#1 2022-06-18 17:56:32
MiyoLinux
Using the Pragha Music Player with only alsa
I realize that this may not be of much use to very many people, but I thought that I would post it just in case it may help someone.
My favorite GUI music player is Pragha. However, if you install it on an "alsa-only" system, it won't play out-of-the-box.
When looking at the recommended packages, it only recommends gstreamer1.0-plugins-good and gstreamer1.0-pulseaudio. Both will be included in a "normal" installation of Pragha.
You can safely remove gstreamer1.0-pulseaudio after the installation. wink tongue
Anyway...back to the topic. It won't play on an alsa-only system after installation.
To get it to work, you will need to also install gstreamer1.0-plugins-bad...even though it's not listed as a recommended package.
After installing that, and you have Pragha set to use alsa, it works perfectly. smile
#2 2022-06-19 08:36:33
Re: Using the Pragha Music Player with only alsa
Like it!
Even though I don't use it, (never actually heard of it, but might give it a try).
Thanks for posting the solution.
