#1 2022-10-13 09:05:16
chomwitt
virt-manager 1:4.1.0-1 is broken in daedalus
Devuan GNU/Linux 5 (daedalus/ceres)
After  doing :
$ sudo apt-get update
$ sudo apt-get upgrade
$ virt-manager --debug
--if i try to 'open' the window of a virtual machine virt-manager
crashes with the following message:
(virt-manager:19736): libsoup-ERROR **: 08:54:50.904:
libsoup3 symbols detected. Using libsoup2 and libsoup3
in the same process is not supported.
$ sudo apt-cache policy virt-manager
virt-manager:
  Installed: 1:4.1.0-1
  Candidate: 1:4.1.0-1
how can i correct this?
I've checked https://tracker.debian.org/pkg/virt-manager
and bug reports upstream at the project's bug tracker
but i havent found something.
But in searching the interent i found arch related opened issues FS#75823 where the cause is said to be  libgovirt on which many applications depend
I've managed to connect to a running vm from the command line:
$ sudo virsh list --all
Id   Name               State
6    Hyperbola_min_vm   running
-    Devuan_vm          shut off
$ virt-viewer --connect qemu:///system 6
So the issue in my case dont seem related to virt-viewer
@ devuanwiki/Chomwitt
#2 2022-10-13 15:12:39
andyprough
Re: virt-manager 1:4.1.0-1 is broken in daedalus
Thanks for posting this, I won't update to this version. Please let us know if you get a point update that fixes it or if there's some obvious config change that's needed to fix it.
#3 2022-10-13 17:47:25
xinomilo
Unknown
no such problem here (same version - testing/ceres). not a single libsoup message in virt-manager --debug. vms window open/work normally as always.
i would say problem is on some virt-manager installed recommendation, and not on actual virt-manager. eg. check this bug, it's similar :
https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=1019339
maybe some gnome thingy(?)
