical block 1971, lost async page write
[ 8056.684367] Buffer I/O error on dev sdb1, logical block 1972, lost async page write
[ 8056.684375] Buffer I/O error on dev sdb1, logical block 1973, lost async page write
[ 8056.684383] Buffer I/O error on dev sdb1, logical block 1974, lost async page write
[ 8056.684391] Buffer I/O error on dev sdb1, logical block 1975, lost async page write
[ 8056.684409] Buffer I/O error on dev sdb1, logical block 1976, lost async page write
[ 8056.684418] Buffer I/O error on dev sdb1, logical block 1977, lost async page write
[ 8062.126899] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8062.578893] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8063.026866] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8063.482889] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8063.930882] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8064.382856] usb 8-2: reset high-speed USB device number 3 using ehci-pci
[ 8064.543620] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=2s
[ 8064.543637] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f f8 00 00 48 00
[ 8064.543644] I/O error, dev sdb, sector 4088 op 0x1:(WRITE) flags 0x100000 phys_seg 72 prio class 2
[ 8064.543663] buffer_io_error: 62 callbacks suppressed
[ 8064.543669] Buffer I/O error on dev sdb1, logical block 2040, lost async page write
[ 8064.543683] Buffer I/O error on dev sdb1, logical block 2041, lost async page write
[ 8064.543692] Buffer I/O error on dev sdb1, logical block 2042, lost async page write
[ 8064.543700] Buffer I/O error on dev sdb1, logical block 2043, lost async page write
[ 8064.543708] Buffer I/O error on dev sdb1, logical block 2044, lost async page write
[ 8064.543716] Buffer I/O error on dev sdb1, logical block 2045, lost async page write
[ 8064.543724] Buffer I/O error on dev sdb1, logical block 2046, lost async page write
[ 8064.543732] Buffer I/O error on dev sdb1, logical block 2047, lost async page write
[ 8064.543749] Buffer I/O error on dev sdb1, logical block 2048, lost async page write
[ 8064.543758] Buffer I/O error on dev sdb1, logical block 2049, lost async page write
[ 8070.128071] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8070.128088] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8070.128096] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8070.128105] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f a8 00 00 08 00
[ 8070.128111] I/O error, dev sdb, sector 4008 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8070.128129] buffer_io_error: 62 callbacks suppressed
[ 8070.128134] Buffer I/O error on dev sdb1, logical block 1960, lost async page write
[ 8070.128149] Buffer I/O error on dev sdb1, logical block 1961, lost async page write
[ 8070.128157] Buffer I/O error on dev sdb1, logical block 1962, lost async page write
[ 8070.128165] Buffer I/O error on dev sdb1, logical block 1963, lost async page write
[ 8070.128173] Buffer I/O error on dev sdb1, logical block 1964, lost async page write
[ 8070.128181] Buffer I/O error on dev sdb1, logical block 1965, lost async page write
[ 8070.128189] Buffer I/O error on dev sdb1, logical block 1966, lost async page write
[ 8070.128196] Buffer I/O error on dev sdb1, logical block 1967, lost async page write
[ 8070.208083] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8070.208097] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8070.208104] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8070.208113] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f c0 00 00 10 00
[ 8070.208118] I/O error, dev sdb, sector 4032 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8070.208134] Buffer I/O error on dev sdb1, logical block 1984, lost async page write
[ 8070.208145] Buffer I/O error on dev sdb1, logical block 1985, lost async page write
[ 8070.925955] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8070.925974] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8070.925983] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8070.925992] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f d8 00 00 08 00
[ 8070.925998] I/O error, dev sdb, sector 4056 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8071.408070] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8071.408089] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8071.408098] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8071.408107] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f f0 00 00 08 00
[ 8071.408113] I/O error, dev sdb, sector 4080 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8071.488069] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8071.488083] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8071.488091] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8071.488100] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 08 00 00 10 00
[ 8071.488106] I/O error, dev sdb, sector 4104 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8072.073956] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8072.073973] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8072.073981] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8072.073990] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 20 00 00 10 00
[ 8072.073996] I/O error, dev sdb, sector 4128 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8072.700065] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8072.700082] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8072.700090] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8072.700099] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 40 00 00 08 00
[ 8072.700105] I/O error, dev sdb, sector 4160 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8072.796085] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8072.796103] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8072.796111] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8072.796121] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 a8 00 00 08 00
[ 8072.796127] I/O error, dev sdb, sector 4264 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8073.000441] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8073.000458] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8073.000466] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8073.000476] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 70 00 00 08 00
[ 8073.000481] I/O error, dev sdb, sector 4208 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8073.726325] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8073.726342] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8073.726350] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8073.726359] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 88 00 00 08 00
[ 8073.726365] I/O error, dev sdb, sector 4232 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8080.240043] scsi_io_completion_action: 3 callbacks suppressed
[ 8080.240063] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8080.240078] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8080.240086] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8080.240095] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 48 00 00 08 00
[ 8080.240100] blk_print_req_error: 3 callbacks suppressed
[ 8080.240105] I/O error, dev sdb, sector 4168 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8080.240123] buffer_io_error: 118 callbacks suppressed
[ 8080.240127] Buffer I/O error on dev sdb1, logical block 2120, lost async page write
[ 8080.240140] Buffer I/O error on dev sdb1, logical block 2121, lost async page write
