#1 2022-08-29 10:10:16
amaro
move Devuan to a bigger partition
Hello everybody!
Several months ago I wanted to test Devuan and installed it on a small partition (sda4).
I liked and want to keep it but the partition is full.
So now I want to move Devuan to a bigger partiton (sda3).
I have already installed it on the bigger partition.
In order to skip all the manual adjustments would it be enough to copy (rsync) /etc, /usr, /home directories?
If that is not enough what else needs to be done?
Thank you in advance!
p.s. Regarding the packages since I don't have copies of all of them in /var/cache/apt/archives/
I guess I will have to manually install them, right?
#2 2022-08-29 11:16:58
Re: move Devuan to a bigger partition
Can you not just backup the system (with rsync), blow away sda4, make sda3 bigger then copy the system back? It would need some adjustment to the bootloader & /etc/fstab but you wouldn't be left with a useless extra partition.
EDIT: or just copy sda4 to sda3 then delete sda4 and expand sda3 if you don't have a backup medium. But you really should have a backup anyway.
#3 2022-08-29 12:29:18
amaro
thank you, hoas!
that was my idea, though, I was not sure which directories can be skipped.
btw, skipping some of the directories is just to save some time because the current installation is 8,5GB.
#4 2022-08-29 12:59:11
I follow https://wiki.archlinux.org/title/Rsync# … tem_backup — that has a list of system directories which should be excluded (mostly the API filesystems). You would have to add your own exceptions for any other large files you don't want transferred.
/etc/fstab & GRUB for the new system can be configured with these commands run from sda4:
# apt install arch-install-scripts
# mount /dev/sda3 /mnt
# genfstab -U /mnt > /mnt/etc/fstab
# arch-chroot /mnt
[chroot]# dpkg-reconfigure grub-pc
[chroot]# grub-mkconfig -o /boot/grub/grub.cfg
[chroot]# exit
# umount /mnt
# apt purge arch-install-scripts # or keep it :-)
^ That presumes a non-UEFI system with only a single root (/) partition.
#5 2022-08-29 14:03:55
depending on the partition sizes, it could be an option to mount sda3 on "/home". Minimal effort and recommended anyway.
#6 2022-08-30 03:44:56
For the /home directory, I would use rsync -avh to copy files back to the new home.
But the system dir is another thing.  when you format or change a drive size it will get a new UUID, you'll need that for fstab and possibly grub.
blkid  and lsblk helps.
