#1 2023-01-09 18:18:27
mr12345
Beyond 2TB MBR NTFS Partition under Linux ?
Is there a solution, a driver or something to operate a partition beyond 2TB MBR (512b sectors) under Linux? It is done easily under Windows, using a Acronis driver . An "unreachable" partition becomes fully RW-able just after the driver installation, an additional Acronis virtual drive appears in device manager list. Even a reboot is not required.
I plan to repartition this 3TB drive but I am just curious. smile
I am just a Linux beginner enthusiast smile
#2 2023-01-09 18:48:00
Re: Beyond 2TB MBR NTFS Partition under Linux ?
If you're re-partitioning why not move into the 21st century and use a GUID partition table (GPT) instead? That has an 18TiB limit for individual partitions.
#3 2023-01-09 19:04:59
mr12345
It is long story why it is how it is. I am just not ready to re-partition it now so I am curious.
#4 2023-01-09 20:58:05
Have you installed ntfs-3g?
I am using it and I am not aware of any limitations beyond 2T.
#5 2023-01-09 21:02:28
The limitation is caused by the partition table rather than the filesystem.