[ 8080.240149] Buffer I/O error on dev sdb1, logical block 2122, lost async page write
[ 8080.240157] Buffer I/O error on dev sdb1, logical block 2123, lost async page write
[ 8080.240165] Buffer I/O error on dev sdb1, logical block 2124, lost async page write
[ 8080.240173] Buffer I/O error on dev sdb1, logical block 2125, lost async page write
[ 8080.240182] Buffer I/O error on dev sdb1, logical block 2126, lost async page write
[ 8080.240190] Buffer I/O error on dev sdb1, logical block 2127, lost async page write
[ 8089.692278] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8089.692298] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8089.692306] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8089.692316] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 50 00 00 48 00
[ 8089.692322] I/O error, dev sdb, sector 4176 op 0x1:(WRITE) flags 0x100000 phys_seg 72 prio class 2
[ 8089.692341] Buffer I/O error on dev sdb1, logical block 2128, lost async page write
[ 8089.692354] Buffer I/O error on dev sdb1, logical block 2129, lost async page write
[ 8089.692363] Buffer I/O error on dev sdb1, logical block 2130, lost async page write
[ 8089.692372] Buffer I/O error on dev sdb1, logical block 2131, lost async page write
[ 8089.692380] Buffer I/O error on dev sdb1, logical block 2132, lost async page write
[ 8089.692388] Buffer I/O error on dev sdb1, logical block 2133, lost async page write
[ 8089.692396] Buffer I/O error on dev sdb1, logical block 2134, lost async page write
[ 8089.692405] Buffer I/O error on dev sdb1, logical block 2135, lost async page write
[ 8089.692419] Buffer I/O error on dev sdb1, logical block 2136, lost async page write
[ 8089.692429] Buffer I/O error on dev sdb1, logical block 2137, lost async page write
[ 8094.727761] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8094.727781] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8094.727790] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8094.727799] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 98 00 00 18 00
[ 8094.727805] I/O error, dev sdb, sector 4248 op 0x1:(WRITE) flags 0x100000 phys_seg 24 prio class 2
[ 8094.727825] buffer_io_error: 62 callbacks suppressed
[ 8094.727830] Buffer I/O error on dev sdb1, logical block 2200, lost async page write
[ 8094.727844] Buffer I/O error on dev sdb1, logical block 2201, lost async page write
[ 8094.727853] Buffer I/O error on dev sdb1, logical block 2202, lost async page write
[ 8094.727861] Buffer I/O error on dev sdb1, logical block 2203, lost async page write
[ 8094.727869] Buffer I/O error on dev sdb1, logical block 2204, lost async page write
[ 8094.727877] Buffer I/O error on dev sdb1, logical block 2205, lost async page write
[ 8094.727885] Buffer I/O error on dev sdb1, logical block 2206, lost async page write
[ 8094.727894] Buffer I/O error on dev sdb1, logical block 2207, lost async page write
[ 8094.727908] Buffer I/O error on dev sdb1, logical block 2208, lost async page write
[ 8094.727917] Buffer I/O error on dev sdb1, logical block 2209, lost async page write
[ 8095.095748] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8095.095766] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8095.095774] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8095.095783] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 58 00 00 10 00
[ 8095.095789] I/O error, dev sdb, sector 4440 op 0x1:(WRITE) flags 0x100000 phys_seg 16 prio class 2
[ 8095.195872] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8095.195884] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8095.195892] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8095.195900] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 70 00 00 48 00
[ 8095.195905] I/O error, dev sdb, sector 4464 op 0x1:(WRITE) flags 0x100000 phys_seg 72 prio class 2
[ 8095.531007] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8095.531023] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8095.531031] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8095.531039] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 c0 00 00 18 00
[ 8095.531045] I/O error, dev sdb, sector 4544 op 0x1:(WRITE) flags 0x100000 phys_seg 24 prio class 2
[ 8104.311727] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8104.311747] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8104.311755] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8104.311764] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 1f 30 00 00 08 00
[ 8104.311770] I/O error, dev sdb, sector 7984 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8104.311790] buffer_io_error: 126 callbacks suppressed
[ 8104.311795] Buffer I/O error on dev sdb1, logical block 5936, lost async page write
[ 8104.311809] Buffer I/O error on dev sdb1, logical block 5937, lost async page write
[ 8104.311818] Buffer I/O error on dev sdb1, logical block 5938, lost async page write
[ 8104.311826] Buffer I/O error on dev sdb1, logical block 5939, lost async page write
[ 8104.311834] Buffer I/O error on dev sdb1, logical block 5940, lost async page write
[ 8104.311842] Buffer I/O error on dev sdb1, logical block 5941, lost async page write
[ 8104.311851] Buffer I/O error on dev sdb1, logical block 5942, lost async page write
[ 8104.311859] Buffer I/O error on dev sdb1, logical block 5943, lost async page write
[ 8117.091538] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8117.091558] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8117.091566] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8117.091576] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 24 b8 00 00 08 00
[ 8117.091581] I/O error, dev sdb, sector 9400 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8117.091600] Buffer I/O error on dev sdb1, logical block 7352, lost async page write
[ 8117.091612] Buffer I/O error on dev sdb1, logical block 7353, lost async page write
[ 8117.091621] Buffer I/O error on dev sdb1, logical block 7354, lost async page write
[ 8117.091629] Buffer I/O error on dev sdb1, logical block 7355, lost async page write
[ 8117.091637] Buffer I/O error on dev sdb1, logical block 7356, lost async page write
[ 8117.091645] Buffer I/O error on dev sdb1, logical block 7357, lost async page write
[ 8117.091653] Buffer I/O error on dev sdb1, logical block 7358, lost async page write
[ 8117.091660] Buffer I/O error on dev sdb1, logical block 7359, lost async page write
[ 8117.295924] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8117.295937] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8117.295944] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8117.295952] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 2f a0 00 00 08 00
[ 8117.295957] I/O error, dev sdb, sector 12192 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8117.295972] Buffer I/O error on dev sdb1, logical block 10144, lost async page write
[ 8117.295983] Buffer I/O error on dev sdb1, logical block 10145, lost async page write
[ 8123.499393] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8123.499413] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8123.499421] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8123.499430] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f a0 00 00 08 00
[ 8123.499436] I/O error, dev sdb, sector 4000 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8123.499455] buffer_io_error: 6 callbacks suppressed
[ 8123.499460] Buffer I/O error on dev sdb1, logical block 1952, lost async page write
[ 8123.499473] Buffer I/O error on dev sdb1, logical block 1953, lost async page write
[ 8123.499481] Buffer I/O error on dev sdb1, logical block 1954, lost async page write
