#1 2022-05-07 03:45:43
erdos
[SOLVED] libreoffice fails to launch in Devuan 4.0
hi,  i'm on devuan 4.0 with XFCE DE and have libreoffice installed.
when i choose 'libreoffice writer' or 'libreoffice calc' in the XFCE menu, nothing happens.
what gives?
#2 2022-05-07 10:11:09
alexkemp
Re: [SOLVED] libreoffice fails to launch in Devuan 4.0
I'm using that same version both for OS & DE. LO boots fine via the xfce menu.
$ lsb_release -a
No LSB modules are available.
Distributor ID:	Devuan
Description:	Devuan GNU/Linux 4 (chimaera)
Release:	4
Codename:	chimaera
$ uname -a
Linux ng3 5.16.0-0.bpo.4-amd64 #1 SMP PREEMPT Debian 5.16.12-1~bpo11+1 (2022-03-08) x86_64 GNU/Linux
$ /usr/bin/soffice --version
LibreOffice 7.3.3.1 30(Build:1)
$ locate .desktop | fgrep office
/usr/share/applications/libreoffice-calc.desktop
/usr/share/applications/libreoffice-draw.desktop
/usr/share/applications/libreoffice-impress.desktop
/usr/share/applications/libreoffice-math.desktop
/usr/share/applications/libreoffice-startcenter.desktop
/usr/share/applications/libreoffice-writer.desktop
/usr/share/applications/libreoffice-xsltfilter.desktop
The launch files are horribly long, but here it is (you will need to give some sort of trouble-shooting after this to receive further help):
$ cat /usr/share/applications/libreoffice-calc.desktop
# This file is part of the LibreOffice project.
# This Source Code Form is subject to the terms of the Mozilla Public
# License, v. 2.0. If a copy of the MPL was not distributed with this
# file, You can obtain one at http://mozilla.org/MPL/2.0/.
# This file incorporates work covered by the following license notice:
#   Licensed to the Apache Software Foundation (ASF) under one or more
#   contributor license agreements. See the NOTICE file distributed
#   with this work for additional information regarding copyright
#   ownership. The ASF licenses this file to you under the Apache
#   License, Version 2.0 (the "License"); you may not use this file
#   except in compliance with the License. You may obtain a copy of
#   the License at http://www.apache.org/licenses/LICENSE-2.0 .
[Desktop Entry]
Version=1.0
Terminal=false
Icon=libreoffice-calc
Type=Application
Categories=Office;Spreadsheet;
Exec=libreoffice --calc %U
MimeType=application/vnd.oasis.opendocument.spreadsheet;application/vnd.oasis.opendocument.spreadsheet-template;application/vnd.sun.xml.calc;application/vnd.sun.xml.calc.template;application/msexcel;application/vnd.ms-excel;application/vnd.openxmlformats-officedocument.spreadsheetml.sheet;application/vnd.ms-excel.sheet.macroEnabled.12;application/vnd.openxmlformats-officedocument.spreadsheetml.template;application/vnd.ms-excel.template.macroEnabled.12;application/vnd.ms-excel.sheet.binary.macroEnabled.12;text/csv;application/x-dbf;text/spreadsheet;application/csv;application/excel;application/tab-separated-values;application/vnd.lotus-1-2-3;application/vnd.oasis.opendocument.chart;application/vnd.oasis.opendocument.chart-template;application/x-dbase;application/x-dos_ms_excel;application/x-excel;application/x-msexcel;application/x-ms-excel;application/x-quattropro;application/x-123;text/comma-separated-values;text/tab-separated-values;text/x-comma-separated-values;text/x-csv;application/vnd.oasis.opendocument.spreadsheet-flat-xml;application/vnd.ms-works;application/clarisworks;application/x-iwork-numbers-sffnumbers;application/x-starcalc;
