#1 2022-07-13 14:37:14
[ANNOUNCE] xorg-server 21.1.4
Good to know someone took over at X.Org.
Kudos to Kanapickas!  8^)
This release fixes 2 recently reported security vulnerabilities in xkb, several
regressions since 1.20.x and a number of miscellaneous bugs.
Błażej Szczygieł (1):
       present: Check for NULL to prevent crash
Jeremy Huddleston Sequoia (23):
       rootless: Dead code removal (ROOTLESS_REDISPLAY_DELAY is already defined)
       X11Application: Ensure TIS operations are done on the main thread
       os/connection: Improve abstraction for launchd secure sockets
       xquartz: Create a separate category for organizing user preferences
       xquartz pbproxy: Adopt NSUserDefaults+XQuartzDefaults for preferences
       xquartz: Fold spaces related preferences into NSUserDefaults+XQuartzDefaults
       XQuartz: Ensure scroll events are delivered to a single window (not both X11 and AppKit)
       meson: Bump requirement to meson-0.50.0
       xquartz: Update Sparkle configuration to use SUPublicEDKey
       xquartz: Update copyright for 2022
       meson: Provide options to set CFBundleVersion and CFBundleVersionString in XQuartz
       Revert "meson: Bump requirement to meson-0.50.0"
       xquartz: Update autotools-based builds of XQuartz to account for recent changes
       print_edid: Fix a format string error
       xf86-input-inputtest: Fix build on systems without SOCK_NONBLOCK
       tests: Fix build failure from missing micmap.c
       meson: Support building Xnest and Xorg on darwin
       XQuartz: Build the bundle trampoline when using meson
       XQuartz: Add TCC reason keys to Info.plist
       xquartz: Use correct defines when building to support Sparkle updates
       xquartz: Fix a possible crash when editing the Application menu due to mutaing immutable arrays
       XQuartz: Improve type safety for X11Controller's application menu editor
       xquartz: Add missing files to distribution tarball
Olivier Fourdan (1):
       render: Fix build with gcc 12
Peter Hutterer (3):
       xkb: switch to array index loops to moving pointers
       xkb: swap XkbSetDeviceInfo and XkbSetDeviceInfoCheck
       xkb: add request length validation for XkbSetGeometry
Povilas Kanapickas (5):
       Revert "os: Try to discover the current seat with the XDG_SEAT var first"
       dix: Correctly save replayed event into GrabInfoRec
       dix: Don't send touch end to clients that do async grab without touches
       xfree86: Fix event data alignment in inputtest driver
       xserver 21.1.4
Samuel Thibault (1):
       xkb: fix XkbSetMap when changing a keysym without changing a keytype
git tag: xorg-server-21.1.4
https://xorg.freedesktop.org/archive/in … 1.4.tar.gz
SHA256: cbd5a1f75881e8a341823e51e489281aee0912c7023b4eed170b26b18f617e36  xorg-server-21.1.4.tar.gz
SHA512: 6e15d5c7f2a63f72688d3b04c3493271f419a69ce4b0c412a14293c40463733e050beb594689f27e5048b2356ce8f5b84aae96dad4a422054b36393d2f3d1847  xorg-server-21.1.4.tar.gz
PGP:  https://xorg.freedesktop.org/archive/in … tar.gz.sig
https://xorg.freedesktop.org/archive/in … 1.4.tar.xz
SHA256: 5cc4be8ee47edb58d4a90e603a59d56b40291ad38371b0bd2471fc3cbee1c587  xorg-server-21.1.4.tar.xz
SHA512: eb5b8520d02908f72719e6ecfbf7a9bf139acb65ccae04d1db4223a8a2384cd3a94bd5afef10cce327b751b800cc2b79bfaa5ae35c95c3a217f775168082e68f  xorg-server-21.1.4.tar.xz
PGP:  https://xorg.freedesktop.org/archive/in … tar.xz.sig
O.
