#1 2023-04-27 21:25:58
James1138
What is the maximum USB capacity Devuan can use?
I am planning to backup my data (docs, music, video, etc.) offline using USB drives since I travel quite a bit nowadays and do not always have access to internet/cloud storage and rather not carry bulky extra external SSD (bulky compared to USB drives in terms of weight and size).
So far I found no problem with generic 128 gb drives - but wondered what is the maximum capacity (256gb, 512gb)?
On a related note - other that GPARTED or GNOME Disk Manager... any suggestions on any other software that just format USB?
James
Indiana
#2 2023-04-28 08:12:52
alexkemp
Re: What is the maximum USB capacity Devuan can use?
I've got two drives that are USB-connected HDD:
  1. Seagate 2TB portable
    (this is formatted using standard Linux utilities to (so-called) FAT64 (HPFS/NTFS/exFAT: max 2TB))
  2. WD (Western Digital) 4TB portable ("My Passport")
    (this is native M$ format ("Microsoft basic data") and I cannot find a linux utility that can format and/or repair it to it's current state)
The advantage of the former is that it is ubiquitous across many different OS. As an example, my ancient Samsung TV can read & play movies from (1), but not (2).
The advantage of (2) is that it can store above the 2TB threshold. Also, astonishing that I may need it to. I left the disk in it's supplied format since that can be read by more OS than a native Linux format.
As long as you have a 64-bit cpu then (as I understand it) either disk can be read up to the max of the cpu (which I cannot recall as I sit here, but much, much more than 4TB).
#3 2023-04-28 08:25:24
If you don't want to carry a 2.5" USB disk drive, you might like to try using an M2 SSD in an external USB case (approx 3.75" x 1.5" x 0.25") & more reliable than a pendrive.
With regards to setting up disks, I just use fdisk on the command line.
Good to know that you have had good experiences with generic 128GB pendrives, as I have just ordered 3x to try out with/on my thin client desktops. smile
