#1 2022-11-02 18:05:54
Bartes
[SOLVED] Install openvas(gvm) in Devuan
Hi all.
I needed to install Openvas(gmv).
They are not in the repositories.
I downloaded the script from github for auto installation.
Installed but can't run. Installed openrc.
The commands to start gvm did not help me.
sudo rc service gvm start.
sudo rc update add gvm.
How do I start the openvas service.
To then enter 127.0.0.1:9392 in the browser.
test@Hack:~$ rc-status
Runlevel: default
 rsyslog                                                           [  started  ]
 dbus                                                              [  started  ]
 avahi-daemon                                                      [  started  ]
 cups-browsed                                                      [  started  ]
 ntp                                                               [  started  ]
 postgresql                                                        [  started  ]
 elogind                                                           [  started  ]
 console-setup.sh                                                  [  started  ]
 sysstat                                                           [  started  ]
 sudo                                                              [  started  ]
 rmnologin                                                         [  started  ]
 pulseaudio-enable-autospawn                                       [  started  ]
 bootlogs                                                          [  started  ]
 lightdm                                                           [  started  ]
 anacron                                                           [  started  ]
 cups                                                              [  started  ]
 qemu-guest-agent                                                  [  started  ]
 network-manager                                                   [  started  ]
 ssh                                                               [  started  ]
 rsync                                                             [  started  ]
 binfmt-support                                                    [  started  ]
 cron                                                              [  started  ]
 redis-server                                                      [  started  ]
 saned                                                             [  started  ]
 stop-bootlogd                                                     [  started  ]
 rc.local                                                          [  started  ]
Dynamic Runlevel: hotplugged
Dynamic Runlevel: needed/wanted
 umountroot                                                        [  started  ]
 umountfs                                                          [  started  ]
 umountnfs.sh                                                      [  started]
