#1 2022-11-30 15:54:18
aghasee
[SOLVED] Devuan and Realtek RTL8821CE
Is it even possible?
- a collision at sea can ruin your entire day -
#2 2022-11-30 16:16:50
blackhole
Re: [SOLVED] Devuan and Realtek RTL8821CE
It might be...
#3 2022-11-30 16:23:25
It is! Larry Finger will have you covered if it isn't in the kernel.
My crystal ball says the OP has an RTL8852 of some description. Let's see if I'm correct...
#4 2022-11-30 16:47:46
aghasee
RTL8821CE...
#5 2022-11-30 16:58:35
Entering the card name into a search engine and adding "Linux" gives some useful results, for example:
https://linux-hardware.org/index.php?id … -17aa-c024
Devuan's stable release is currently on kernel 5.10 so you should be fine as long as you install the firmware for the card.
#6 2022-11-30 17:10:28
aghasee
Currently I have the tomaspinho version installed. The card works err, somewhat. VERY poor reception and totally unreliable.
#7 2022-11-30 17:35:37
Which kernel are you running? I've had good experiences with Larry's drivers but I don't have an 8821CE.
EDIT: please add "RTL8821CE" to the thread title (edit the first post), it will aid SEO and may attract the attention of others who use the device under Devuan.
#8 2022-11-30 18:31:45
aghasee
5.10 something. Current Cimaera bog standard.
Tried with other kernels to no avail.
#9 2022-11-30 18:44:42
Devuan's stable-backports repository has >6, have you tried that? Newer is probably better for that card, upstream is on v6.0.10 at the moment.
There are also some driver parameters that can be tweaked to aid performance:
# tee /etc/modprobe.d/rtw8821ce.conf >/dev/null <<!
options rtw88_pci disable_aspm=y
options rtw88_core disable_lps=y
# update-initramfs -u -k all
# reboot
^ The tee command creates a file at /etc/modprobe.d/rtw8821ce.conf that disables ASPM & Deep PowerSaving, which might help maintain the connection. Delete the file & run update-initramfs -u -k all again if it doesn't help.
#10 2022-11-30 18:48:26
aghasee
# reboot
Iirc it was 6.0.9 amongst others I tried.
Thanks for the info, I'll give it a try.
#11 2022-11-30 20:16:20
aghasee
No results.
#12 2022-12-02 09:46:01
aghasee
Ok. New install, nonfree and backports enabled.
Available kernels:
dpkg --list | grep linux-image
ii  linux-image-5.10.0-19-amd64                   5.10.149-2                         amd64        Linux 5.10 for 64-bit PCs (signed)
ii  linux-image-5.10.0-9-amd64                    5.10.70-1                          amd64        Linux 5.10 for 64-bit PCs (signed)
ii  linux-image-5.18.0-0.deb11.4-amd64            5.18.16-1~bpo11+1                  amd64        Linux 5.18 for 64-bit PCs (signed)
ii  linux-image-amd64                             5.10.149-2                         amd64        Linux for 64-bit PCs (meta-package)
Only driver I did install extra is firmware-amd-graphics from the official repo.
Now running
uname -r
WiFi card is recognised, but has very poor reception (sitting right next to the router). Fails to login to the network. Bluetooth non functional. USB tethering works a charm.
lspci -v
02:00.0 Network controller: Realtek Semiconductor Co., Ltd. RTL8821CE 802.11ac PCIe Wireless Network Adapter
	DeviceName: Realtek Chopard RTL8821CE 802.11ac 1x1 +BT 4.2 M.2 2230 PCI-e+USB WW
	Subsystem: Hewlett-Packard Company RTL8821CE 802.11ac PCIe Wireless Network Adapter
	Flags: bus master, fast devsel, latency 0, IRQ 63, IOMMU group 9
	I/O ports at f000 [size=256]
	Memory at fce00000 (64-bit, non-prefetchable) [size=64K]
	Capabilities: [40] Power Management version 3
	Capabilities: [50] MSI: Enable+ Count=1/1 Maskable- 64bit+
	Capabilities: [70] Express Endpoint, MSI 00
	Capabilities: [100] Advanced Error Reporting
	Capabilities: [148] Device Serial Number 00-e0-4c-ff-fe-c8-21-01
	Capabilities: [158] Latency Tolerance Reporting
	Capabilities: [160] L1 PM Substates
	Capabilities: [170] Precision Time Measurement
	Capabilities: [17c] Vendor Specific Information: ID=0003 Rev=1 Len=054 <?>
	Kernel driver in use: rtw_8821ce
	Kernel modules: rtw88_8821ce
Where do I go from here?
#13 2022-12-02 16:20:51
You should have installed the metapackage rather than an individual kernel. 5.18 is old now.
# apt install -t stable-backports linux-image-amd64
#14 2022-12-03 01:25:16
aghasee
Even worse with 6.0xxx, it doesnt even try to connect.
Guess I'm gonna buy a new laptop w/o Realtek, or downgrade to windows, coz no linux distro I tried in the last few days gets the job done, systemd'd or not.
#15 2022-12-03 01:27:24
aghasee
~# dpkg --list | grep linux-image
ii  linux-image-6.0.0-0.deb11.2-amd64             6.0.3-1~bpo11+1                    amd64        Linux 6.0 for 64-bit PCs (signed)
ii  linux-image-amd64                             6.0.3-1~bpo11+1                    amd64        Linux for 64-bit PCs (meta-package)
#16 2022-12-03 08:13:03
I'll ask just in case.
Does the wireless regulatory domain match your country?
#17 2022-12-03 10:03:36
aghasee
I guess so, but I'll check later today. Thanks.
#18 2022-12-03 13:31:18
Did you remove the Tomas Pinho driver version? It might conflict or override the mainline version.
Otherwise check the logs.
#19 2022-12-03 14:52:00
aghasee
Clean install Chimaera. Only driver installed is firmware-amd-graphics from the official repo.
#20 2022-12-03 15:15:12
Firmware != driver.
Did you install the relevant Realtek non-free firmware package as well?
#21 2022-12-08 18:40:03
aghasee
Firmware != driver.
No.
It gets installed by default.
#22 2023-03-15 15:35:15
aghasee
Installed a non-realtek wifi antenna.
Marked as solved.
