#1 2023-01-05 02:42:38
dcolburn
[SOLVED] SSL Report - What to Fix & Ignore
Suggestions as to what I should address vs ignore?
I just ran this free analysis ... https://www.ssllabs.com/ssltest/analyze.html
I'm guessing I need to figure out why DNS CAA isn't being reported ... DNS CAA     No (more info)
Should I just ignore the rest of this?
IE 11 / Win Phone 8.1  R		Server sent fatal alert: handshake_failure
Safari 6 / iOS 6.0.1 	Server sent fatal alert: handshake_failure
Safari 7 / iOS 7.1  R		Server sent fatal alert: handshake_failure
Safari 7 / OS X 10.9  R		Server sent fatal alert: handshake_failure
Safari 8 / iOS 8.4  R		Server sent fatal alert: handshake_failure
Safari 8 / OS X 10.10  R		Server sent fatal alert: handshake_failure
#2 2023-01-05 03:50:20
dcolburn
Re: [SOLVED] SSL Report - What to Fix & Ignore
These are the last few lines of output from https://unboundtest.com for CAA.
Jan 05 03:47:24 unbound[729481:0] info: reply from <com.> 192.41.162.30#53
Jan 05 03:47:24 unbound[729481:0] info: query response was ANSWER
Jan 05 03:47:24 unbound[729481:0] info: validated DNSKEY com. DNSKEY IN
Jan 05 03:47:24 unbound[729481:0] info: resolving realupnow.com. DS IN
Jan 05 03:47:24 unbound[729481:0] info: response for realupnow.com. DS IN
Jan 05 03:47:24 unbound[729481:0] info: reply from <com.> 2001:503:d2d::30#53
Jan 05 03:47:24 unbound[729481:0] info: query response was nodata ANSWER
Jan 05 03:47:24 unbound[729481:0] info: NSEC3s for the referral proved no DS.
Jan 05 03:47:24 unbound[729481:0] info: Verified that unsigned response is INSECURE
Jan 05 03:47:24 unbound[729481:0] info: 127.0.0.1 realupnow.com. CAA IN NOERROR 1.528696 0 101
#3 2023-01-05 03:57:35
dcolburn
Shutting down for the night but will try this tomorrow ... unless directed elsewhere ...
https://www.linuxbabe.com/ubuntu/dns-over-tls-resolver-nginx
Step 3: Create DNS over TLS Proxy in Nginx
#4 2023-01-05 14:36:13
rbit
This is set by your domain registrar.  Log into the site that you registered the domain name, and add a CAA record using the issuer of your certificate.  https://letsencrypt.org/docs/caa/ may have more information.  One of my CAA records looks like this:
example.com 1799 IN CAA 0 issue "letsencrypt.org"
Unfortunately, I don't know what to make of those handshake failures.  That seems unrelated to caa.
