#1 2022-05-28 13:54:53
rmrichesjr
pkgmaster.devuan.org quit serving chimaera updates?
It appears pkgmaster.devuan.org has quit serving chimaera updates.  What is the recommended replacement?
When I installed chimaera last December, this line in the original /etc/apt/sources.list referred to pkgmaster:
    deb http://pkgmaster.devuan.org/merged chimaera-security main contrib non-free
I'm using apt-cacher-ng, so I adapted it to this:
    deb http://127.0.0.1:3142/pkgmaster.devuan.org/merged chimaera-security main contrib non-free
That had been working great through May 7.  On May 14, 21, and 28 (today), I get this when attempting "apt-get update":
Hit:1 http://127.0.0.1:3142/deb.devuan.org/merged chimaera InRelease
Err:2 http://127.0.0.1:3142/pkgmaster.devuan.org/merged chimaera-security InRelease
  Connection failed [IP: 127.0.0.1 3142]
Hit:3 http://127.0.0.1:3142/deb.devuan.org/merged chimaera-updates InRelease
Hit:4 http://127.0.0.1:3142/deb.devuan.org/merged chimaera-backports InRelease
W: Failed to fetch http://127.0.0.1:3142/pkgmaster.devuan. … /InRelease  Connection failed [IP: 127.0.0.1 3142]
W: Some index files failed to download. They have been ignored, or old ones used instead.
Is deb.devuan.org the recommended replacement for pkgmaster.devuan.org?  Or, is there a different recommended replacement?
#2 2022-05-28 13:56:47
rmrichesjr
Re: pkgmaster.devuan.org quit serving chimaera updates?
Oh, as far as I'm aware, I'm using IPv4 exclusively.  I disabled IPv6 during post-installation tuning.
#3 2022-05-28 14:49:02
You should use deb.devuan.org/merged, see https://www.devuan.org/os/packages
Does its job for me.
#4 2022-05-28 15:54:53
rmrichesjr
Thanks for the extremely quick reply!  That appears to work for me, too.