[ 8123.499489] Buffer I/O error on dev sdb1, logical block 1955, lost async page write
[ 8123.499497] Buffer I/O error on dev sdb1, logical block 1956, lost async page write
[ 8123.499505] Buffer I/O error on dev sdb1, logical block 1957, lost async page write
[ 8123.499513] Buffer I/O error on dev sdb1, logical block 1958, lost async page write
[ 8123.499521] Buffer I/O error on dev sdb1, logical block 1959, lost async page write
[ 8123.703794] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8123.703806] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8123.703814] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8123.703822] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 b0 00 00 08 00
[ 8123.703827] I/O error, dev sdb, sector 4272 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8123.703841] Buffer I/O error on dev sdb1, logical block 2224, lost async page write
[ 8123.703852] Buffer I/O error on dev sdb1, logical block 2225, lost async page write
[ 8124.427146] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8124.427164] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8124.427171] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8124.427180] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 1f 30 00 00 08 00
[ 8124.427186] I/O error, dev sdb, sector 7984 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8124.779392] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8124.779411] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8124.779419] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8124.779428] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 20 00 00 00 08 00
[ 8124.779434] I/O error, dev sdb, sector 8192 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8124.859392] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8124.859411] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8124.859419] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8124.859429] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0c 0f a0 00 00 08 00
[ 8124.859435] I/O error, dev sdb, sector 790432 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8166.498880] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8166.498899] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8166.498907] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8166.498916] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f a0 00 00 18 00
[ 8166.498922] I/O error, dev sdb, sector 4000 op 0x1:(WRITE) flags 0x100000 phys_seg 24 prio class 2
[ 8166.498942] buffer_io_error: 30 callbacks suppressed
[ 8166.498947] Buffer I/O error on dev sdb1, logical block 1952, lost async page write
[ 8166.498961] Buffer I/O error on dev sdb1, logical block 1953, lost async page write
[ 8166.498970] Buffer I/O error on dev sdb1, logical block 1954, lost async page write
[ 8166.498978] Buffer I/O error on dev sdb1, logical block 1955, lost async page write
[ 8166.498986] Buffer I/O error on dev sdb1, logical block 1956, lost async page write
[ 8166.498995] Buffer I/O error on dev sdb1, logical block 1957, lost async page write
[ 8166.499003] Buffer I/O error on dev sdb1, logical block 1958, lost async page write
[ 8166.499011] Buffer I/O error on dev sdb1, logical block 1959, lost async page write
[ 8166.499030] Buffer I/O error on dev sdb1, logical block 1960, lost async page write
[ 8166.499038] Buffer I/O error on dev sdb1, logical block 1961, lost async page write
[ 8166.703261] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8166.703280] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8166.703289] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8166.703298] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 1f 30 00 00 08 00
[ 8166.703304] I/O error, dev sdb, sector 7984 op 0x1:(WRITE) flags 0x100000 phys_seg 8 prio class 2
[ 8171.890885] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8171.890902] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8171.890910] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8171.890919] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f b8 00 00 20 00
[ 8171.890925] I/O error, dev sdb, sector 4024 op 0x1:(WRITE) flags 0x100000 phys_seg 32 prio class 2
[ 8171.890944] buffer_io_error: 22 callbacks suppressed
[ 8171.890949] Buffer I/O error on dev sdb1, logical block 1976, lost async page write
[ 8171.890969] Buffer I/O error on dev sdb1, logical block 1977, lost async page write
[ 8171.890978] Buffer I/O error on dev sdb1, logical block 1978, lost async page write
[ 8171.890986] Buffer I/O error on dev sdb1, logical block 1979, lost async page write
[ 8171.890994] Buffer I/O error on dev sdb1, logical block 1980, lost async page write
[ 8171.891002] Buffer I/O error on dev sdb1, logical block 1981, lost async page write
[ 8171.891010] Buffer I/O error on dev sdb1, logical block 1982, lost async page write
[ 8171.891018] Buffer I/O error on dev sdb1, logical block 1983, lost async page write
[ 8171.891036] Buffer I/O error on dev sdb1, logical block 1984, lost async page write
[ 8171.891045] Buffer I/O error on dev sdb1, logical block 1985, lost async page write
[ 8177.375234] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8177.375252] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8177.375260] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8177.375270] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f d8 00 00 28 00
[ 8177.375276] I/O error, dev sdb, sector 4056 op 0x1:(WRITE) flags 0x100000 phys_seg 40 prio class 2
[ 8177.375297] buffer_io_error: 22 callbacks suppressed
[ 8177.375302] Buffer I/O error on dev sdb1, logical block 2008, lost async page write
[ 8177.375317] Buffer I/O error on dev sdb1, logical block 2009, lost async page write
[ 8177.375326] Buffer I/O error on dev sdb1, logical block 2010, lost async page write
[ 8177.375334] Buffer I/O error on dev sdb1, logical block 2011, lost async page write
[ 8177.375343] Buffer I/O error on dev sdb1, logical block 2012, lost async page write
[ 8177.375351] Buffer I/O error on dev sdb1, logical block 2013, lost async page write
[ 8177.375359] Buffer I/O error on dev sdb1, logical block 2014, lost async page write
[ 8177.375367] Buffer I/O error on dev sdb1, logical block 2015, lost async page write
[ 8177.375386] Buffer I/O error on dev sdb1, logical block 2016, lost async page write
[ 8177.375395] Buffer I/O error on dev sdb1, logical block 2017, lost async page write
[ 8182.638723] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8182.638742] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8182.638750] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8182.638759] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 00 00 00 20 00
[ 8182.638765] I/O error, dev sdb, sector 4096 op 0x1:(WRITE) flags 0x100000 phys_seg 32 prio class 2
[ 8182.638786] buffer_io_error: 30 callbacks suppressed
[ 8182.638791] Buffer I/O error on dev sdb1, logical block 2048, lost async page write
[ 8182.638806] Buffer I/O error on dev sdb1, logical block 2049, lost async page write
[ 8182.638815] Buffer I/O error on dev sdb1, logical block 2050, lost async page write
[ 8182.638823] Buffer I/O error on dev sdb1, logical block 2051, lost async page write
[ 8182.638831] Buffer I/O error on dev sdb1, logical block 2052, lost async page write
[ 8182.638839] Buffer I/O error on dev sdb1, logical block 2053, lost async page write
[ 8182.638847] Buffer I/O error on dev sdb1, logical block 2054, lost async page write
[ 8182.638855] Buffer I/O error on dev sdb1, logical block 2055, lost async page write
