#1 2022-05-10 17:09:36
draden
OPENVPN - Setting up service for a given user
My aim is to forget the use of sudo / su command for starting openvpn service on Devuan. Running it so has the possibility for some hostile parties to gain control of its terminal session -which is unlikely- but I would like to make it a way more secure.
For the first step I'd create a user with only access to /etc/openvpn:
sudo adduser vpnhandler
sudo chown -R vpnhandler:vpnhandler /etc/openvpn
Then it would be great to set it up as a service which is auto-started by vpnhandler so I don't have to type openvpn xxxxx.ovpn in the terminal every time with that user.
Can someone help me with this? I'm open to any idea.
#2 2022-05-19 11:21:18
czeekaj
Re: OPENVPN - Setting up service for a given user
you'll have to move openvpn from /sbin into /usr/local/bin
I'd suggest trying to use network manager or some user side application with VPN support.
As of now I have not tried and always ran it as root.
Potentially you can try experimenting with firejail or fakeroot .