Name=LibreOffice Calc
GenericName=Spreadsheet
GenericName[af]=Sigblad
GenericName[am]=ሰንጠረዥ
GenericName[ar]=جدول مُمتد
GenericName[as]=স্প্ৰেডশ্বীট
GenericName[ast]=Fueya de cálculu
GenericName[be]=Разліковы аркуш
GenericName[bg]=Електронна таблица
GenericName[bn]=স্প্রেডশীট
GenericName[br]=Renkell
GenericName[bs]=Proračunska tablica
GenericName[ca]=Full de càlcul
GenericName[ca_valencia]=Full de càlcul
GenericName[cs]=Sešit
GenericName[cy]=Taenlen
GenericName[da]=Regneark
GenericName[de]=Tabellendokument
GenericName[dz]=ཤོག་ཁྲམ།
GenericName[el]=Υπολογιστικό φύλλο
GenericName[en]=Spreadsheet
GenericName[en_GB]=Spreadsheet
GenericName[en_ZA]=Spreadsheet
GenericName[eo]=Kalkultabelo
GenericName[es]=Hoja de cálculo
GenericName[et]=Tabelarvutus
GenericName[eu]=Kalkulu-orria
GenericName[fa]=صفحهگسترده
GenericName[fi]=Taulukkolaskenta
GenericName[fr]=Classeur
GenericName[ga]=Scarbhileog
GenericName[gd]=Cliath-dhuilleag
GenericName[gl]=Folla de cálculo
GenericName[gu]=સ્પ્રેડશીટ
GenericName[gug]=Kuatia Kálkulo Peguarã
GenericName[he]=גיליון אלקטרוני
GenericName[hi]=स्प्रेडशीट
GenericName[hr]=Proračunska tablica
GenericName[hu]=Munkafüzet
GenericName[id]=Lembar Sebar
GenericName[is]=Töflureiknir
GenericName[it]=Foglio elettronico
GenericName[ja]=表計算ドキュメント
GenericName[ka]=Spreadsheet
GenericName[kk]=Электрондық кесте
GenericName[km]=សៀវភៅបញ្ជី
GenericName[kmr_Latn]=Tabloya Hesêb
GenericName[kn]=ಸ್ಪ್ರೆಡ್ಶೇಟ್
GenericName[ko]=스프레드시트
GenericName[lt]=Skaičiuoklė
GenericName[lv]=Izklājlapa
GenericName[mk]=Табеларна пресметка
GenericName[ml]=സ്പ്രെഡ്ഷീറ്റ്
GenericName[mn]=Хүснэгт баримт
GenericName[mr]=स्प्रेडशीट्
GenericName[nb]=Regneark
GenericName[ne]=स्प्रेडसीट
GenericName[nl]=Werkblad
GenericName[nn]=Rekneark
GenericName[nr]=Spreadsheet
GenericName[nso]=Letlakala-kalo
GenericName[oc]=Classador
GenericName[om]=Wardii
GenericName[or]=Spreadsheet
GenericName[pa_IN]=ਸਪਰੈੱਡ ਸ਼ੀਟ
GenericName[pl]=Arkusz kalkulacyjny
GenericName[pt]=Folha de cálculo
GenericName[pt_BR]=Planilha
GenericName[ro]=Foaie de calcul
GenericName[ru]=Электронная таблица
GenericName[rw]=Urupapurotuzu
GenericName[si]=පැතුරුම්පත
GenericName[sk]=Tabuľkový dokument
GenericName[sl]=Preglednica
GenericName[sr]=Таблица
GenericName[sr_Latn]=Tablica
GenericName[ss]=Liphephacansi
GenericName[st]=Spreadsheet
GenericName[sv]=Kalkylblad
GenericName[szl]=Archa kalkulacyjno
GenericName[ta]=விரிதாள்
GenericName[te]=స్ర్పెడ్ షీట్
GenericName[tg]=Spreadsheet
GenericName[th]=ตารางคำนวณ
GenericName[tn]=Letlharephatlalalo
GenericName[tr]=Hesap Tablosu
GenericName[ts]=Spreadsheet
GenericName[ug]=ئېلېكترونلۇق جەدۋەل
GenericName[uk]=Електронна таблиця
GenericName[uz]=Elektro jadval
GenericName[ve]=Spreadsheet
GenericName[vi]=Bảng tính
GenericName[xh]=Spreadsheet
GenericName[zh_CN]=电子表格
GenericName[zh_TW]=試算表
GenericName[zu]=Ikhasi lokubala
Comment=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[af]=Doen berekening, analiseer inligting en bestuur lyste in sigblaaie met Calc.
Comment[am]=ሂሳቦችን ያስሉ መረጃዎችን ይመርምሩ እና ያስተዳድሩ lists in spreadsheets by using Calc.
Comment[ar]=أنجز العمليات الحسابية، وحلِّل المعلومات وأدر القوائم في الجداول المُمتدة باستخدام كالك.
