#1 2022-08-24 21:52:31
unixdan22
[SOLVED] LUKS Full Disk Encryption
Hello,
what is the recommended way to setup LUKS FDE on Devuan on a BIOS/MBR machine?
I have created a unencrypted /boot and an encrypted LUKS partition for the system.
I cannot figure out how to boot the encrypted LUKS partition from GRUB. I tried creating the file /etc/crypttab and setting the cryptdevice and root parameters in /etc/default/grub (then updating grub and initramfs).
Thank you in advance!
#2 2022-08-25 01:49:49
Re: [SOLVED] LUKS Full Disk Encryption
FDE usually refers to a setup that has /boot part of the encrypted volume. I recommend using one of the live isos. Refractainstaller knows how to do it. I can never remember all the steps and the right words, which is why I put it into a script.
Tell the installer you want to encrypt the root partition and don't select a separate boot. Added bonus - don't select a swap partition and let the installer put a small swap file on the encrypted root partition.
If you would rather diagnose and fix your current situation, you probably should show us what's in crypttab, fstab, a menuentry from grub.cfg and whatever you put into /etc/default/grub. And maybe fdisk -l, too.
#3 2022-08-25 09:32:37
unixdan22
Thank you for the quick reply!
I will try it out with the installer from the live iso.
#4 2022-08-25 13:19:26
Any installer will do, there is nothing special to be done to make grub boot an encrypted root. I am using FDE with unencrypted /boot and an LVM in an encrypted partition for / and /swap for many years now, no issues. Legacy Bios or efi, mbr or gpt do not matter, all combinations work.
Cook book:
* I only use manual partitioning: p1 with 2048 MB for /boot, ext4; for p2 the encrypted partition I use 32G for / plus at least 32G for swap, i.e. 65535MB. Change these values to your demands.
* Select volume for encryption for p2. You have to enter a PW for the encryption.
* Select that volume and change it from ext4 to a physical volume for LVM.
* Define vg and logical volumes. Make one LV to /, ext4, the other one to swap.
* Write all to disk and continue with the installation. At the end the system should boot automagically and ask for the PW for decryption.
Manually setting everything up is a bit fidelly. There is a guide for guided setup at: https://www.devuan.org/os/documentation … encryption which is much easier.
Good luck, rolfie
#5 2022-09-07 09:30:46
unixdan22
Which partitioning software is it in this documentation?
#6 2022-09-07 09:34:05
unixdan22
I installed the encrypted system with refractainstaller and it worked!
First I tried without a separate /boot partition, but then I had to enter the disk password twice during boot: Once to start GRUB and then to boot Devuan. GRUB takes 17 seconds to decrypt which was very annoying.
Then I tried a different configuration with a separate /boot partition (also with refractainstaller), and it worked perfectly! GRUB starts without a password and I only have to enter the password to boot Devuan.
#7 2022-09-07 09:42:50
unixdan22
This is what the GRUB menu entry looks like:
menuentry 'Devuan GNU/Linux' --class devuan --class gnu-linux --class gnu --class os $menuentry_id_option 'gnulinux-simple-<system-uuid>' {
	load_video
	insmod gzio
	if [ x$grub_platform = xxen ]; then insmod xzio; insmod lzopio; fi
	insmod part_msdos
	insmod ext2
	set root='hd0,msdos2'
	if [ x$feature_platform_search_hint = xy ]; then
	  search --no-floppy --fs-uuid --set=root --hint-bios=hd0,msdos2 --hint-efi=hd0,msdos2 --hint-baremetal=ahci0,msdos2  <boot-uuid>
	else
	  search --no-floppy --fs-uuid --set=root <boot-uuid>
	fi
	echo	'Loading Linux 5.18.0-0.bpo.1-amd64 ...'
	linux	/vmlinuz-5.18.0-0.bpo.1-amd64 root=UUID=<system-uuid> ro  text iomem=relaxed
	echo	'Loading initial ramdisk ...'
	initrd	/initrd.img-5.18.0-0.bpo.1-amd64
How does the kernel know where to find the system-uuid? It is inside the LUKS partition. To see the UUID of the encrypted partition it would have to decrypt the LUKS partition first. How does it work?
