#1 2023-02-28 15:06:02
kapqa
(chimaera) samba, gvfs install > fuse deinstall?
Hello ,
tried to install samba & smbclient to have better network integration on devuan xfce 4.0,
but i noticed that the package "fuse" is being deinstalled.
My question: will this create problems?
is this package not necessary?
thanks.
sudo apt install samba smbclient gvfs*
[sudo] password for rich:
Note, selecting 'gvfs-bin' for glob 'gvfs*'
Note, selecting 'gvfs-fuse' for glob 'gvfs*'
Note, selecting 'gvfs-common' for glob 'gvfs*'
Note, selecting 'gvfs-libs' for glob 'gvfs*'
Note, selecting 'gvfs-backends' for glob 'gvfs*'
Note, selecting 'gvfs' for glob 'gvfs*'
Note, selecting 'gvfs-daemons' for glob 'gvfs*'
gvfs is already the newest version (1.46.2-1).
gvfs set to manually installed.
gvfs-backends is already the newest version (1.46.2-1).
gvfs-backends set to manually installed.
gvfs-common is already the newest version (1.46.2-1).
gvfs-common set to manually installed.
gvfs-daemons is already the newest version (1.46.2-1).
gvfs-daemons set to manually installed.
gvfs-libs is already the newest version (1.46.2-1).
gvfs-libs set to manually installed.
  attr fuse3 ibverbs-providers libcephfs2 libfuse3-3 libgfapi0 libgfrpc0
  libgfxdr0 libglusterfs0 libibverbs1 librados2 librdmacm1 liburing1
  python3-samba python3-tdb samba-common samba-common-bin samba-dsdb-modules
  samba-vfs-modules tdb-tools
Suggested packages:
  bind9 bind9utils ctdb ldb-tools ntp | chrony smbldap-tools ufw winbind
  heimdal-clients cifs-utils
  fuse
  attr fuse3 gvfs-bin gvfs-fuse ibverbs-providers libcephfs2 libfuse3-3
  libgfapi0 libgfrpc0 libgfxdr0 libglusterfs0 libibverbs1 librados2 librdmacm1
  liburing1 python3-samba python3-tdb samba samba-common samba-common-bin
  samba-dsdb-modules samba-vfs-modules smbclient tdb-tools
0 upgraded, 24 newly installed, 1 to remove and 3 not upgraded.
Need to get 22.9 MB of archives.
After this operation, 76.3 MB of additional disk space will be used.
Get:1 http://deb.devuan.org/merged chimaera/main amd64 libfuse3-3 amd64 3.10.3-2 [85.3 kB]
Get:2 http://deb.devuan.org/merged chimaera/main amd64 fuse3 amd64 3.10.3-2 [34.7 kB]
Get:3 http://deb.devuan.org/merged chimaera/main amd64 python3-tdb amd64 1.4.3-1+b1 [20.6 kB]
Get:4 http://deb.devuan.org/merged chimaera/main amd64 python3-samba amd64 2:4.13.13+dfsg-1~deb11u5 [2,688 kB]
Get:5 http://deb.devuan.org/merged chimaera/main amd64 samba-common all 2:4.13.13+dfsg-1~deb11u5 [171 kB]
Get:6 http://deb.devuan.org/merged chimaera/main amd64 samba-common-bin amd64 2:4.13.13+dfsg-1~deb11u5 [666 kB]
Get:7 http://deb.devuan.org/merged chimaera/main amd64 tdb-tools amd64 1.4.3-1+b1 [31.7 kB]
Get:8 http://deb.devuan.org/merged chimaera/main amd64 samba amd64 2:4.13.13+dfsg-1~deb11u5 [1,182 kB]
Get:9 http://deb.devuan.org/merged chimaera/main amd64 smbclient amd64 2:4.13.13+dfsg-1~deb11u5 [510 kB]
Get:10 http://deb.devuan.org/merged chimaera/main amd64 attr amd64 1:2.4.48-6 [41.9 kB]
Get:11 http://deb.devuan.org/merged chimaera/main amd64 gvfs-bin amd64 1.46.2-1 [22.2 kB]
Get:12 http://deb.devuan.org/merged chimaera/main amd64 gvfs-fuse amd64 1.46.2-1 [35.3 kB]
