#1 2022-12-21 19:23:00
dcolburn
[SOLVED] What is installed when "web server" is selected
When I get to the Software selection step of Install one of the choices is "web server".
I Searched and could not find a reference to "web server" that lists what is installed.
Anyone have a link or list, please?
Thanks
#2 2022-12-21 19:31:23
Re: [SOLVED] What is installed when "web server" is selected
https://pkginfo.devuan.org/cgi-bin/poli … r&x=submit
#3 2022-12-21 20:07:11
dcolburn
OK, so it appears that it's Apache2:
https://pkginfo.devuan.org/cgi-bin/pack … .70devuan1
Description-en: web server
This task selects packages useful for a general purpose web server
system.
Depends: tasksel (= 3.70devuan1), apache2
Recommends: apache2-doc, analog
Edit1: I would prefer to install NGINX rather than Apache - I'm looking at this https://dev1galaxy.org/viewtopic.php?id=3768 and this http://www.troubleshooters.com/linux/nginx/
Edit2: Also, page 5 here ... https://dev1galaxy.org/viewtopic.php?id=3331&p=5
Thanks
#4 2022-12-21 23:08:26
Dutch_Master
  • you can install nginx as a standalone package, as are other server-related packages like mariadb, PHP, etc
  • nginx and apache can safely co-exist on the same machine, but require careful configuration to avoid competing for port access
#5 2022-12-21 23:26:33
dcolburn
I just found it in the repository and it has been installed, thanks!
