#1 2023-01-19 17:50:39
dcolburn
[SOLVED] dkpg error
Clean new start - no RAID - just sda partitioned ...
https://www.sun2save.com/images/misc1/d … tions1.jpg
After I first saw this nginx error E: nginx-extras: installed nginx-extras package post-installation script subprocess returned error exit status 1 I tried reinstalling nginx from inside Synaptic Package Manager - no joy.
So, I tried this ...
root@devuan1:~# sudo dpkg --configure -a
Setting up nginx-extras (1.18.0-6.1+deb11u3) ...
Starting nginx: nginx failed!
invoke-rc.d: initscript nginx, action "start" failed.
dpkg: error processing package nginx-extras (--configure):
 nginx-extras
root@devuan1:~# sudo apt-get install -f
E: Could not get lock /var/cache/apt/archives/lock. It is held by process 2652 (synaptic)
N: Be aware that removing the lock file is not a solution and may break your system.
E: Unable to lock directory /var/cache/apt/archives/
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
1 not fully installed or removed.
After this operation, 0 B of additional disk space will be used.
 nginx-extras
root@devuan1:~#
Any notion as to what's busted and how to proceed, please?
#2 2023-01-19 18:19:40
Re: [SOLVED] dkpg error
Is port 80 already being used by another application?
ss -nlt 'sport = 80'
The script is supposed to fail more gracefully though hmm
Your disk partitioning is still weird btw but I won't be discussing that in this thread.
EDIT: https://bugs.debian.org/cgi-bin/bugrepo … bug=754407.
#3 2023-01-19 18:21:54
Try killing 2652 - sudo kill -9 2652
https://www.man7.org/linux/man-pages/man1/kill.1.html
#4 2023-01-19 18:25:45
Camtaf wrote:
sudo kill -9 2652
Don't use SIGKILL unless absolutely necessary. Just use SIGTERM instead, which is the default action for kill.
And anyway the OP already killed it.
#5 2023-01-19 18:51:06
dcolburn
root@devuan1:/etc# ss -nlt 'sport = 80'
State   Recv-Q   Send-Q       Local Address:Port       Peer Address:Port   Process
root@devuan1:/etc#
#6 2023-01-19 18:58:10
What does the log say? Don't ask me where they are though. I don't know.
#7 2023-01-22 00:35:20
dcolburn
Checked log and found my error. Thanks
