#1 2022-11-23 02:10:00
deepforest
mc, files scrolling by dragging mouse?
were function files scrolling by dragging mouse.
now i use mc  4.8.28 and this function not working, why?
smile
#2 2022-11-24 15:18:49
deepforest
Re: mc, files scrolling by dragging mouse?
noone use that here?
smile
#3 2022-11-25 06:36:48
I've been using mc for ~20 years, and I've never heard of, needed, or wanted to scroll the filelist by "dragging" the mouse. The scrollwheel works fine.
TBH I primarily just use the keyboard though, that's what page up and page down keys are for, is it not?
#4 2022-11-26 00:11:33
deepforest
Thanks for reply!)
May be this answer?
Now tested. Under xfce all works good. Issue only under Trinity DE(KDE3 successor)
https://midnight-commander.org/ticket/4063
smile
#5 2022-11-26 00:43:14
deepforest
No, not solved, on xfce, mc scrolling by pulling mouse + RMB pressed working only downside, upside not.
smile
#6 2022-11-26 23:33:48
Kelsoo
I'm on 4.8.27 on Slackware.
RMB and drag selects for me. Though MC has way more config options than I need.
It will does scroll if I select files higher or lower than the visible window but for plain scrolling I use mouse wheel or page up/down like steve_v.
scrolling by pulling mouse + LMB pressed works only downways, not upways. is the behavior I get.
#7 2022-11-27 05:00:23
Fixed in (not yet released) 4.8.29
#8 2022-11-27 23:25:16
deepforest
Thank you for information!)
smile
