#1 2023-04-04 13:40:34
webman
XFCE4 config on devuan - differences to debian
Hello!
I am looking to understand, where to configure XFCE4 to behave the same as on my debian (bullseye).
At least two things matter:
- dialogs are not resizable
- cannot switch user (logging in parallel with a second user).
Can someone probably shed some light onto this?
Thanks,
Manfred
#2 2023-04-04 16:39:55
Andre4freedom
Re: XFCE4 config on devuan - differences to debian
webman, I'm not aware of what version of Devuan you use.....
but, by default the selection of xfce4 desktop environment installs slim as display-manager.
Just install lightdm instead --- and you will be able to switch users.
(Use sysnaptic or apt install lightdm to install and answer the questions sensibly)
Good luck
#3 2023-04-09 11:13:12
webman
Thank you!
This may be it.
I'll try it out!
#4 2023-08-04 17:49:01
danuan
LightDM installs are broken most of the time for me and do not auto select greeter (lightdm-gtk-greeter)
Make sure lightdm install grabs that package