[ 8182.638873] Buffer I/O error on dev sdb1, logical block 2056, lost async page write
[ 8182.638882] Buffer I/O error on dev sdb1, logical block 2057, lost async page write
[ 8188.639205] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8188.639223] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8188.639231] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8188.639240] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 20 00 00 30 00
[ 8188.639246] I/O error, dev sdb, sector 4128 op 0x1:(WRITE) flags 0x100000 phys_seg 48 prio class 2
[ 8188.639267] buffer_io_error: 22 callbacks suppressed
[ 8188.639272] Buffer I/O error on dev sdb1, logical block 2080, lost async page write
[ 8188.639286] Buffer I/O error on dev sdb1, logical block 2081, lost async page write
[ 8188.639295] Buffer I/O error on dev sdb1, logical block 2082, lost async page write
[ 8188.639303] Buffer I/O error on dev sdb1, logical block 2083, lost async page write
[ 8188.639312] Buffer I/O error on dev sdb1, logical block 2084, lost async page write
[ 8188.639320] Buffer I/O error on dev sdb1, logical block 2085, lost async page write
[ 8188.639328] Buffer I/O error on dev sdb1, logical block 2086, lost async page write
[ 8188.639336] Buffer I/O error on dev sdb1, logical block 2087, lost async page write
[ 8188.639353] Buffer I/O error on dev sdb1, logical block 2088, lost async page write
[ 8188.639362] Buffer I/O error on dev sdb1, logical block 2089, lost async page write
[ 8194.170689] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8194.170707] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8194.170715] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8194.170724] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 50 00 00 28 00
[ 8194.170730] I/O error, dev sdb, sector 4176 op 0x1:(WRITE) flags 0x100000 phys_seg 40 prio class 2
[ 8194.170750] buffer_io_error: 38 callbacks suppressed
[ 8194.170755] Buffer I/O error on dev sdb1, logical block 2128, lost async page write
[ 8194.170769] Buffer I/O error on dev sdb1, logical block 2129, lost async page write
[ 8194.170779] Buffer I/O error on dev sdb1, logical block 2130, lost async page write
[ 8194.170787] Buffer I/O error on dev sdb1, logical block 2131, lost async page write
[ 8194.170795] Buffer I/O error on dev sdb1, logical block 2132, lost async page write
[ 8194.170803] Buffer I/O error on dev sdb1, logical block 2133, lost async page write
[ 8194.170811] Buffer I/O error on dev sdb1, logical block 2134, lost async page write
[ 8194.170819] Buffer I/O error on dev sdb1, logical block 2135, lost async page write
[ 8194.170837] Buffer I/O error on dev sdb1, logical block 2136, lost async page write
[ 8194.170846] Buffer I/O error on dev sdb1, logical block 2137, lost async page write
[ 8199.395055] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8199.395074] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8199.395082] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8199.395092] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 78 00 00 38 00
[ 8199.395098] I/O error, dev sdb, sector 4216 op 0x1:(WRITE) flags 0x100000 phys_seg 56 prio class 2
[ 8199.395118] buffer_io_error: 30 callbacks suppressed
[ 8199.395124] Buffer I/O error on dev sdb1, logical block 2168, lost async page write
[ 8199.395138] Buffer I/O error on dev sdb1, logical block 2169, lost async page write
[ 8199.395147] Buffer I/O error on dev sdb1, logical block 2170, lost async page write
[ 8199.395156] Buffer I/O error on dev sdb1, logical block 2171, lost async page write
[ 8199.395164] Buffer I/O error on dev sdb1, logical block 2172, lost async page write
[ 8199.395172] Buffer I/O error on dev sdb1, logical block 2173, lost async page write
[ 8199.395181] Buffer I/O error on dev sdb1, logical block 2174, lost async page write
[ 8199.395189] Buffer I/O error on dev sdb1, logical block 2175, lost async page write
[ 8199.395206] Buffer I/O error on dev sdb1, logical block 2176, lost async page write
[ 8199.395215] Buffer I/O error on dev sdb1, logical block 2177, lost async page write
[ 8200.117711] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8200.117730] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8200.117740] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8200.117749] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 b8 00 00 b8 00
[ 8200.117755] I/O error, dev sdb, sector 4280 op 0x1:(WRITE) flags 0x100000 phys_seg 184 prio class 2
[ 8205.674391] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8205.674411] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8205.674419] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8205.674429] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 70 00 00 30 00
[ 8205.674436] I/O error, dev sdb, sector 4464 op 0x1:(WRITE) flags 0x100000 phys_seg 48 prio class 2
[ 8205.674456] buffer_io_error: 230 callbacks suppressed
[ 8205.674461] Buffer I/O error on dev sdb1, logical block 2416, lost async page write
[ 8205.674476] Buffer I/O error on dev sdb1, logical block 2417, lost async page write
[ 8205.674485] Buffer I/O error on dev sdb1, logical block 2418, lost async page write
[ 8205.674493] Buffer I/O error on dev sdb1, logical block 2419, lost async page write
[ 8205.674501] Buffer I/O error on dev sdb1, logical block 2420, lost async page write
[ 8205.674509] Buffer I/O error on dev sdb1, logical block 2421, lost async page write
[ 8205.674517] Buffer I/O error on dev sdb1, logical block 2422, lost async page write
[ 8205.674526] Buffer I/O error on dev sdb1, logical block 2423, lost async page write
[ 8205.674543] Buffer I/O error on dev sdb1, logical block 2424, lost async page write
[ 8205.674551] Buffer I/O error on dev sdb1, logical block 2425, lost async page write
[ 8211.166859] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8211.166879] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8211.166887] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8211.166896] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 a0 00 00 20 00
[ 8211.166902] I/O error, dev sdb, sector 4512 op 0x1:(WRITE) flags 0x100000 phys_seg 32 prio class 2
[ 8211.166921] buffer_io_error: 38 callbacks suppressed
[ 8211.166926] Buffer I/O error on dev sdb1, logical block 2464, lost async page write
[ 8211.166940] Buffer I/O error on dev sdb1, logical block 2465, lost async page write
[ 8211.166948] Buffer I/O error on dev sdb1, logical block 2466, lost async page write
[ 8211.166956] Buffer I/O error on dev sdb1, logical block 2467, lost async page write
[ 8211.166964] Buffer I/O error on dev sdb1, logical block 2468, lost async page write
[ 8211.166972] Buffer I/O error on dev sdb1, logical block 2469, lost async page write
[ 8211.166980] Buffer I/O error on dev sdb1, logical block 2470, lost async page write
[ 8211.166988] Buffer I/O error on dev sdb1, logical block 2471, lost async page write
[ 8211.167001] Buffer I/O error on dev sdb1, logical block 2472, lost async page write
[ 8211.167010] Buffer I/O error on dev sdb1, logical block 2473, lost async page write
[ 8214.902362] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8214.902379] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8214.902388] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8214.902397] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 08 08 00 00 08 00
[ 8214.902403] I/O error, dev sdb, sector 2056 op 0x1:(WRITE) flags 0x800 phys_seg 8 prio class 2
[ 8215.106848] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8215.106865] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8215.106873] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8215.106883] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 0f 90 00 00 10 00
