#1 2023-01-09 01:07:07
webman
Question on mount/unmout on non-systemd systems like Devuan
Hello!
In the beginning, I was a fan of systemd, even I haven't know to use it, because
I never understood systemv (init-system).
Now, on debian (for several years), I am facing on this and that problems, which seem
to be systemd related.
I have a KVM guest with several accounts.
Astoundingly, each of this have processes running after boot and
independent, if they are logged in or not.
This is problematic, because for some users, I use a homedir which
resides on cifs/smb. On the host, these are zfs filesystems which I want
to snapshot and I wish, that all processes are terminated. For the moment,
I kill them und force unmount by root.
The question is, how this behaves on Devuan.
Thanks so far,
Manfred
#2 2023-01-09 15:29:49
Re: Question on mount/unmout on non-systemd systems like Devuan
I think that user process behaviour is dependent on the KillUserProcesses option in logind.conf so it can be disabled under both systemd (/etc/systemd/logind.conf) or sysvinit/elogind (/etc/elongind/logind.conf) by setting that to yes.
So I think the behaviour would be the same under both init systems. Perhaps try it and report back? I might be wrong.
#3 2023-01-09 15:49:34
webman
thank you.
I've already read and tried this (using the "exclude root" option) - but with different success, so the question
came up for me. The remaining processes are something like gfvs.*
You implicitely said, under systemV/etc this is not the case?
I have a lot of computers, am a linux-noob (nearly), countless VMs (kvm+lxc)
and would not be able to migrate that all fast, but were probably unable to work
with different systems.
#4 2023-01-09 15:58:46
No.
#5 2023-01-10 01:43:42
andyprough
Wouldn't you just find the service associated with the process and un-check that service's annoying run-levels with 'sudo sysv-rc-conf'?
Maybe I'm being dense and this has nothing to do with services. But this is usually one of the first places I look to get misbehaving autostart processes under control.
#6 2023-01-10 06:47:49
Or just purge that GVFS shite.
#7 2023-01-10 08:12:45
webman
Hallo!
Thanks, but there is nothing like this on my debian!
I just beginning from scratch using devuan and even there, there is nothing like this.
On devuan, gvfs is installed, but not active running.
Manfred
#8 2023-01-10 08:15:09
webman
Hi!
Comes to my mind, but must learn about it first.
Probably I need it on that debian-vm.
Manfred
#9 2023-01-18 18:37:42
mweishaar
webman wrote:
Hallo!
Manfred
sudo apt install sysv-rc-conf maybe?
