#1 2022-10-24 20:45:01
nahkhiirmees
init script for stubby
Couple months ago i tried dnsmasq and stubby. During that time i noticed that there's no init script for stubby so i wrote one:
### BEGIN INIT INFO
# Provides: stubby
# Required-Start: $network $remote_fs $syslog
# Required-Stop:  $network $remote_fs $syslog
# Default-Start:  2 3 4 5
# Default-Stop:   0 1 6
# Description: a dns resolver
### END INIT INFO
#. /lib/lsb/init-functions
case "$1" in
  start)
	touch /run/stubby.pid
	chmod 600 /run/stubby.pid
	chown stubby:65534 /run/stubby.pid
	sudo -u stubby stubby -g
 stop)
	killall stubby
        echo "Usage: $SCRIPTNAME start" >&2
        exit 3
esac
pretty obvious stuff. The #BEGIN ... #END - parts i copied from dnsmasq's init file or some other file and changed a few rows.
How about adding something like this in the stubby package?
#2 2022-10-24 20:54:14
Re: init script for stubby
sudo shouldn't be used in init scripts. There are other issues.
For a better version (along with postinst, prerm & postrm scripts) see https://bugs.debian.org/cgi-bin/bugrepo … ug=1008931.
Related: https://dev1galaxy.org/viewtopic.php?id=4865 ← that shows how to generate an init script from the supplied /lib/systemd/system/stubby.service unit file.
#3 2024-06-01 00:25:03
nahkhiirmees
Is the problem with sudo just that "you're not supposed to do thing that way". Or are there security problems involved?
#4 2024-06-03 03:33:32
Hi, in case you are waiting for HoaS to reply, he hasn't been on these forums for a while.
#5 2024-06-03 14:38:18
nahkhiirmees
Did some research, found these links:
https://stackoverflow.com/questions/179 … nit-script
https://bitmingw.com/2017/01/22/use-sudo-in-scripts/
So, if sudo is not the recommended command, deamon/runuser/whatever_passes_for_those_in_Devuan_today is ok?
I'm considering whether i should convert that service-file(?id=4865) or not?
#6 2024-06-03 22:46:41
I don't use sudo, you might be better off starting a new thread with your question. All the best.
#7 2024-06-04 21:54:33
EDX-0
sudo should not be used on init scripts, not directly because of security, but it is assumed not every system may had sudo installed as a minimal install with a root account and password will only have su and require running su to change into the root account to perform all administrative tasks.
that aside in a proper initscript the variable RUN_AS_USER is defined, usually as RUN_AS_USER=root for daemons intended to be ran by the root user, for daemons that need to be ran under a specific user the variable is defined with the intended user.
accordingly the start-stop-daemon program will be used to guarantee correct behaviour, ie check for initialization of instance and creation of the pid file.
an example standar use of start-stop-daemon would be as follows:
start-stop-daemon -S --pidfile ${PIDFILE} --make-pidfile --background \
            --chuid ${RUN_AS_USER} --startas ${DAEMON} -- ${DAEMON_ARGS}
as for the options straight from the manual:
-S, --start [--] arguments
           Check  for  the existence of a specified process.  If such a process exists, start-stop-daemon does nothing, and exits with error status 1 (0 if --oknodo is specified).  If such a process does not exist, it
           starts an instance, using either the executable specified by --exec or, if specified, by --startas.  Any arguments given after -- on the command line are passed unmodified to the program being started.
the flags and the vars passed should be descriptive enough and those are expected to be defined earlier on the initscript.
as for --background it is used with prgrams that will not fork to background by themselves.
if you want an okay example of a proper initscript file for an arbitrary daemon check https://github.com/eylles/afreq.sh
the file acpufreq.is is the definition of the initscrip, mind you that when you write initscript files not every daemon will support options like reloading the configuration so the route that many initscripts take is to just have the restart idiom also match reload and force-reload like so:
    restart|reload|force-reload)
        $0 stop && sleep 3 && $0 start
#8 2024-06-05 22:57:00
nahkhiirmees
Found already the manpage of start-stop-deamon . Planning to rewrite that "stubby-script" when i get tired of solving the gray_screen_problem.
#9 2024-06-25 09:43:09
tux2bsd
### BEGIN INIT INFO
# Provides: stubby
### END INIT INFO
case "$1" in
  start)
	test -f /run/stubby.pid || install -o stubby -g stubby -m 600 /dev/null /run/stubby.pid
	su - stubby -c "stubby &"
 stop)
	killall stubby
	rm /run/stubby.pid
        exit 3
esac
This should work OK.  Untested, I don't have stubby installed. Main goal is get rid of sudo for you.
If the stubby program writes to the PID fill it could be used to kill with instead.
#10 2026-01-17 16:13:34
nahkhiirmees
Last year i tried to rewrite my script to use start-stop-daemon. But then dnsmasq ceased to co-operate. Maybe the version Daedalus includes has a problem with running on localhost.
#11 2026-01-18 11:58:47
abower
There is an official initscript (by me) for stubby in ceres. So far no one has committed to wanting to install it from excalibur/trixie-backports but that could be an option if there were demand.
Here it is: https://sources.debian.org/src/getdns/1 … tubby.init
