#1 2022-10-20 17:29:00
migf
[SOLVED] Realtet 8852 wireless in Chimaera
I have installed Chimaera on a recent HP having a Realtek8852 wireless chipset whose firmware is missing.
I already tried some solution I found out in the Debian site, the result being that I had to reinstall everything from scratch,
and I am aware of the driver in [https://www.amd.com/en/support/graphics/radeon-rx-vega-series/radeon-rx-vega-series/radeon-rx-vega-64] that seems to still have issues.
So I think there may be two more easier solutions
  • install a more recent kernell like 5.18 and stop using the one in the Chimaera distribution: will this solve the problem, and is it a safe solutiom?
  • keep the current kernel and buy a dongle that is known to work with it: what such dongles are there?
I will be very grateful for any help on this!
#2 2022-10-20 19:18:38
nixer
Re: [SOLVED] Realtet 8852 wireless in Chimaera
I had a similar issue two weeks ago.  I had a 5 or 6 year old HP laptop in good condition but the wifi card in it was only 2.4ghz and I wanted a 5ghz card for the speed.  So I bought one off of ebay.  It was a RTL8821CE 802.11ac.  It did not work with the stock kernel in chimaera, so I installed a newer kernel from chimaera-backports.  The dkms module built fine then and it works like a charm.  It was the first time I ever needed a newer backported kernel.
Installed the necessary firmware:
apt install firmware-realtek
Add the backports line to the  /etc/apt/sources.list  file
deb http://deb.devuan.org/merged/ chimaera-backports main contrib non-free
Then:
apt update
Install the backported kernel:
apt install -t chimaera-backports linux-image-5.18-(whatever the version is in backports).
Might be best to install the kernel before the firmware.
It appears that this firmware-realtek package may support your RTL8852 card.  From the debian package page showing supported hardware:
* Realtek RTL8852AU Bluetooth config (rtl_bt/rtl8852au_config.bin)
* Realtek RTL8852AU Bluetooth firmware (rtl_bt/rtl8852au_fw.bin)
* Realtek RTL8852A firmware, version v0.9.12.2 (rtw89/rtw8852a_fw.bin)
#3 2022-10-21 05:43:17
The rtw89 driver was mainlined for kernel 5.16 so you will need the backported kernel. Use the linux-image-amd64 metapackage, that will always depend on the latest version.
#4 2022-10-21 10:19:55
migf
Thank you very much for both replies!
I added the backports line to the apt sources.list and I just found out I missed "non-free" there, but I think this will not change what I describe below.
@Head_on_a_stick: I found out that linux-image-amd64 was already there and when I tried to reinstall it apt answered that the 5.10 kernel would be installed; so
I quit.
@nixer: I tried to install linux-image-5.18.0-0 as you suggested but there are several packages that match this name:
# apt-get install -t chimaera-backports linux-image-5.18.0-0
Note, selecting 'linux-image-5.18.0-0.deb11.4-rt-amd64-dbg' for regex 'linux-image-5.18.0-0'
Note, selecting 'linux-image-5.18.0-0.deb11.4-amd64-unsigned' for regex 'linux-image-5.18.0-0'
Note, selecting 'linux-image-5.18.0-0.deb11.4-amd64' for regex 'linux-image-5.18.0-0'
Note, selecting 'linux-image-5.18.0-0.deb11.4-amd64-dbg' for regex 'linux-image-5.18.0-0'
Note, selecting 'linux-image-5.18.0-0.deb11.4-cloud-amd64' for regex 'linux-image-5.18.0-0'
Note, selecting 'linux-image-5.18.0-0.deb11.4-cloud-amd64-dbg' for regex 'linux-image-5.18.0-0'
Note, selecting 'linux-image-5.18.0-0.deb11.4-rt-amd64-unsigned' for regex 'linux-image-5.18.0-0'
Note, selecting 'linux-image-5.18.0-0.deb11.4-rt-amd64' for regex 'linux-image-5.18.0-0'
Note, selecting 'linux-image-5.18.0-0.deb11.4-cloud-amd64-unsigned' for regex 'linux-image-5.18.0-0'
 linux-image-5.18.0-0.deb11.4-amd64 : Conflicts: linux-image-5.18.0-0.deb11.4-amd64-unsigned but 5.18.16-1~bpo11+1 is to be installed
 linux-image-5.18.0-0.deb11.4-amd64-unsigned : Conflicts: linux-image-5.18.0-0.deb11.4-amd64 but 5.18.16-1~bpo11+1 is to be installed
 linux-image-5.18.0-0.deb11.4-cloud-amd64 : Conflicts: linux-image-5.18.0-0.deb11.4-cloud-amd64-unsigned but 5.18.16-1~bpo11+1 is to be installed
 linux-image-5.18.0-0.deb11.4-cloud-amd64-unsigned : Conflicts: linux-image-5.18.0-0.deb11.4-cloud-amd64 but 5.18.16-1~bpo11+1 is to be installed
 linux-image-5.18.0-0.deb11.4-rt-amd64 : Conflicts: linux-image-5.18.0-0.deb11.4-rt-amd64-unsigned but 5.18.16-1~bpo11+1 is to be installed
 linux-image-5.18.0-0.deb11.4-rt-amd64-unsigned : Conflicts: linux-image-5.18.0-0.deb11.4-rt-amd64 but 5.18.16-1~bpo11+1 is to be installed
What is the one to be selected?
#5 2022-10-21 11:06:11
nixer
Try this,
apt install -t chimaera-backports linux-image-5.18.0-0.deb11.4-amd64
Then you may uninstall the default kernel if you wish, after a reboot of course.  The reboot should boot the new kernel, and you can verify this by running - after the reboot,
uname -a
#6 2022-10-21 12:15:33
migf
OK, that is it! wlan0 is now available and working, thanks a lot.
If I may put a related question: I am getting this in dmesg concerning the firmware of the Radeon GPU:
 [drm:amdgpu_pci_probe [amdgpu]] *ERROR* amdgpu requires firmware installed
[    3.067618] amdgpu: See https://wiki.debian.org/Firmware for information about missing firmware
Is there also a package for it, and is it recommended to add this firmware?
Thanks again!
#7 2022-10-21 14:23:46
I quit.
You need to target chimaera-backports for that package, just as you did for the individual kernel package.
The backported metapackge is needed. You will soon be running an outdated kernel with known vulnerabilities if you don't install it.
#8 2022-10-21 14:58:36
migf
@Head_on_a_Stick
Thanks for your tip: I have now the backported metapackage.
#9 2022-10-21 15:25:19
nixer
I learned something new today.  I will install it now so my kernel does not get left behind on the update process.
Thanks HOAS.
Edit:
migf,
The same would be true for the header files as well.
apt install -t chimaera-backports linux-headers-amd64
#10 2022-10-21 16:00:56
migf
Ok, done! Thanks again to both!
I will now mark this as solved.
