#1 2022-10-08 04:28:56
amc252
[SOLVED] optimized initramfs howto
Today I installed Debian Bookworm on a spare partition using the expert mode.
At some point, the installer offered the option to create an optimized initramfs containing only the needed module for the system. I accepted and the resulting initrd.img is 7.8 M as opposite of 27.5 M on Chimaera.
I googled around but couldn't find instructions as to how do that on my installed Chiamera.
Could anyone point me to an howto?
#2 2022-10-08 06:59:14
Re: [SOLVED] optimized initramfs howto
Read the MODULES section in
man initramfs.conf
Once the changes have been made regenerate the initramfs:
# update-initramfs -u -k all
EDIT: or try
dpkg-reconfigure initramfs-tools
But that's just a guess. I've never tried it and I'm not in De{vu,bi}an atm.
#3 2022-10-08 08:03:06
amc252
It seems to have worked.
I changed the value in /etc/initramfs-tools/conf.d/driver-policy to MODULES=dep and ran update-initramfs -u -k all.
The resulting initrd.img is 6.6 M instead of 27.5 M.
I rebooted and everything seems fine so far.
Thanks for the suggestion.
#4 2022-10-08 11:17:14
amc252 wrote:
... anyone point me to an howto?
Besides following HoaS' instructions, to may find this link (or parts of it) useful.
If you need udev, your minimization efforts will most likely be in vain.
#5 2022-10-08 15:49:08
amc252
Thanks.
Well, as far as I can tell, my system uses eudev and I can't see no problem so far. Everything works normally and the boot time was shorter.
#6 2022-10-09 13:04:25
That statement refers to Arch's udev hook. Debian does not use the same methods as Arch so the statement is irrelevant.
For the record I'm using a "minified" initramfs in my Arch box and even with zstd compression[0] it's still double the size of the OP's in this thread — klibc ftw!
[0] I prefer no compression with my images 'cos I have a hellafast hard drive.
#7 2022-10-09 13:39:24
... refers to Arch's udev hook.
Debian does not use the same methods as Arch ...
Indeed ...
I noted that after posting but forgot all about it.
Sorry about that.
... so the statement is irrelevant.
Quite so.
But I'm sure it had not escaped you that the OP had already answered my post.
And in doing so, gracefully pointed out the difference between Debian and Arch to me.
Nevertheless, thanks for your input.   8^D
