This system is Devuan 4.0 Cinnamon. 5.18 kernel is installed (linux-image-5.18.0-0.bpo.1-amd64_5.18.2-1~bpo11+1_amd64.deb) because the hardware includes Realtek wireless RTL8821CE. Today the following was seen after executing "apt update, apt upgrade":
linux-image-5.10.0-9-amd64
Use 'sudo apt autoremove' to remove it.
linux-headers-5.10.0-17-amd64 linux-headers-5.10.0-17-common
linux-image-5.10.0-17-amd64
linux-compiler-gcc-10-x86 linux-headers-amd64 linux-image-amd64
linux-kbuild-5.10 linux-libc-dev
Why is Devuan worrying about a kernel that's not being used? Does Devuan keep two kernels, one for the current state of the distribution and another if a custom one was installed?
Keeping multiple kernels is generally viewed as a wise safety net measure. If one kernel fails often another allows you to recover or fix the problem. Multiple kernels are allowed and not automatically removed on Debian, Devuan, MXLinux, arch, manjaro, antiX, Sparky among others.
Pax vobiscum,
Mark Rabideau - ManyRoads
i3wm, bspwm, dkwm, dwm, hlwm, sway, openbox on Sid/ ceres ~ Linux #449130
Thanks for the response. Now I won't worry about overwriting 5.18.
If you need the backported kernel for hardware support then you need to install the metapackage:
# apt install -t beowulf-backports linux-image-amd64
^ That will remove the current 5.10 kernel and set the default to 5.18. You should still have old versions of 5.10 & 5.18 to boot into just in case.
EDIT: but an autoremove operation will delete them so be sure the new one works before running that.
@Head_on_a_Stick
"an autoremove operation will delete them so be sure the new one works before running that"
I found that out the hard way once when I thought the newer kernel was running properly, so I autoremoved the old kernel -- and the system kinda died. <chuckle>