#8 2022-09-07 12:43:15
I don't know the details of how it works, but grub has modules for crypto and for luks. Look under /boot/grub/.
Yeah, I almost warned you about the double password entry. It's very slow, too. I should have said that I recommend it if that's what you really want. Another way to make /boot secure is to remove it from the hard disk and put it on a usb stick. Then you can't boot without the stick. (also inconvenient.)
#9 2022-09-07 17:48:18
These are pictures taken from the standard installer in normal mode.
#10 2022-09-07 17:49:30
Have a look at /etc/crypttab. The contents of this file is one of the inputs for grub and the initramfs.
#11 2022-09-08 08:02:48
xinomilo
Unknown
a guide for FDE including /boot : https://cryptsetup-team.pages.debian.net/cryptsetup/encrypted-boot.html
#12 2022-09-09 10:31:09
unixdan22
I think having /boot unencrypted is not really an issue for me, because it does not contain any personal data anyway. Sorry if the title was misleading.
#13 2022-09-09 10:40:00
unixdan22
Right now I have an unencrypted swap partition. What is the best way to also encrypt that?
Should I create / and swap partitions inside an LVM as rolfie has suggested or is it possible to create a swap file on the encrypted file system?
#14 2022-09-10 16:31:14
The live installer would have made a swapfile in the root partition if you had not chosen to use the swap partition. So yes, it's possible to have a swapfile. To be sure, check to see if /swapfile already exists.
refractainstaller does the following, where bs=1024 and count=1048576:
        dd if=/dev/zero of=/target/swapfile bs="$swapfile_blocksize" count="$swapfile_count" ; check_exit
        mkswap /target/swapfile ; check_exit
        chmod 600 /target/swapfile
The values for bs and count are in /etc/refractainstaller in case anyone wants to change the size of the swapfile. Currently it's set to 256mb. And then you have to edit the swap entry in /etc/fstab. Mine looks like this:
/swapfile	none	swap	sw	0	0
#15 2022-09-11 09:14:44
unixdan22
I have created a swap file manually as you said and disabled the swap partition. But now the hibernate button in the XFCE logout menu is gone. How to enable hibernate with a swap file?
All the tutorials I found tell about installing and configuring the uswsusp package, but this package is missing in the Devuan repository.
#16 2022-09-11 10:18:23
I've never tried to hibernate with a swapfile. There is a uswsusp module in the pm-utils package. I have no idea how you would use it. (dpkg-reconfigure uswsusp won't work)
$ apt-file find uswsusp
pm-utils: /usr/lib/pm-utils/module.d/uswsusp
#17 2022-09-11 10:23:38
unixdan22
Does hibernate work with a swap partition inside an LVM?
#18 2022-09-11 10:56:35
Marjorie
It does on my PC (AMD5600G, Chimaera, emulated legacy boot, no encryption, kernel 5.18.0-0.deb11.4-amd64. RAID1).
I'm still finding hibernation a bit flaky - sometimes it attempt a reboot and I have to kill it with the power button (but then still resumes OK subsequently).
If you were to try to hibernate to a swapfile one obvious, bur solvable, problem is that you would have to make it significantly larger than 256Mb as it has to have space for what's in your RAM).
#19 2022-09-23 09:07:15
unixdan22
I have created an encrypted LVM with logical volumes for swap and root. /boot is unencrypted on another partition. /etc/crypttab and /etc/fstab look as follows.
/etc/crypttab:
lvm_crypt UUID=<luks-uuid> none luks
/etc/fstab:
/dev/vg00/lvol_devuan_swap	none	swap	sw	0	0
/dev/vg00/lvol_devuan_system	/	ext4	defaults,noatime	0	1
UUID=<boot-uuid>	/boot	ext4	defaults,noatime0	2
I had to update-initramfs -u -k all and update-grub.
Now it works without any problems! I can also hibernate and resume from the encrypted swap partition.
Thank you guys for all your help!
