#1 2022-06-23 01:00:16
deepforest
[SOLVED] XFCE Nofitication style was broken after installing i3wm
after installing i3wm, xfce volume bar was replaced by i3 volume bar, how restore default xfce volume bar
screenshots here
https://imgur.com/a/H3OuBUt
this not help
sudo apt reinstall xfce4-pulseaudio-plugin
sudo apt reinstall pavucontrol
sudo apt reinstall xfce4-indicator-plugin
also reinstalled xfce4-notifyd, not help
https://imgur.com/a/TXncrzQ
smile
pyzNi 3.14zDa! smile
#2 2022-06-23 01:41:17
deepforest
Re: [SOLVED] XFCE Nofitication style was broken after installing i3wm
Solved
this magic helped
sudo apt remove notification-daemon dunst xfce4-notifyd --purge && sudo apt autoremove && sudo apt install notification-daemon xfce4-notifyd && sudo apt remove notify-osd --purge
smile
