#1 2022-11-01 18:07:27
migf
[SOLVED] Installing firmware not yet in Devuan nor Debian packages
In a previous thread https://dev1galaxy.org/viewtopic.php?id=5300 I got very nice advice on how to install firmware for the Realtek wireless from the backports repositories, and this apparently solved the problems I was having. Some days later I found out that although the device was then seen the connection was unstable and is unusable: dmesg was full of messages like this:
rtw89_pci 0000:03:00.0:  [FWBB][WARN][CMW] No specific sta connect
A lengthy search led me to this thread in kernel.org https://lkml.kernel.org/linux-wireless/ … tek.com/T/ that
advises the use of some options to the Realtek kernel modules (rtw89_core, rtw89_pci), and the use of the firmware version 0.13.36.0, while the latest one in Debian bullseye is 0.9.12.2.
So I got the bin file from https://git.kernel.org/pub/scm/linux/ke … mware.git/ and I am now trying to find out what to do with it,
as I am confused with all the methods I found out in the net for upgrading firmware...
Is that enough to put the file in /lib/firmware/rtw89/ as in that thread, or is this unsafe? If unsafe what is the recommended method? The laptop is a HP with UEFI boot.
Thanks in advance for any help.
#2 2022-11-01 18:58:31
Re: [SOLVED] Installing firmware not yet in Devuan nor Debian packages
Using the raw file is fine but it will need to be kept updated.
Ceres now has the firmware from 2022-10-18 so you can use that.
Add this to /etc/apt/sources.list.d/ceres:
deb http://deb.devuan.org/merged ceres non-free
And add this to /etc/apt/preferences.d/ceres:
Package: *
Pin: release a=unstable, n=ceres
Pin-Priority: -1
Package: firmware-realtek
Pin-Priority: 500
Then
# apt update
# apt upgrade
Keep checking chimaera-backports though because that package will probably make it through in a few weeks. When it does remove the added files and reinstall the package from backports instead.
#3 2022-11-01 19:40:25
migf
Thanks a lot for your reply! I was not aware of the Ceres release, but if it is based on Debian unstable I could not find that version there some days ago.
I will try this tomorrow and will report back.
#4 2022-11-03 18:36:41
migf
I am stuck again, now with a Temporary failure resolving 'deb.devuan.org' error when trying apt update.
I already read the https://dev1galaxy.org/viewtopic.php?id=5133 thread in this forum, and following a tip there I changed my router
DNS settings to point to OpenDNS. This solved the problem in my desktop, but not in the laptop.
I noticed that dig deb.devuan.org
  • gets 125.228.189.120 with a warning recursion requested but not available[
  • with the -4 option starts with the warning Message parser reports malformed message packet but the rest is identical
  • with -6 it just freezes
host debuan.dev.org works fine with no option or with -4, but freezes with -6. So maybe this a problem of something trying to use ipV6 at some stage.
I also tried to use the mirror repo.ifca.es/devuan-cd by editing the apt sources list, but the results are similar.
I do not know if there is any relation with problems of Firefox that cannot access any web server. This may result from the avahi-daemon not being installed: I get rid of it because it created an interface etho:avahi that could not be  controlled by  ifup and ifdown, and that used some strange IP (not in the LAN).
#5 2022-11-03 19:18:05
Try again later. Maybe one of the mirrors just had a hickup.
When you directly copy new firmware to /lib/firmware you need to build a new initrd to make that work.
#6 2022-11-04 12:31:56
migf
@rolfie: Thanks for your tip!
There has been some progress: using eth0 I could upgrade and update the system, with a new kernel version, 5.19, and the Realtek firmware of the version I sought:
[    3.868460] rtw89_8852ae 0000:01:00.0: enabling device (0000 -> 0003)
[    3.871490] rtw89_8852ae 0000:01:00.0: firmware: direct-loading firmware rtw89/rtw8852a_fw.bin
[    3.871504] rtw89_8852ae 0000:01:00.0: Firmware version 0.13.36.0, cmd version 0, type 1
[    3.871506] rtw89_8852ae 0000:01:00.0: Firmware version 0.13.36.0, cmd version 0, type 3
[    3.888028] rtw89_8852ae 0000:01:00.0: chip rfe_type is 1
However, with ifdown eth0 and ifup wlan0 the latter hangs and must be backgrounded. The kernel messages show also that some features are disabled:
[   66.744949] r8169 0000:02:00.0 eth0: Link is Down
[   79.935440] wlan0: authenticate with ec:1a:59:88:2f:25
[   79.935455] wlan0: bad VHT capabilities, disabling VHT
[   79.935457] wlan0: Invalid HE elem, Disable HE
[   80.158538] wlan0: send auth to ec:1a:59:88:2f:25 (try 1/3)
[   80.160026] wlan0: authenticated
[   80.160231] rtw89_8852ae 0000:01:00.0 wlan0: disabling HT/VHT/HE as WMM/QoS is not supported by the AP
[   80.162542] wlan0: associate with ec:1a:59:88:2f:25 (try 1/3)
[   80.165039] wlan0: RX AssocResp from ec:1a:59:88:2f:25 (capab=0x411 status=0 aid=1)
[   80.278693] wlan0: associated
[   80.350754] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Then no nameserver is seen with a Network unreachable error. So it seems that this command did not finish the network configuration. Moreover trying to turn off the interface also hangs and must be interrupted:
# ifdown wlan0
ifdown: waiting for lock on /run/network/ifstate.wlan0
^CGot signal Interrupt, terminating...
^C
The relevant lines of /etc/network/interfaces are
allow-hotplug eth0
iface eth0 inet dhcp
iface wlan0 inet dhcp
    pre-up wpa_supplicant -c /etc/wpa_supplicant/wpa_supplicant.conf -i wlan0
and here are the contents of /etc/resolv.conf
domain XXX
search XXX
nameserver 192.168.2.1
Is there any way of configuring manually the network, apart from adding IPs and hosts to /etc/hosts?
#7 2022-11-04 17:43:24
allow-hotplug eth0
What is the content of wpa_supplicant.conf? How did you generate it?
It is more usual to just include the name of the access point and the (hashed) password in /etc/network/interfaces directly, as per https://wiki.debian.org/WiFi/HowToUse#Using_ifupdown, have you tried that?
#8 2022-11-04 18:09:11
migf
I generated it as I did for previous laptops: using wpa_passphrase to encode the key. Its contents are:
ctrl_interface=DIR=/var/run/wpa_supplicant GROUP=netdev
network={
  ssid="XXX"
  scan_ssid=1
  key_mgmt=WPA-PSK
  psk=.......
Has this been deprecated?
#9 2022-11-04 18:18:51
Not that I know of but I've been using iwd for a good long while now so I don't keep up with wpa_supplicant. That ctrl_interface line is only needed for wpagui though, at least AFAIK.
Use the /etc/network/interfaces format suggested in https://wiki.debian.org/WiFi/HowToUse#W … d_WPA2-PSK instead.
#10 2022-11-04 19:12:24
migf
Great, many thanks: it works!
There were  small changes in the /etc/network/interfaces, for instance no equal signs between options and their values, that I think are just for making people like me to be confused.
Marking this thread as solved, and many thanks again!