Get:13 http://deb.devuan.org/merged chimaera/main amd64 libibverbs1 amd64 33.2-1 [59.4 kB]
Get:14 http://deb.devuan.org/merged chimaera/main amd64 ibverbs-providers amd64 33.2-1 [253 kB]
Get:15 http://deb.devuan.org/merged chimaera/main amd64 librdmacm1 amd64 33.2-1 [68.9 kB]
Get:16 http://deb.devuan.org/merged chimaera/main amd64 librados2 amd64 14.2.21-1 [3,099 kB]
Get:17 http://deb.devuan.org/merged chimaera/main amd64 libcephfs2 amd64 14.2.21-1 [480 kB]
Get:18 http://deb.devuan.org/merged chimaera/main amd64 libgfxdr0 amd64 9.2-1 [3,043 kB]
Get:19 http://deb.devuan.org/merged chimaera/main amd64 libglusterfs0 amd64 9.2-1 [3,288 kB]
Get:20 http://deb.devuan.org/merged chimaera/main amd64 libgfrpc0 amd64 9.2-1 [3,069 kB]
Get:21 http://deb.devuan.org/merged chimaera/main amd64 libgfapi0 amd64 9.2-1 [3,097 kB]
Get:22 http://deb.devuan.org/merged chimaera/main amd64 liburing1 amd64 0.7-3 [8,572 B]
Get:23 http://deb.devuan.org/merged chimaera/main amd64 samba-dsdb-modules amd64 2:4.13.13+dfsg-1~deb11u5 [398 kB]
Get:24 http://deb.devuan.org/merged chimaera/main amd64 samba-vfs-modules amd64 2:4.13.13+dfsg-1~deb11u5 [499 kB]
Fetched 22.9 MB in 6s (4,031 kB/s)
Preconfiguring packages ...
Selecting previously unselected package libfuse3-3:amd64.
(Reading database ... 213350 files and directories currently installed.)
Preparing to unpack .../libfuse3-3_3.10.3-2_amd64.deb ...
Unpacking libfuse3-3:amd64 (3.10.3-2) ...
dpkg: fuse: dependency problems, but removing anyway as you requested:
 xdg-desktop-portal depends on fuse.
 ntfs-3g depends on fuse.
 exfat-fuse depends on fuse.
(Reading database ... 213359 files and directories currently installed.)
Removing fuse (2.9.9-5) ...
update-initramfs: deferring update (trigger activated)
Selecting previously unselected package fuse3.
(Reading database ... 213348 files and directories currently installed.)
Preparing to unpack .../00-fuse3_3.10.3-2_amd64.deb ...
Unpacking fuse3 (3.10.3-2) ...
Selecting previously unselected package python3-tdb.
Preparing to unpack .../01-python3-tdb_1.4.3-1+b1_amd64.deb ...
Unpacking python3-tdb (1.4.3-1+b1) ...
Selecting previously unselected package python3-samba.
Preparing to unpack .../02-python3-samba_2%3a4.13.13+dfsg-1~deb11u5_amd64.deb ..
Unpacking python3-samba (2:4.13.13+dfsg-1~deb11u5) ...
Selecting previously unselected package samba-common.
Preparing to unpack .../03-samba-common_2%3a4.13.13+dfsg-1~deb11u5_all.deb ...
Unpacking samba-common (2:4.13.13+dfsg-1~deb11u5) ...
Selecting previously unselected package samba-common-bin.
Preparing to unpack .../04-samba-common-bin_2%3a4.13.13+dfsg-1~deb11u5_amd64.deb
Unpacking samba-common-bin (2:4.13.13+dfsg-1~deb11u5) ...
Selecting previously unselected package tdb-tools.
Preparing to unpack .../05-tdb-tools_1.4.3-1+b1_amd64.deb ...
Unpacking tdb-tools (1.4.3-1+b1) ...
Selecting previously unselected package samba.
Preparing to unpack .../06-samba_2%3a4.13.13+dfsg-1~deb11u5_amd64.deb ...
Unpacking samba (2:4.13.13+dfsg-1~deb11u5) ...
Selecting previously unselected package smbclient.
Preparing to unpack .../07-smbclient_2%3a4.13.13+dfsg-1~deb11u5_amd64.deb ...
Unpacking smbclient (2:4.13.13+dfsg-1~deb11u5) ...
Selecting previously unselected package attr.