[ 8215.106888] I/O error, dev sdb, sector 3984 op 0x1:(WRITE) flags 0x800 phys_seg 16 prio class 2
[ 8215.828844] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8215.828863] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8215.828871] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8215.828880] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 10 b0 00 00 08 00
[ 8215.828886] I/O error, dev sdb, sector 4272 op 0x1:(WRITE) flags 0x800 phys_seg 8 prio class 2
[ 8216.182354] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8216.182370] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8216.182378] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8216.182387] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 11 c0 00 00 18 00
[ 8216.182392] I/O error, dev sdb, sector 4544 op 0x1:(WRITE) flags 0x800 phys_seg 24 prio class 2
[ 8216.182409] buffer_io_error: 54 callbacks suppressed
[ 8216.182414] Buffer I/O error on dev sdb1, logical block 2496, lost async page write
[ 8216.182428] Buffer I/O error on dev sdb1, logical block 2497, lost async page write
[ 8216.182437] Buffer I/O error on dev sdb1, logical block 2498, lost async page write
[ 8216.182445] Buffer I/O error on dev sdb1, logical block 2499, lost async page write
[ 8216.182453] Buffer I/O error on dev sdb1, logical block 2500, lost async page write
[ 8216.182461] Buffer I/O error on dev sdb1, logical block 2501, lost async page write
[ 8216.182469] Buffer I/O error on dev sdb1, logical block 2502, lost async page write
[ 8216.182477] Buffer I/O error on dev sdb1, logical block 2503, lost async page write
[ 8216.182492] Buffer I/O error on dev sdb1, logical block 2504, lost async page write
[ 8216.182501] Buffer I/O error on dev sdb1, logical block 2505, lost async page write
[ 8216.262328] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8216.262341] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8216.262349] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8216.262357] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 00 20 00 00 00 18 00
[ 8216.262363] I/O error, dev sdb, sector 8192 op 0x1:(WRITE) flags 0x800 phys_seg 24 prio class 2
[ 8216.979101] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8216.979119] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8216.979127] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8216.979136] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 04 0f 90 00 00 10 00
[ 8216.979141] I/O error, dev sdb, sector 266128 op 0x1:(WRITE) flags 0x800 phys_seg 16 prio class 2
[ 8217.462221] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8217.462237] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8217.462245] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8217.462254] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 08 08 00 00 00 10 00
[ 8217.462260] I/O error, dev sdb, sector 526336 op 0x1:(WRITE) flags 0x800 phys_seg 16 prio class 2
[ 8217.542199] sd 4:0:0:0: [sdb] tag#0 FAILED Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK cmd_age=0s
[ 8217.542212] sd 4:0:0:0: [sdb] tag#0 Sense Key : Hardware Error [current]
[ 8217.542219] sd 4:0:0:0: [sdb] tag#0 Add. Sense: No additional sense information
[ 8217.542227] sd 4:0:0:0: [sdb] tag#0 CDB: Write(10) 2a 00 00 0c 0f 90 00 00 18 00
[ 8217.542232] I/O error, dev sdb, sector 790416 op 0x1:(WRITE) flags 0x800 phys_seg 24 prio class 2
Then i tried to format sdb1 instead:
root@FM2:~# mkfs.ext2 -F -F /dev/sdb1
Creating filesystem with 986328 4k blocks and 247008 inodes
Filesystem UUID: 72145872-7a20-43f8-9077-126fbe0ad797
Superblock backups stored on blocks:
	32768, 98304, 163840, 229376, 294912, 819200, 884736
Allocating group tables: done
Writing inode tables: done
Writing superblocks and filesystem accounting information: mkfs.ext2: Input/output error while writing out and closing file system
But still nothing
#5 2023-05-19 11:36:40
soren
Re: usb pendrive always mounted as read-only
Wipe the device fully and try again.
Install gdisk and parted - sudo apt install gdisk parted
I would do this in a terminal as root user and see if it still has input/output errors.
sudo wipefs --all /dev/sdb
sudo gdisk -z /dev/sdb
sudo parted /dev/sdb mklabel msdos
sudo parted -a opt /dev/sdb mkpart primary ext2 0% 100%
sudo mkfs.ext2 -c /dev/sdb1
#6 2023-05-27 21:28:10
Panda1100
Hello again:
root@FM2:/home/francesco/errore_chiavetta# sudo wipefs --all /dev/sdb
/dev/sdb: 2 bytes were erased at offset 0x000001fe (dos): 55 aa
/dev/sdb: 8 bytes were erased at offset 0xf0fffe00 (gpt): 45 46 49 20 50 41 52 54
/dev/sdb: calling ioctl to re-read partition table: Success
root@FM2:/home/francesco/errore_chiavetta# sudo gdisk -z /dev/sdb
GPT fdisk (gdisk) version 1.0.9
Usage: gdisk [-l] device_file
root@FM2:/home/francesco/errore_chiavetta# parted /dev/sdb mklabel msdos
Warning: The existing disk label on /dev/sdb will be destroyed and all data on
this disk will be lost. Do you want to continue?
Yes/No? yes
Error: Input/output error during write on /dev/sdb
Retry/Ignore/Cancel? retry
Information: You may need to update /etc/fstab.
root@FM2:/home/francesco/errore_chiavetta# parted -a opt /dev/sdb mkpart primary ext2 0% 100%
Warning: You requested a partition from 0,00B to 4043MB (sectors 0..7897087).
The closest location we can manage is 512B to 1048kB (sectors 1..2047).
Is this still acceptable to you?
Yes/No? yes
Warning: The resulting partition is not properly aligned for best performance:
1s % 2048s != 0s
Ignore/Cancel? ignore
root@FM2:/home/francesco/errore_chiavetta# mkfs.ext2 -c /dev/sdb1
mke2fs 1.47.0 (5-Feb-2023)
/dev/sdb1 contains a ext2 file system
	last mounted on /media/francesco/eacdf0bc-d9fc-4ec0-a7ea-6bc2543a86c8 on Mon May 15 21:04:13 2023
Proceed anyway? (y,N) y
Filesystem UUID: ff5c5025-b048-46ab-a759-8075451804b1
Checking for bad blocks (read-only test):   0.00% done, 0:00 elapsed. (0/0/0 errors)##########################################  0.25% done, 0:01 elapsed. (0/0/0 errors)##########################################  0.58% done, 0:02 elapsed. (0/0/0 errors)##########################################  0.92% done, 0:03 elapsed. (0/0/0 errors)##########################################  1.27% done, 0:04 elapsed. (0/0/0 errors)##########################################  1.61% done, 0:05 elapsed. (0/0/0 errors)##########################################  1.98% done, 0:06 elapsed. (0/0/0 errors)##########################################  2.34% done, 0:07 elapsed. (0/0/0 errors)##########################################  2.70% done, 0:08 elapsed. (0/0/0 errors)##########################################  3.06% done, 0:09 elapsed. (0/0/0 errors)##########################################  3.43% done, 0:10 elapsed. (0/0/0 errors)##########################################  3.78% done, 0:11 elapsed. (0/0/0 errors)##########################################  4.11% done, 0:12 elapsed. (0/0/0 errors)##########################################  4.46% done, 0:13 elapsed. (0/0/0 errors)##########################################  4.82% done, 0:14 elapsed. (0/0/0 errors)##########################################  5.18% done, 0:15 elapsed. (0/0/0 errors)##########################################  5.54% done, 0:16 elapsed. (0/0/0 errors)##########################################  5.90% done, 0:17 elapsed. (0/0/0 errors)##########################################  6.26% done, 0:19 elapsed. (0/0/0 errors)##########################################  6.62% done, 0:20 