#1 2022-12-16 15:27:59
[SOLVED] Daedalus on Aspire and mtp-probe errors
Aspire Aspire A515-44 with Daedalus/openRC/Cinnamon DE (--no-install-recommends): got the following udevd/mtp-probe errors during boot. No errors when booting the older Chimaera installation.
[    6.282545] ACPI: button: Power Button [PWRF]
[    6.343990] r8169 0000:03:00.0: firmware: direct-loading firmware rtl_nic/rtl8168h-2.fw
[    6.354497] ccp 0000:05:00.2: enabling device (0000 -> 0002)
[    6.354668] ccp 0000:05:00.2: ccp: unable to access the device: you might be running a broken BIOS.
[    6.361697] ACPI: bus type drm_connector registered
[    6.364815] ccp 0000:05:00.2: tee enabled
[    6.364818] ccp 0000:05:00.2: psp enabled
[    6.374743] Generic FE-GE Realtek PHY r8169-0-300:00: attached PHY driver (mii_bus:phy_addr=r8169-0-300:00, irq=MAC)
[    6.393147] udevd[1032]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb1/1-4 1 3': No such file or directory
[    6.394023] alg: No test for fips(ansi_cprng) (fips_ansi_cprng)
[    6.398140] udevd[1041]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/pci0000:00/0000:00:08.1/0000:05:00.3/usb2/2-2 2 2': No such file or directory
[    6.449352] snd_hda_intel 0000:05:00.1: enabling device (0000 -> 0002)
[    6.449498] snd_hda_intel 0000:05:00.1: HAspire A515-44andle vga_switcheroo audio client
[    6.449639] snd_hda_intel 0000:05:00.6: enabling device (0000 -> 0002)
[    6.451453] udevd[1076]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-4 3 3': No such file or directory
[    6.452040] udevd[1077]: failed to execute '/lib/udev/mtp-probe' 'mtp-probe /sys/devices/pci0000:00/0000:00:08.1/0000:05:00.4/usb3/3-3 3 2': No such file or directory
[    6.460219] mc: Linux media interface: v0.10
[    6.462551] input: HD-Audio Generic HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:08.1/0000:05:00.1/sound/card0/input11
lspci tells me:
# lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:08.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir Device 24: Function 7
02:00.0 Non-Volatile memory controller: Micron/Crucial Technology Device 5412
03:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 15)
04:00.0 Network controller: Qualcomm Atheros QCA6174 802.11ac Wireless Network Adapter (rev 32)
05:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Renoir (rev c3)
05:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir Radeon High Definition Audio Controller
05:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 10h-1fh) Platform Security Processor
05:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
05:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] ACP/ACP3X/ACP6x Audio Coprocessor (rev 01)
05:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h HD Audio Controller
06:00.0 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
06:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 81)
Looks like mtp-probe is missing in /lib/udev. mtp-tools and various mtp-libs are installed. The issue seems to be related to the Audio devices.
How can I get rid of these messages?
#2 2022-12-16 15:44:04
Re: [SOLVED] Daedalus on Aspire and mtp-probe errors
Does installing the libmtp-runtime package fix things?
Credit to xaos52: https://crunchbang.org/forums/viewtopic.php?id=25200
And thanks to corenomial for keeping those boards running.
EDIT: **** me, I can still log in there and I'm still a moderator. Nice.
#3 2022-12-16 16:26:13
Yes it does, thank you for the reminder. I thought I had added the runtime during the installation, looks like I didn't. The missing file is added to /lib/udev now.
