#1 2022-06-22 18:19:39
Giorgos
Install a KDE program, without KUserFeedback?
Hi.
Is there any way to install a KDE program, without installing the KUserFeedback package?
Although I'm using XFCE nowadays, there are some KDE programs I like (eg. K3b), but seems impossible to install them, without installing the infamous spyware KUserFeedback. It seems to be a requirement, to everything KDE related at repositories.
TIA.
#2 2022-06-22 19:44:51
Re: Install a KDE program, without KUserFeedback?
Well, I have installed KMyMoney which is a KDE application, and no trace of KUserFeedback. Did not even use anything like --no-install-recommends.
You might try that option when installing K3b via apt.
Good luck, rolfie
#3 2022-06-23 15:02:12
Giorgos
THANKS rolfie!!!
I'll try it.
