#1 2022-06-26 04:33:46
Phil
LXQT Problem
Is anyone having a problem using the Lxpanel task manager? I have run into a problem which looks like a repeat of https://github.com/lxqt/lxqt-panel/issues/1600 It was supposed to be fixed but I am running the unstable version of Devuan and I cannot get the task manager popup to work correctly. By playing with it I found a way to make it work by using the right button to first click on a task manager item them adding a left click but it shouldn't work like that.
Phil
#2 2022-06-26 17:23:59
deepforest
Re: LXQT Problem
Yes, same here. Just tested on my Devuan Ceres (unstable) If items on taskbar grouped and minimized i cant select it.
https://streamable.com/nnldqn
smile
#3 2022-07-01 03:43:20
Phil
Re: LXQT Problem
I am trying to use the bug report tool to report this problem, however it doesn't seem to be working correctly.
Phil