elapsed. (0/0/0 errors)##########################################  6.97% done, 0:21 elapsed. (0/0/0 errors)##########################################  7.27% done, 0:22 elapsed. (0/0/0 errors)##########################################  7.61% done, 0:23 elapsed. (0/0/0 errors)##########################################  7.93% done, 0:24 elapsed. (0/0/0 errors)##########################################  8.25% done, 0:25 elapsed. (0/0/0 errors)##########################################  8.56% done, 0:26 elapsed. (0/0/0 errors)##########################################  8.86% done, 0:27 elapsed. (0/0/0 errors)##########################################  9.18% done, 0:28 elapsed. (0/0/0 errors)##########################################  9.48% done, 0:29 elapsed. (0/0/0 errors)##########################################  9.78% done, 0:30 elapsed. (0/0/0 errors)########################################## 10.12% done, 0:31 elapsed. (0/0/0 errors)########################################## 10.45% done, 0:32 elapsed. (0/0/0 errors)########################################## 10.60% done, 0:33 elapsed. (0/0/0 errors)########################################## 10.95% done, 0:34 elapsed. (0/0/0 errors)########################################## 11.34% done, 0:35 elapsed. (0/0/0 errors)########################################## 11.76% done, 0:36 elapsed. (0/0/0 errors)########################################## 12.14% done, 0:37 elapsed. (0/0/0 errors)########################################## 12.48% done, 0:38 elapsed. (0/0/0 errors)########################################## 12.65% done, 0:39 elapsed. (0/0/0 errors)########################################## 13.11% done, 0:40 elapsed. (0/0/0 errors)########################################## 13.57% done, 0:41 elapsed. (0/0/0 errors)########################################## 14.04% done, 0:42 elapsed. (0/0/0 errors)########################################## 14.49% done, 0:43 elapsed. (0/0/0 errors)########################################## 14.95% done, 0:44 elapsed. (0/0/0 errors)########################################## 15.41% done, 0:45 elapsed. (0/0/0 errors)########################################## 15.87% done, 0:46 elapsed. (0/0/0 errors)########################################## 16.33% done, 0:47 elapsed. (0/0/0 errors)########################################## 16.79% done, 0:48 elapsed. (0/0/0 errors)########################################## 17.25% done, 0:49 elapsed. (0/0/0 errors)########################################## 17.71% done, 0:50 elapsed. (0/0/0 errors)########################################## 18.17% done, 0:51 elapsed. (0/0/0 errors)########################################## 18.62% done, 0:52 elapsed. (0/0/0 errors)########################################## 19.08% done, 0:53 elapsed. (0/0/0 errors)########################################## 19.54% done, 0:54 elapsed. (0/0/0 errors)########################################## 20.00% done, 0:55 elapsed. (0/0/0 errors)########################################## 20.47% done, 0:56 elapsed. (0/0/0 errors)########################################## 20.93% done, 0:57 elapsed. (0/0/0 errors)########################################## 21.39% done, 0:58 elapsed. (0/0/0 errors)########################################## 21.85% done, 0:59 elapsed. (0/0/0 errors)########################################## 22.31% done, 1:00 elapsed. (0/0/0 errors)########################################## 22.77% done, 1:01 elapsed. (0/0/0 errors)########################################## 23.23% done, 1:02 elapsed. (0/0/0 errors)########################################## 23.69% done, 1:03 elapsed. (0/0/0 errors)########################################## 24.15% done, 1:04 elapsed. (0/0/0 errors)########################################## 24.61% done, 1:05 elapsed. (0/0/0 errors)########################################## 25.01% done, 1:06 elapsed. (0/0/0 errors)########################################## 25.46% done, 1:07 elapsed. (0/0/0 errors)########################################## 25.92% done, 1:08 elapsed. (0/0/0 errors)########################################## 26.38% done, 1:09 elapsed. (0/0/0 errors)########################################## 26.83% done, 1:10 elapsed. (0/0/0 errors)########################################## 27.29% done, 1:11 elapsed. (0/0/0 errors)########################################## 27.75% done, 1:12 elapsed. (0/0/0 errors)########################################## 28.21% done, 1:13 elapsed. (0/0/0 errors)########################################## 28.67% done, 1:14 elapsed. (0/0/0 errors)########################################## 29.13% done, 1:15 elapsed. (0/0/0 errors)########################################## 29.60% done, 1:16 elapsed. (0/0/0 errors)########################################## 30.05% done, 1:17 elapsed. (0/0/0 errors)########################################## 30.51% done, 1:18 elapsed. (0/0/0 errors)########################################## 30.97% done, 1:19 elapsed. (0/0/0 errors)########################################## 31.43% done, 1:20 elapsed. (0/0/0 errors)########################################## 31.89% done, 1:21 elapsed. (0/0/0 errors)########################################## 32.35% done, 1:22 elapsed. (0/0/0 errors)########################################## 32.81% done, 1:23 elapsed. (0/0/0 errors)########################################## 33.27% done, 1:24 elapsed. (0/0/0 errors)########################################## 33.72% done, 1:25 elapsed. (0/0/0 errors)########################################## 34.18% done, 1:26 elapsed. (0/0/0 errors)########################################## 34.63% done, 1:27 elapsed. (0/0/0 errors)########################################## 35.09% done, 1:28 elapsed. (0/0/0 errors)########################################## 35.55% done, 1:29 elapsed. (0/0/0 errors)########################################## 36.01% done, 1:30 elapsed. (0/0/0 errors)########################################## 36.47% done, 1:31 elapsed. (0/0/0 errors)########################################## 36.92% done, 1:32 elapsed. (0/0/0 errors)########################################## 37.38% done, 1:33 elapsed. (0/0/0 errors)########################################## 37.78% done, 1:34 elapsed. (0/0/0 errors)########################################## 38.23% done, 1:35 elapsed. (0/0/0 errors)########################################## 38.68% done, 1:36 elapsed. (0/0/0 errors)########################################## 39.14% done, 1:37 elapsed. (0/0/0 errors)########################################## 39.59% done, 1:38 elapsed. (0/0/0 errors)########################################## 40.05% done, 1:39 elapsed. (0/0/0 errors)########################################## 40.50% done, 1:40 elapsed. (0/0/0 errors)########################################## 40.96% done, 1:41 elapsed. (0/0/0 errors)########################################## 41.42% done, 1:42 elapsed. (0/0/0 errors)########################################## 41.87% done, 1:43 elapsed. (0/0/0 errors)########################################## 42.33% done, 1:44 elapsed. (0/0/0 errors)########################################## 42.79% done, 1:46 elapsed. (0/0/0 errors)########################################## 43.24% done, 1:47 elapsed. (0/0/0 errors)########################################## 43.56% done, 1:48 elapsed. (0/0/0 errors)########################################## 44.01% done, 1:49 elapsed. (0/0/0 errors)########################################## 44.47% done, 1:50 elapsed. (0/0/0 errors)########################################## 44.87% done, 1:51 elapsed. (0/0/0 errors)########################################## 45.32% done, 1:52 elapsed. (0/0/0 errors)########################################## 45.78% done, 1:53 elapsed. (0/0/0 errors)########################################## 46.24% done, 1:54 elapsed. (0/0/0 errors)########################################## 46.69% done, 1:55 elapsed. (0/0/0 errors)########################################## 47.15% done, 1:56 elapsed. (0/0/0 errors)########################################## 47.61% done, 1:57 elapsed. (0/0/0 errors)########################################## 48.07% done, 1:58 elapsed. (0/0/0 errors)########################################## 48.54% done, 1:59 elapsed. (0/0/0
