#1 2023-03-14 19:26:07
rmcg
Bluetooth Install Problem on Chimaera
Chimaera thinkpadl520 5.10.0-21-amd64 #1 SMP Debian 5.10.162-1 (2023-01-21) x86_64 GNU/Linux
Using sys-v init
install  sudo apt install bluetooth
 bluez : Depends: dbus but it is not installable
E: Unable to correct problems, you have held broken packages
#2 2023-03-15 00:11:37
Re: Bluetooth Install Problem on Chimaera
What's the output of apt-cache policy dbus for you?
#3 2023-03-15 04:35:28
rmcg
Thanks for the input:-) here is my
dbus:
  Installed: (none)
  Candidate: (none)
  Version table:
     1.12.24-0+deb11u1devuan1 -1
        500 https://ftp.fau.de/devuan/merged chimaera/main amd64 Packages
#4 2023-03-15 05:12:24
Fair enough. You haven't said there is an issue.
You merely show that with apt preferences set up so as to not install dbus, then apt will not install anything that declares it depends on dbus.
#5 2023-03-15 05:51:41
rmcg
My issue is that I was unaware that apt my preferences are set up so as to not install dbus, I'm running a Devuan derivative - Forge OS so part of the learning curve for me.
#6 2023-03-15 05:52:14
rmcg
Thanks for the help.
