Pages: 1
Latest upgrade broke Grub.
error:symbol 'grub_disk-native-sectors-not-found'
grub rescue>
I know the steps are on the web, Not sure about doing this.
It is a BIOS install. I'm posting from a live usb devuan.
I mounted boot partition to remove grub-efi-amd64 and reinstall grub-pc and get this
Setting up grub-pc (2.04-20) ...
/usr/sbin/grub-probe: error: failed to get canonical path of `overlay'.
dpkg: error processing package grub-pc (--configure):
installed grub-pc package post-installation script subprocess returned error exit status 1
grub-pc
E: Sub-process /usr/bin/dpkg returned an error code (1)nex step ?
You need to chroot into the system with the API filesystems mounted for that to work.
Either use Rescue Mode to obtain a shell in the installed system or run these commands from the live environment:
apt update
apt install arch-install-scripts
mount /dev/sdXY /mnt
mount /dev/sdXZ /mnt/boot
arch-chroot /mntReplace X, Y & Z with the drive letter and partition numbers for the root (/) and /boot partitions, respectively.
From a shell in the installed system run these commands to fix things:
dpkg-reconfigure grub-pc
grub-mkconfig -o /boot/grub/grub.cfgI presume you're running testing/unstable? You really should mention the version in the OP.
EDIT: and please replace the thread title with something useful (eg, "GRUB update lands at 'grub rescue>' prompt"). This is actually a common problem at the moment:
https://archlinux.org/news/grub-bootloa … ibilities/
If you had bothered to search before posting you would probably have found the solution more quickly.
Hold on, I missed this:
Why was grub-efi-amd64 installed?
The amd64 live isos have grub-efi-amd64 installed and the grub-pc deb package available inside the iso for bios boots. If the iso is booted in uefi mode, it installs grub-efi. If the iso is booted in bios mode, the installer will install grub-pc. If you boot in bios mode and chroot the installed system, you need to install the grub-pc package before running grub-install. It's in the root of the filesystem. So run dpkg -i /grub-pc*.deb before running grub-install.
If the iso is booted in bios mode and the disk has gpt partition table, the installer will warn you that you need a special partition for grub, at least 1mb with no filesystem and with flag bios_grub (in gparted) or ef03 (in gdisk).
Edit: Just after hitting Submit, I saw that the first message says this happened after an upgrade. Now I'm not sure if my answer if relevant.
Install is Chimaera stable, the update stopped at a screen that asked where and how to install the new grub. I selected sda1. I thought the motherboard settings were wrong.
Is Recovery mode the same as Rescue mode .
No.
I provided the link for a reason. Please read it.
The following string will be used as Linux parameters for the default │
│ menu entry but not for the recovery mode. │
│ Linux default command line: │
grub-mkconfig -o /boot/grub/grub.cfg_
following fsmithread
dpkg: error processing package grub-pc (--install):
Processing triggers for man-db (2.9.4-2) ...
grub-pcThe live usb has Failsafe but no Rescue Boot Option.
Just for clarification, is this a general problem with the latest upgrade of grub?
I've just been updating my legacy-bios Chimaera installation (using synaptic).
There are lots of upgrades available today, including one to grub-pc, from 2.04-20 to 2:06-3~deb11u1.
I've installed all the other upgrades.
Is this safe to install the grub upgrade or will it just give me a grub rescue> prompt and a headache?
Chimaera: Just tried the update on my laptop: Yes, the grub update will cause headaches. Acer Aspire 5 A515-44, efi only, encrypted LVM with unencrypted root. The installation worked on second try (had to enable rw for the efivarfs), creates a new debian entry in the efi, on reboot the grub rescue shell comes up with "symbol grub_disk_native_sectors not found".
When I use F12 to select my original entry devuan4 the laptop boots. Then I removed the debian, and now I am getting the error also on my devuan4.
Then use arch-chroot from the live environment, as I suggested in my first post.
Are you even reading replies?
Yes. Details on the Arch News item to which I linked. It's been all over the Arch forums recently.
Debian's 11.5 point release has an upgraded GRUB version, which is highly unusual. I'm not sure if that also has the problem.
I don't use GRUB myself...
Got my laptop fixed again. Booted the installer stick into rescue mode, chrooted into the encrypted system. To get that working I needed to load some Realtek firmware for wired network access. Took me a while to figure out that the stick I first used wasn't FAT formatted. The installer didn't like that.
# grub-install --bootloader-id=devuan4 --no-uefi-secure-boot
# update-grubThat fixed it for me.
Edith
Note to the public: in general probably a simple
# grub-install
# update-grubwill do the job.
I got fed up and reinstalled.
Thanks for all replies.
Pages: 1
