#1 2022-12-06 22:44:47
deepforest
[SOLVED] --fix-broken install
how to fix that?
root@devuan:/etc/apt# apt remove --fix-broken install
E: Unable to locate package install
root@devuan:/etc/apt# apt --fix-broken install
Correcting dependencies... Done
  libjpeg62-turbo
  libjpeg62-turbo
1 upgraded, 0 newly installed, 0 to remove and 112 not upgraded.
4 not fully installed or removed.
Need to get 0 B/169 kB of archives.
After this operation, 346 kB of additional disk space will be used.
Reading changelogs... Done
(Reading database ... 388635 files and directories currently installed.)
Preparing to unpack .../libjpeg62-turbo_1%3a2.1.2-1+b1_amd64.deb ...
Unpacking libjpeg62-turbo:amd64 (1:2.1.2-1+b1) over (1:1.3.1-12) ...
dpkg: error processing archive /var/cache/apt/archives/libjpeg62-turbo_1%3a2.1.2-1+b1_amd64.deb (--unpack):
 trying to overwrite shared '/usr/share/doc/libjpeg62-turbo/changelog.Debian.gz', which is different from other instances of package libjpeg62-turbo:amd64
smile
pyzNi 3.14zDa! smile
#2 2022-12-06 22:53:02
deepforest
Re: [SOLVED] --fix-broken install
manually remove
/var/lib/dpkg/info
libjpeg62-turbo*
smile