 errors)########################################## 49.00% done, 2:00 elapsed. (0/0/0 errors)########################################## 49.46% done, 2:01 elapsed. (0/0/0 errors)########################################## 49.92% done, 2:02 elapsed. (0/0/0 errors)########################################## 50.31% done, 2:03 elapsed. (0/0/0 errors)########################################## 50.77% done, 2:04 elapsed. (0/0/0 errors)########################################## 50.94% done, 2:05 elapsed. (0/0/0 errors)########################################## 51.40% done, 2:06 elapsed. (0/0/0 errors)########################################## 51.86% done, 2:07 elapsed. (0/0/0 errors)########################################## 52.32% done, 2:08 elapsed. (0/0/0 errors)########################################## 52.78% done, 2:09 elapsed. (0/0/0 errors)########################################## 53.23% done, 2:10 elapsed. (0/0/0 errors)########################################## 53.69% done, 2:11 elapsed. (0/0/0 errors)########################################## 54.15% done, 2:12 elapsed. (0/0/0 errors)########################################## 54.61% done, 2:13 elapsed. (0/0/0 errors)########################################## 55.07% done, 2:14 elapsed. (0/0/0 errors)########################################## 55.53% done, 2:15 elapsed. (0/0/0 errors)########################################## 55.99% done, 2:16 elapsed. (0/0/0 errors)########################################## 56.45% done, 2:17 elapsed. (0/0/0 errors)########################################## 56.91% done, 2:18 elapsed. (0/0/0 errors)########################################## 57.33% done, 2:20 elapsed. (0/0/0 errors)########################################## 57.79% done, 2:21 elapsed. (0/0/0 errors)########################################## 58.24% done, 2:22 elapsed. (0/0/0 errors)########################################## 58.70% done, 2:23 elapsed. (0/0/0 errors)########################################## 59.16% done, 2:24 elapsed. (0/0/0 errors)########################################## 59.62% done, 2:25 elapsed. (0/0/0 errors)########################################## 60.09% done, 2:26 elapsed. (0/0/0 errors)########################################## 60.55% done, 2:27 elapsed. (0/0/0 errors)########################################## 61.01% done, 2:28 elapsed. (0/0/0 errors)########################################## 61.46% done, 2:29 elapsed. (0/0/0 errors)########################################## 61.92% done, 2:30 elapsed. (0/0/0 errors)########################################## 62.38% done, 2:31 elapsed. (0/0/0 errors)########################################## 62.77% done, 2:32 elapsed. (0/0/0 errors)########################################## 63.23% done, 2:33 elapsed. (0/0/0 errors)########################################## 63.68% done, 2:34 elapsed. (0/0/0 errors)########################################## 63.95% done, 2:35 elapsed. (0/0/0 errors)########################################## 64.28% done, 2:36 elapsed. (0/0/0 errors)########################################## 64.74% done, 2:37 elapsed. (0/0/0 errors)########################################## 65.20% done, 2:38 elapsed. (0/0/0 errors)########################################## 65.65% done, 2:39 elapsed. (0/0/0 errors)########################################## 66.11% done, 2:40 elapsed. (0/0/0 errors)########################################## 66.57% done, 2:41 elapsed. (0/0/0 errors)########################################## 67.02% done, 2:42 elapsed. (0/0/0 errors)########################################## 67.48% done, 2:43 elapsed. (0/0/0 errors)########################################## 67.93% done, 2:44 elapsed. (0/0/0 errors)########################################## 68.38% done, 2:45 elapsed. (0/0/0 errors)########################################## 68.84% done, 2:46 elapsed. (0/0/0 errors)########################################## 69.29% done, 2:47 elapsed. (0/0/0 errors)########################################## 69.75% done, 2:48 elapsed. (0/0/0 errors)########################################## 70.21% done, 2:49 elapsed. (0/0/0 errors)########################################## 70.67% done, 2:50 elapsed. (0/0/0 errors)########################################## 71.12% done, 2:51 elapsed. (0/0/0 errors)########################################## 71.58% done, 2:52 elapsed. (0/0/0 errors)########################################## 72.04% done, 2:53 elapsed. (0/0/0 errors)########################################## 72.50% done, 2:54 elapsed. (0/0/0 errors)########################################## 72.96% done, 2:55 elapsed. (0/0/0 errors)########################################## 73.42% done, 2:56 elapsed. (0/0/0 errors)########################################## 73.87% done, 2:57 elapsed. (0/0/0 errors)########################################## 74.33% done, 2:58 elapsed. (0/0/0 errors)########################################## 74.79% done, 2:59 elapsed. (0/0/0 errors)########################################## 75.18% done, 3:00 elapsed. (0/0/0 errors)########################################## 75.65% done, 3:01 elapsed. (0/0/0 errors)########################################## 76.10% done, 3:02 elapsed. (0/0/0 errors)########################################## 76.55% done, 3:03 elapsed. (0/0/0 errors)########################################## 77.01% done, 3:04 elapsed. (0/0/0 errors)########################################## 77.47% done, 3:06 elapsed. (0/0/0 errors)########################################## 77.93% done, 3:07 elapsed. (0/0/0 errors)########################################## 78.38% done, 3:08 elapsed. (0/0/0 errors)########################################## 78.84% done, 3:09 elapsed. (0/0/0 errors)########################################## 79.30% done, 3:10 elapsed. (0/0/0 errors)########################################## 79.76% done, 3:11 elapsed. (0/0/0 errors)########################################## 80.22% done, 3:12 elapsed. (0/0/0 errors)########################################## 80.67% done, 3:13 elapsed. (0/0/0 errors)########################################## 81.13% done, 3:14 elapsed. (0/0/0 errors)########################################## 81.59% done, 3:15 elapsed. (0/0/0 errors)########################################## 82.04% done, 3:16 elapsed. (0/0/0 errors)########################################## 82.50% done, 3:17 elapsed. (0/0/0 errors)########################################## 82.96% done, 3:18 elapsed. (0/0/0 errors)########################################## 83.43% done, 3:19 elapsed. (0/0/0 errors)########################################## 83.89% done, 3:20 elapsed. (0/0/0 errors)########################################## 84.35% done, 3:21 elapsed. (0/0/0 errors)########################################## 84.80% done, 3:22 elapsed. (0/0/0 errors)########################################## 85.26% done, 3:23 elapsed. (0/0/0 errors)########################################## 85.72% done, 3:24 