Preparing to unpack .../08-attr_1%3a2.4.48-6_amd64.deb ...
Unpacking attr (1:2.4.48-6) ...
Selecting previously unselected package gvfs-bin.
Preparing to unpack .../09-gvfs-bin_1.46.2-1_amd64.deb ...
Unpacking gvfs-bin (1.46.2-1) ...
Selecting previously unselected package gvfs-fuse.
Preparing to unpack .../10-gvfs-fuse_1.46.2-1_amd64.deb ...
Unpacking gvfs-fuse (1.46.2-1) ...
Selecting previously unselected package libibverbs1:amd64.
Preparing to unpack .../11-libibverbs1_33.2-1_amd64.deb ...
Unpacking libibverbs1:amd64 (33.2-1) ...
Selecting previously unselected package ibverbs-providers:amd64.
Preparing to unpack .../12-ibverbs-providers_33.2-1_amd64.deb ...
Unpacking ibverbs-providers:amd64 (33.2-1) ...
Selecting previously unselected package librdmacm1:amd64.
Preparing to unpack .../13-librdmacm1_33.2-1_amd64.deb ...
Unpacking librdmacm1:amd64 (33.2-1) ...
Selecting previously unselected package librados2.
Preparing to unpack .../14-librados2_14.2.21-1_amd64.deb ...
Unpacking librados2 (14.2.21-1) ...
Selecting previously unselected package libcephfs2.
Preparing to unpack .../15-libcephfs2_14.2.21-1_amd64.deb ...
Unpacking libcephfs2 (14.2.21-1) ...
Selecting previously unselected package libgfxdr0:amd64.
Preparing to unpack .../16-libgfxdr0_9.2-1_amd64.deb ...
Unpacking libgfxdr0:amd64 (9.2-1) ...
Selecting previously unselected package libglusterfs0:amd64.
Preparing to unpack .../17-libglusterfs0_9.2-1_amd64.deb ...
Unpacking libglusterfs0:amd64 (9.2-1) ...
Selecting previously unselected package libgfrpc0:amd64.
Preparing to unpack .../18-libgfrpc0_9.2-1_amd64.deb ...
Unpacking libgfrpc0:amd64 (9.2-1) ...
Selecting previously unselected package libgfapi0:amd64.
Preparing to unpack .../19-libgfapi0_9.2-1_amd64.deb ...
Unpacking libgfapi0:amd64 (9.2-1) ...
Selecting previously unselected package liburing1:amd64.
Preparing to unpack .../20-liburing1_0.7-3_amd64.deb ...
Unpacking liburing1:amd64 (0.7-3) ...
Selecting previously unselected package samba-dsdb-modules:amd64.
Preparing to unpack .../21-samba-dsdb-modules_2%3a4.13.13+dfsg-1~deb11u5_amd64.d
eb ...
Unpacking samba-dsdb-modules:amd64 (2:4.13.13+dfsg-1~deb11u5) ...
Selecting previously unselected package samba-vfs-modules:amd64.
Preparing to unpack .../22-samba-vfs-modules_2%3a4.13.13+dfsg-1~deb11u5_amd64.de
b ...
Unpacking samba-vfs-modules:amd64 (2:4.13.13+dfsg-1~deb11u5) ...
Setting up libibverbs1:amd64 (33.2-1) ...
Setting up ibverbs-providers:amd64 (33.2-1) ...
Setting up attr (1:2.4.48-6) ...
Setting up samba-common (2:4.13.13+dfsg-1~deb11u5) ...
Creating config file /etc/samba/smb.conf with new version
Setting up libglusterfs0:amd64 (9.2-1) ...
Setting up python3-tdb (1.4.3-1+b1) ...
Setting up tdb-tools (1.4.3-1+b1) ...
update-alternatives: using /usr/bin/tdbbackup.tdbtools to provide /usr/bin/tdbba
ckup (tdbbackup) in auto mode
Setting up gvfs-bin (1.46.2-1) ...
Setting up libfuse3-3:amd64 (3.10.3-2) ...
Setting up liburing1:amd64 (0.7-3) ...
Setting up smbclient (2:4.13.13+dfsg-1~deb11u5) ...
Setting up samba-dsdb-modules:amd64 (2:4.13.13+dfsg-1~deb11u5) ...
Setting up python3-samba (2:4.13.13+dfsg-1~deb11u5) ...
