#1 2023-03-28 00:43:00
spikemcc
Refracta tools on Debian issue
Seem like refracta-snapshot make an iso with the user/password of the 1st user of the setup even when used on a second user ...
#2 2023-03-28 12:26:26
Re: Refracta tools on Debian issue
Both accounts should have been copied into the iso, but the default setting is to boot to the primary user (uid:gid 1000:1000).
To boot to the other user with the iso you already made, edit the boot screen to add username=<whatever the other user's name is>
(Press TAB to edit bios boot menu, press e to edit uefi boot menu)
To make an iso that  boots to the second user by default, edit /etc/refractasnapshot.conf to set the desired username.