elapsed. (0/0/0 errors)########################################## 86.18% done, 3:25 elapsed. (0/0/0 errors)########################################## 86.63% done, 3:26 elapsed. (0/0/0 errors)########################################## 87.09% done, 3:27 elapsed. (0/0/0 errors)########################################## 87.54% done, 3:28 elapsed. (0/0/0 errors)########################################## 87.71% done, 3:29 elapsed. (0/0/0 errors)########################################## 88.17% done, 3:30 elapsed. (0/0/0 errors)########################################## 88.62% done, 3:31 elapsed. (0/0/0 errors)########################################## 89.08% done, 3:32 elapsed. (0/0/0 errors)########################################## 89.54% done, 3:33 elapsed. (0/0/0 errors)########################################## 90.00% done, 3:34 elapsed. (0/0/0 errors)########################################## 90.46% done, 3:35 elapsed. (0/0/0 errors)########################################## 90.92% done, 3:36 elapsed. (0/0/0 errors)########################################## 91.37% done, 3:37 elapsed. (0/0/0 errors)########################################## 91.83% done, 3:38 elapsed. (0/0/0 errors)########################################## 92.29% done, 3:39 elapsed. (0/0/0 errors)########################################## 92.74% done, 3:40 elapsed. (0/0/0 errors)########################################## 93.20% done, 3:41 elapsed. (0/0/0 errors)########################################## 93.66% done, 3:42 elapsed. (0/0/0 errors)########################################## 94.11% done, 3:43 elapsed. (0/0/0 errors)########################################## 94.57% done, 3:44 elapsed. (0/0/0 errors)########################################## 95.02% done, 3:45 elapsed. (0/0/0 errors)########################################## 95.48% done, 3:46 elapsed. (0/0/0 errors)########################################## 95.94% done, 3:47 elapsed. (0/0/0 errors)########################################## 96.40% done, 3:48 elapsed. (0/0/0 errors)########################################## 96.86% done, 3:49 elapsed. (0/0/0 errors)########################################## 97.32% done, 3:50 elapsed. (0/0/0 errors)########################################## 97.78% done, 3:51 elapsed. (0/0/0 errors)########################################## 98.24% done, 3:52 elapsed. (0/0/0 errors)########################################## 98.70% done, 3:53 elapsed. (0/0/0 errors)########################################## 99.15% done, 3:54 elapsed. (0/0/0 errors)########################################## 99.61% done, 3:55 elapsed. (0/0/0 errors)########################################## 99.95% done, 3:56 elapsed. (0/0/0 errors)##########################################done
Allocating group tables:  0/31#####     #####done
Writing inode tables:  0/31##### 1/31##### 2/31##### 3/31##### 4/31##### 5/31##### 6/31##### 7/31##### 8/31#####10/31#####11/31#####13/31#####15/31#####16/31#####18/31#####20/31#####21/31#####23/31#####25/31#####26/31#####28/31#####29/31#####     #####done
Writing superblocks and filesystem accounting information:  0/31#####     #####mkfs.ext2: Input/output error while writing out and closing file system
#7 2023-05-28 06:51:50
Sounds like a defective hardware to me. Either the pendrive itself, the USB jack on the computer or something inbetween you may have used.
#8 2023-05-29 20:13:59
entropyagent
I don't have any actual *knowledge* to offer, but perhaps I could fling some comments at the wall?
Do both the pendrives give that "Input/output error while closing the filesystem" ? Such a message could lead a suspicious person to suspect that the drive is failing. Admittedly it seems unlikely that 2 drives would fail at the same time, but perhaps if they were from the same batch, e.g. bought in the same blister pack? Then again....2 months apart is not exactly "the same time"
I tend to take the idea of a hardware failure as a personal insult, especially if it is something I paid my own actual money for. But it does happen sometimes. You might save yourself a lot of pain if you can accept the loss and beg/buy/borrow/steal another drive?
Is there a chance you could try with another kernel, perhaps an older one?
Another desperate clutching at straw: could it be a power issue, with something power-hungry using the usb bus? do you have a powered usb hub available for experimentation?
Could the usb socket be experiencing mechanical stress, perhaps with the laptop on a nonlevel surface (such as, to pick a random example, a lap) and the flashdrive sticking out of the side, brushing against couch cushions or blankets? Or perhaps you have the "bulky devices in slots that are too close together" problem? Perhaps you have another computer available for experimentation.
OK, getting more desperate....how is your environment for static electricity?
Good luck.
#9 2023-05-30 00:00:09
entropyagent wrote:
... idea of a hardware failure as a personal insult, especially if it is something I paid my own actual money for.
Indeed ...
But it happens and there can be quite a few reasons.
From crappy memory chips in cheap USB sticks to counterfit Kingston USB drives to faulty/dirty USB sockets.
entropyagent wrote:
... accept the loss and beg/buy/borrow/steal another drive?
I would first try the (apparently) offending drive on a different host. ie: another PC, laptop, RPi, whatever you have available.
Boot to a terminal and do a command line nuke of the thing, a thorough clean-up via dd.
Once that is done, attempt the same operation you had problems with and check the result.
If the problem subsists, the drive is bad.
If the operation was successful, repeat the whole process to rule out a fluke.
The first thing is to rule out a hardware fault.
In my experience, the usual suspects are the USB stick and then, if using a portable, the USB socket.
A few years ago I chased USB stick issues for over two days till I discovered an intermittently failing USB socket in my Asus 1000HE.
#10 2025-11-10 20:27:07
Panda1100
(still two years ago) I entered in the computer's bios and then I turned off usb charging. From then pendrives (those I didn't plug yet) work perfectly. I guess the bios usb charging overpowered the drives damaging them.
#11 2025-11-10 21:39:19
Welcome back ...
I was wondering what happened to your USB sticks. 8^°
Panda1100 wrote:
... bios ...
... turned off usb charging.
Hmm ...
Could be, but then it would imply a severe hardware malfunction or BIOS problem.
USB ports have (should have) protection to avoid excess current draw and damage, particularly those that can be used for charging.
It is part of the design parameters of any on-board / external USB socket.
Panda1100 wrote:
... (those I didn't plug yet) work perfectly.
I see.
For the sake of completion to this thread, I think that it would be of interest to the forum (and you) to know some details.
[please humour me]
Reason?
Although not by any means the same quality of the legendary IBM T43 Thinkpad, today's Lenovo Thinkpad T400 is not a toy laptop on which such a thing would just happen, so it would be good to check a couple of things which may be of interest.
What brand and model are the USB sticks you used before and use now?
What does the dmesg printout say after you plug in one of the non-functioning sticks?
Please post the output.
With that same stick plugged in, please bring up gparted.
Does the stick show up? ie: /dev/sdx
If so, can you format it to 'cleared' first and then to 'fat32'?
Let's see if we can get to the bottom of this within a reasonable time frame.  8^D!
