#1 2022-06-24 07:11:49
SpongeBOB
how to not install additional package when doing apt purge !?
on another VM I did a apt purge slim
and it just removed slim.
now when I try the same command on another vm I got
  libck-connector0
Use 'apt autoremove' to remove it.
  liblightdm-gobject-1-0 lightdm lightdm-gtk-greeter task-desktop
  task-xfce-desktop tasksel tasksel-data
Suggested packages:
  accountsservice xserver-xephyr
Recommended packages:
  gnome-themes-extra cups
  slim*
  task-desktop task-xfce-desktop tasksel tasksel-data
4 upgraded, 3 newly installed, 1 to remove and 143 not upgraded.
Need to get 463 kB of archives.
After this operation, 1,017 kB of additional disk space will be used.
So weird that it will force install
liblightdm-gobject-1-0 lightdm lightdm-gtk-greeter task-desktop task-xfce-desktop tasksel tasksel-data
is this necessary to get rid of slim ?????
I've tried apt --no-install-recommends purge slim but that do not work either...
#2 2022-06-24 07:40:58
SpongeBOB
Re: how to not install additional package when doing apt purge !?
if I reply Yes I got this -->
But I don't want any Login manager !!
#3 2022-06-24 08:24:26
Maybe, install xinit/startx (can't remember exact package name), then purge slim - the package manager knows that you have X installed & is trying to be 'helpful' by not breaking it, I expect.
#4 2022-06-25 06:00:27
SpongeBOB
Thank you @Camtaf,
apt...
Camtaf wrote:
... is trying to be 'helpful' by not breaking it, I expect.
But I don't think that menu as been generated by apt it self right ?
So from where come this menu (screenshot) ? and why ? and why not have the possibility (like before) to not have any GUI Login manager ?
#5 2022-06-25 07:51:34
SpongeBOB
what's weird too is that if I select
slim on this menu
it's anyway installing lightdm
$ cat /etc/X11/default-display-manager
/usr/sbin/lightdm
#6 2022-06-25 08:01:40
There is a metapackage installed that has x-display-manager listed as a (virtual) dependency. If slim is removed lightdm is needed to satisfy the dependency.
If you prefer (for example) GDM instead use
# apt install slim- gdm3
But you don't need to remove slim at all — just disable it:
# update-rc.d slim disable
This will have to be repeated if the slim package is updated.
To actually remove slim see https://forums.debian.net//viewtopic.php?f=16&t=104157, which explains how to deal with the metapackage problem.
#7 2022-06-25 08:38:02
SpongeBOB
Thank you @Head_on_a_Stick,
work perfectly ! Thanks.
Talking about metapackage I've seen a bug (when apt want to remove a lot of package for no reason) I will try to reproduce and open another topic.
