#1 2022-05-29 17:24:14
EDX-0
[SOLVED] webp thumbnailer
as per the title i'm trying to get a webp thumbnailer working with pcmanfm.
i put the following inside ~/.local/share/thumbnailers/webp.thumbnailer
[Thumbnailer Entry]
Version=1.0
Encoding=UTF-8
Type=X-Thumbnailer
Name=webp Thumbnailer
MimeType=image/webp;
Exec=/usr/bin/convert %i -thumbnail %s %o
and it doesn't work
i even put this inside ~/.local/share/mime/image/webp.xml
<?xml version="1.0" encoding="utf-8"?>
<mime-type xmlns="http://www.freedesktop.org/standards/shared-mime-info" type="image/webp">
  <!--Created automatically by update-mime-database. DO NOT EDIT!-->
  <comment>WebP file</comment>
  <icon name="image"/>
  <glob-deleteall/>
  <glob pattern="*.webp"/>
</mime-type>
and nothing, webp images inside pcmanfm still show the generic image icon
i'm on pcmanfm 1.3.2-1 with tumbler 4.16.0-1 on devuan ceres.
nevermind, i figured it out, pcmanfm uses gdk-pixbuf for images and doesn't really query thumbler for that, so it needs a webp loader for gdk-pixbuf, i'm lazy and don't use any other software that depends on gdk-pixbuf for the images so i just switched to thunar.
