#1 2022-11-23 11:56:07
[SOLVED] How to set keyboard layout in a remote X session?
when I'm at home, having a wire guard vpn connection to the company, via remote-desktop to xrdp (virtual session, not screen mirror): The keyboard layout switches to 'en_US'.
The reason is unknown, this does not happen when the connection comes form a local machine. Anyway.
I used to have a German keyboard, anything else is English / en_GB.
To switch back to the layout:
$ setxkbmap -layout "de" -nodeadkeys   # same with or without 'nodeadkeys'
This works not 100%. The [Altgr] key stays dead, which means none of {[]}\| .
What am I missing? Or
How to get the [Altgr] key working?
Thanks and regards.
#2 2023-01-06 12:14:08
Re: [SOLVED] How to set keyboard layout in a remote X session?
Update:
The original post was not very precise: xrdp is the problem.
And I found a somewhat dirty hack to fix the keyboard layout.
The loaded keymap is:
sudo cat /var/log/xrdp.log | grep km-000 | tail -1
[20230106-12:31:06] [INFO ] Loading keymap file /etc/xrdp/km-00000409.ini
Which is "us". "de" is "km-00000407.ini".
Backup and copy:
sudo gzip /etc/xrdp/km-00000409.ini
sudo cp /etc/xrdp/km-00000407.ini /etc/xrdp/km-00000409.ini
After logging in, it is still a "us" keymap, but switching to "de" now works
setxkbmap de
Would prefer a cleaner solution, but at least it works by now.
Edit: Will mark it as solved. And look for another remote X session solution.
#3 2023-02-07 23:23:09
guuml.dev1
delgado wrote:
…  And look for another remote X session solution.
Some weeks ago I have read in setxkbmap(1):
USING WITH xkbcomp
If you have an Xserver and a client shell running on different
computers and some XKB configuration files on those machines are
different, you can get problems specifying a keyboard map by model,
layout, and options names. …
For example, the command …
      setxkbmap us -print | xkbcomp - $DISPLAY
makes both steps run on the same (client) machine and loads a keyboard
map into the server.
Note the "us" difference to an example setting with de_DE.UTF-8:
$ setxkbmap -print
xkb_keymap {
	xkb_keycodes  { include "evdev+aliases(qwertz)"	};
	xkb_types     { include "complete"	};
	xkb_compat    { include "complete"	};
	xkb_symbols   { include "pc+de(nodeadkeys)+inet(evdev)"	};
	xkb_geometry  { include "pc(pc105)"	};
Using the command
setxkbmap de nodeadkeys -print | xkbcomp - $DISPLAY
should provide a german keyboard (with no deadkeys) to the server.
#4 2023-04-22 12:38:14
@guuml.dev1: Thanks for the reply (yes, long ago). There are "ä,ö,ü,ß". [AltGr] is onyl working, if xrdp uses an appropriate keymap too.
Update - a cleaner way to set a default keymap for xrdp:
Initially loaded is /etc/xrdp/km-00000000.ini. The file is not existing, so a link or copy can be made without interfering the installation. The issue occurred again on a new PC.
In my case:
$ sudo cp -a /etc/xrdp/km-00000407.ini /etc/xrdp/km-00000000.ini
After logging in, it is still a "us" or "en" keymap, but switching to "de" now fully works.
$ setxkbmap de
