#1 2023-01-21 22:02:08
dcolburn
[SOLVED] Restart nginx question
A quick question, please?
Does nginx -s reload (as root) accomplish the same thing as sudo systemctl restart nginx.service, please?
Thanks
#2 2023-01-21 22:13:37
Re: [SOLVED] Restart nginx question
Almost:
https://salsa.debian.org/nginx-team/ngi … ervice#L24
EDIT: or use
# /etc/init.d/nginx restart
https://salsa.debian.org/nginx-team/ngi … #L132-L156
#3 2023-01-21 22:27:24
dcolburn
nginx restart errors
invalid option: "restart"
I'm not sure what to make of the salsa.debian.org pages ... do I need to edit something so that nginx -s reload is the same as nginx restart?
#4 2023-01-21 22:36:31
dcolburn wrote:
nginx restart
That's not what I posted hmm
EDIT: the first salsa link shows the ExecReload line from the systemd unit file for nginx; that command is what is run when systemctl restart nginx is called.
Better to use the init script instead though, hence my suggestion in the code block.
#5 2023-01-21 23:05:45
Marjorie
Alternatively use either
sudo service nginx restart
or
su -
depending on whether you have a root password or not.
#6 2023-01-21 23:09:32
dcolburn
dcolburn wrote:
nginx restart
That's me missing a detail, again ...
I was sitting at /etc/nginx/ and missed the /init.d/ .. sigh.
All good, thanks!
Onward ...
#7 2023-01-21 23:11:07
dcolburn
or
su -
OK, cool, I'm in root but
ran fine.
Thanks