Setting up libgfxdr0:amd64 (9.2-1) ...
Setting up librdmacm1:amd64 (33.2-1) ...
Setting up librados2 (14.2.21-1) ...
Setting up samba-vfs-modules:amd64 (2:4.13.13+dfsg-1~deb11u5) ...
Setting up libcephfs2 (14.2.21-1) ...
Setting up fuse3 (3.10.3-2) ...
Installing new version of config file /etc/fuse.conf ...
Setting up samba-common-bin (2:4.13.13+dfsg-1~deb11u5) ...
Checking smb.conf with testparm
Load smb config files from /etc/samba/smb.conf
Loaded services file OK.
Weak crypto is allowed
Server role: ROLE_STANDALONE
Done
Setting up gvfs-fuse (1.46.2-1) ...
Setting up libgfrpc0:amd64 (9.2-1) ...
Setting up samba (2:4.13.13+dfsg-1~deb11u5) ...
Adding group `sambashare' (GID 123) ...
Done.
Samba is not being run as an AD Domain Controller: Masking samba-ad-dc.service
Please ignore the following error about deb-systemd-helper not finding those ser
vices.
(samba-ad-dc.service masked)
grep: /etc/apparmor.d/samba/smbd-shares: No such file or directory
diff: /etc/apparmor.d/samba/smbd-shares: No such file or directory
Starting SMB/CIFS daemon: smbd.
Starting NetBIOS name server: nmbd.
Setting up libgfapi0:amd64 (9.2-1) ...
Processing triggers for libc-bin (2.31-13+deb11u5) ...
Processing triggers for man-db (2.9.4-2) ...
Processing triggers for initramfs-tools (0.140) ...
update-initramfs: Generating /boot/initrd.img-5.10.0-21-amd64
W: Possible missing firmware /lib/firmware/amdgpu/ip_discovery.bin for module am
dgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega10_cap.bin for module amdg
pu
W: Possible missing firmware /lib/firmware/amdgpu/navi12_cap.bin for module amdg
pu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_10_sos.bin for module
 amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_7_ta.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_7_sos.bin for module
amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_0_ta.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/psp_13_0_0_sos.bin for module
amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/aldebaran_cap.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_imu.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_2_imu.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_imu.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_rlc.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mec.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_me.bin for module am
dgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_pfp.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_2_rlc.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_2_mec.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_2_me.bin for module am
dgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_2_pfp.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_toc.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_rlc.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_mec.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_me.bin for module am
dgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_pfp.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/sdma_6_0_3.bin for module amdg
pu
W: Possible missing firmware /lib/firmware/amdgpu/sdma_6_0_2.bin for module amdg
pu
W: Possible missing firmware /lib/firmware/amdgpu/sdma_6_0_0.bin for module amdg
pu
W: Possible missing firmware /lib/firmware/amdgpu/sienna_cichlid_mes1.bin for mo
dule amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/navi10_mes.bin for module amdg
pu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mes1.bin for module
amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_3_mes.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_2_mes1.bin for module
amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_2_mes.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_mes1.bin for module
amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/gc_11_0_0_mes.bin for module a
mdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vcn_4_0_4.bin for module amdgp
u
W: Possible missing firmware /lib/firmware/amdgpu/vcn_4_0_0.bin for module amdgp
u
W: Possible missing firmware /lib/firmware/amdgpu/smu_13_0_10.bin for module amd
gpu
W: Possible missing firmware /lib/firmware/amdgpu/smu_13_0_7.bin for module amdg
pu
W: Possible missing firmware /lib/firmware/amdgpu/smu_13_0_0.bin for module amdg
pu
W: Possible missing firmware /lib/firmware/amdgpu/dcn_3_2_1_dmcub.bin for module
 amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/dcn_3_2_0_dmcub.bin for module
 amdgpu
#2 2023-02-28 15:27:17
Re: (chimaera) samba, gvfs install > fuse deinstall?
When you look at your log you see fuse being removed and fuse3 being added. OK?
#3 2023-02-28 15:29:06
boughtonp
Pay more attention to the output:
It is removing fuse because it is installing fuse3 to replace it.
3.1415P265E589T932E846R64338
#4 2023-02-28 17:59:03
kapqa
thank you, yes, did not give the proper attention.
all should be good then.
