#1 2023-01-07 05:53:17
deadtom
[SOLVED] Fresh install. SDDM running, but only booting to command line login
Fresh install, SDDM is running when I do service sddm status. If I log in at the command line and run startx, KDE comes up fine.
No idea where to go from here.
Thanks in advance!
#2 2023-01-07 06:25:14
deadtom
Re: [SOLVED] Fresh install. SDDM running, but only booting to command line login
And somehow it fixed itself. I created  /etc/sddm.conf with the following lines:
[Autologin]
User=<my username>
Session=plasma.desktop
Relogin=false
I did shutdown -r now and it continued to come up to a command line prompt, and I'd have to get into KDE by logging in there and doing startx.
Then, instead of simply shutting down, I logged out via the KDE menu, and it took me to the SDDM screen, which I hadn't seen until this point. I initiated a restart from there and when it came back up, it logged me right into my desktop automatically.
I guess something in this process set up a config file somewhere, because it's working fine now.
So, nevermind?
#3 2023-01-07 17:24:19
Searching for recently changed files in /etc and your home directory might tell you what did it. It's more likely to be in /etc but might be in some subdirectory. Try the find command (read it's man page first if it's new to you).
