#1 2022-09-25 09:03:05
driver
Flatpak and ALSA
I want to use the Librewolf Flatpak and I can't get sound to work with ALSA. I was trying a year ago, fiddling with flatseal and gave up.
Please don't suggest to use the Librewolf apt repo instead. I will not.
#2 2022-09-25 11:49:54
Re: Flatpak and ALSA
The Librewolf Appimage has working sound using ALSA (the build from the apt repo does not, for whatever reason).
Maybe an option ... .
EDIT: Typo
#3 2022-09-25 13:13:26
https://www.reddit.com/r/linuxquestions … a_flatpak/
Disclaimer: I don't use flatpak so I have no personal experience of this issue.
#4 2022-09-25 13:42:01
driver
EDIT: Typo
You are right, I forgot about that. I read about the build from their apt repo not working with ALSA for some reason. I won't use the AppImage either, because I want the browser to be somewhat sandboxed.
I have to admit that I am not any wiser after reading this. The conclusion is it doesn't work? I only tried the whole flatpak thing again because I read some recent post or article that stated that flatpak works with ALSA now. After upgrading to Chimaera and therefore a more recent version of flatpak, I thought I should give it another try.
#5 2022-09-25 14:53:53
That is my understanding.
I'm using Arch, which has v1.14.0, and that pulls in xdg-desktop-portal & pipewire with it. I presume you have Recommends disabled (which isn't the best idea) because it looks like De{bi,vu}an's version should also bring in those packages in a sanely configured system (ie, one that has Recommends enabled by default).
#6 2022-09-25 15:35:22
driver
That sucks. I might end up installing pulseaudio, which I have blacklisted...
I decide on a case-by-case basis if I use --no-install-recommends. Completely disabling it is not for me. Pipewire was probably installed when I upgraded to Chimaera.
#7 2022-09-25 22:29:31
charliebrownau
Gday
I recommend using
* Built in repo (apt get/arch/etc)
* Portable tar.gz programs
* Appimage
Ive used LibreWolf appimage on multiple distros including ARCH and DEBIAN based and Dev1
I personally dont recommend CLOUD, DRM, Vendor Lockin , online appstores that 'require' login or internet
Download latest LibreWolf Appimage from
- mainpage - https://librewolf.net/installation/linux/
- git server - https://gitlab.com/librewolf-community/browser/appimage/-/releases
Current Appimage as of 26/Sept/2022
https://gitlab.com/api/v4/projects/24386000/packages/generic/librewolf/105.0.1-1/LibreWolf.x86_64.AppImage
My Video on Recommended Browsers
https://www.joshwhotv.com/video/.QGAkxw/recommended-web-browsers---may-2021
My Video on Installing LibreWolf
https://www.joshwhotv.com/video/.Q2d7nA/how-to-install-librewolf-browser-on-linux-04-aug-2022-charliebrownau
My Video on Linux portable programs
https://www.joshwhotv.com/video/.QDA9zg/charliebrownau---techie-stuff---linux-app-portablity---appimage---16-dec-2021
________
Regards
Charliebrownau
People's Republic of Australia
* Email           - charliebrownau@protonmail.com
* Website     - http://Charliebrownau.com/
* Video           - https://JoshwhoTV.com/channel/charliebrownau
* Social          - https://pieville.net/@charliebrownau
* Delta.Chat     - charliebrownau@joshwho.net
