#1 2017-04-10 22:25:20
KatolaZ
For package maintainers: d1h is available in experimental
Hi all,
just to let you know that d1h (a helper to simplify operations
in the Devuan package maintenance workflow) is now available in
experimental. The aim of d1h is to make Devuan package
maintenance as easy as it can get, by hiding most of the unnecessary
details and providing a simple (CLI) interface.
More info about getting and using d1h, together with a simple
guide with a worked example can be found at:
  https://dev1galaxy.org/viewtopic.php?id=549
Comments, suggestions, and issues are welcome, and should be
reported on the git page of the project:
  https://git.devuan.org/devuan-packages/d1h
HH
KatolaZ
