#1 2022-08-27 04:20:02
grafiksinc
Debian Point Release Question (Solved)
Hello Forum....
Just a general question.....if Debian Releases a point release.
About how long does it take for that to make its way in to Devuan.... if at all..
Just curious....
Thank you ! In advance
#2 2022-08-27 09:11:30
Re: Debian Point Release Question (Solved)
Once released, I think you should be able to upgrade your system to it, & get all the new bits.
#3 2022-08-27 10:15:43
sgage
grafiksinc wrote:
Hello Forum....
Just curious....
A 'point release' in Debian simply means that they've updated the installation media to include all updates since the last point release (or original release). If you're doing a fresh install, this means less post-install updating to do. If you've been updating your system all along, you already have the point release. If you use the net install, it doesn't matter so much - at the end of the installation you have the latest updates of everything.
#4 2022-08-27 10:52:49
grafiksinc
Thank you guys makes sense... and does answer my question...
