#1 2022-06-07 14:01:38
SpongeBOB
[SOLVED] Can we run .Appimage out of the box ?
Hi everyone,
Just be curiosity (because I'm not sure that I will ever use Appimage on the long run, see -> https://dev1galaxy.org/viewtopic.php?pid=36176#p36176)
Can we launch an x.Appimage out of the box with Devuan ? because I just dw https://apprepo.de/appimage/atom
Placed it to /home/me/Desktop/ tried to run it but nothing happen (it has has 0777 )
Any ideas ?
Thanks
#2 2022-06-07 15:46:11
Re: [SOLVED] Can we run .Appimage out of the box ?
Yes, appimages should work in devuan. I just tested the musescore I downloaded in 2017 for jessie, and it still runs on beowulf. I did not have to install anything special.
0755 should be sufficient for the permissions.
Try running it from a terminal to see if you get any useful messages. That might be helpful for the developer of this alpha software.
#3 2022-06-08 06:20:42
SpongeBOB
Thank you @fsmithred,
here what I got from the terminal ( ~/Desktop )
. Atom.AppImage
bash: .: Atom.AppImage: cannot execute binary file
I'm Running Duvean Chimaera 4.0
Does someone have the link of a working .Appimage to se if it run on my system and therefore see if it's was Atom.Appimage that was buggy or my system
Thanks
#4 2022-06-08 10:48:00
If you're in the same directory as the appimage, the correct command to start it would be
./Atom.AppImage
. Atom.AppImage is the same as source Atom.AppImage which won't work on binary files.
See 'help source' in a bash terminal for more info.
#5 2022-06-08 11:01:42
sgage
. Atom.AppImage
Thanks
I occasionally run the balenaEtcher appimage without issue (it is a USB writer). There's a download button on their home page:
https://www.balena.io/etcher/
It downloads a zip file containing the appimage.
#6 2022-06-08 12:32:20
Ogis1975
I have already downloaded android-file-transfer, music player Museeks, picture viewer Nomacs and file manager DoubleCMD.  These programs work great.
            ----+- Peter Kropotkin -+----
#7 2022-06-12 04:38:13
charliebrownau
Gday
99% of appimages work with Dev1 from my experience
SMplayer appimage does NOT work thou
Appimages that do work
- LibreWolf - browser
- Delta chat - messager
- leafpad - text editor
- Libre office - Office Suite
- Ungoogled chromium - browser
- Shortcut - video editor
