Good morning,
I am trying to install chimaera on an Rpi2.
I prepared an sdcard via chroot from my PC.
the RPi boots correctly, starts the ssh server and a working Xorg session.
But from my PC tio /dev/ttyUSB0 not working.
the PC can connect and disconnect, but no input is received by the RPi.
I prepared another sdcard by copying the image downloads.raspberrypi.org/.../2022-09-22-raspios-buster-armhf-lite.img.xz
it uses systemd as init.
tio /dev/ttyUSB0 works perfectly.
I added
T0:23:respawn:/sbin/agetty -o -p -- \u --keep-baud 115200,57600,38400,9600 ttyAMA0 vt220
in /etc/inittab.
no change, not working.
thanks
I added
T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100
in /etc/inittab, and WORKING !!!
cmdline.txt
root=/dev/mmcblk0p2 rootfstype=ext4 rw rootwait fsck.repair=yes console=tty1 elevator=noop raid=noautodetect net.ifnames=0 biosdevname=0 noswapconfig.txt
disable_overscan=1
hdmi_drive=2
config_hdmi_boost=4
dtparam=audio=on
[pi2]
max_usb_current=1
#pour branchement sur HDMI3 / ARC
hdmi_group=1
hdmi_mode=31
[pi4]
dtoverlay=vc4-fkms-v3d
dtoverlay=disable-bt
#dtoverlay=disable-wifi
max_framebuffers=2
gpu_mem=320
[all]/etc/inittab
#1:2345:respawn:/sbin/getty --noclear --noclear 38400 tty1
2:23:respawn:/sbin/getty 38400 tty2
6:23:respawn:/sbin/getty 38400 tty6
# Example how to put a getty on a serial line (for a terminal)
T0:23:respawn:/sbin/getty -L ttyAMA0 115200 vt100Last edited by nenesse (2023-02-14 17:08:00)