Comment[as]=Calc ব্যৱহাৰ কৰি স্প্ৰেডশ্বিটসমূহত গণনাসমূহ কৰক, তথ্য বিশ্লেষণ কৰক আৰু তালিকাসমূহ ব্যৱস্থাপনা কৰক।
Comment[ast]=Facer cálculos, analizar información y editar llistes en fueyes de cálculu con Calc.
Comment[be]=Праводзьце вылічэнні, аналізуйце інфармацыю і кіруйце спісамі ў разліковых аркушах з дапамогаю Calc.
Comment[bg]=С Calc можете да извършвате изчисления, да анализирате информация и да организирате списъци в електронни таблици.
Comment[bn]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[br]=Ober jedadurioù, dezrannañ stlennoù hag ardeiñ rolladoù er renkelloù dre ober gant Calc.
Comment[bs]=Izračunavanje, analiziranje informacija i upravljanje listama u unakrsnim tabelama koristeći Calc.
Comment[ca]=Feu càlculs, analitzeu informació i gestioneu llistes en fulls de càlcul amb el Calc.
Comment[ca_valencia]=Feu càlculs, analitzeu informació i gestioneu llistes en fulls de càlcul amb el Calc.
Comment[cs]=Calc umožňuje vytvářet a spravovat tabulkové seznamy a provádět na těchto datech výpočty a analýzu informací.
Comment[cy]=Cyfrifo, dadansoddi data a rheoli rhestrau mewn taenlenni gan ddefnyddio Calc.
Comment[da]=Udfør beregning, analyser information og administrer lister i regneark ved brug af Calc.
Comment[de]=Berechnungen ausführen, Informationen analysieren und Listen in Tabellendokumenten verwalten – Calc macht's möglich.
Comment[dz]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[el]=Εκτέλεση υπολογισμών, ανάλυσης πληροφοριών και διαχείρισης λιστών σε υπολογιστικά φύλλα με τη χρήση του Calc.
Comment[en]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[en_GB]=Perform calculations, analyse information and manage lists in spreadsheets using Calc.
Comment[en_ZA]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[eo]=Kalkuladi, analizi informojn kaj administri listojn en kalkultabeloj per Tabelilo.
Comment[es]=Realice cálculos, analice información y maneje listas en hojas de cálculo con Calc.
Comment[et]=Calc võimaldab arvutustabelite abiga teha arvutusi, analüüsida teavet ja hallata loendeid.
Comment[eu]=Kalkuluak egin, informazioa aztertu eta kalkulu-orrietako zerrendak kudeatu Calc erabiliz.
Comment[fa]=با محاسب، اطلاعات موجود در صفحات گسترده را تحلیل کنید، فهرستها را اداره کنید و محاسبات انجام دهید.
Comment[fi]=Calcin avulla voit tehdä laskutoimituksia, analysoida tietoja ja hallita listoja laskentataulukoissa.
Comment[fr]=Calc - Calculs, analyses et gestion de listes dans des feuilles de calcul.
Comment[ga]=Déan ríomhaireacht, déan anailís agus bainistigh liostaí i scarbhileoga trí úsáid a bhaint as Calc.
Comment[gd]=Dèan àireamhachd, mion-sgrùd fiosrachadh is rianaich liostaichean ann an cliath-dhuilleagan le Calc.
Comment[gl]=Facer cálculos, analizar información e xestionar listas en follas de cálculo con Calc.
Comment[gu]=કૅલ્ક વડે સ્પ્રેડશીટમાં ગણતરીઓ, માહીતી પૃથ્થકરણ અને યાદીઓ બનાવો.
Comment[gug]=Rejapo kálkulo, analice informacíon ha sambyhy listas en kuatia kálkulo peguarã reipuru jave Calc.
Comment[he]=ביצוע חישובים, ניתוח מידע וניהול רשימות בגיליונות אלקטרוניים באמצעות Calc.
Comment[hi]=गणना करता है, सूचना विश्लेषण करता है, और Calc के प्रयोग से स्प्रेडशीट में सूची प्रबंधित करता है.
Comment[hr]=Izvedite proračune, analizirajte informacije i upravljajte popisima u proračunskim tablicama koristeći Calc.
Comment[hu]=Számítások végrehajtása, adatok elemzése és listák kezelése munkafüzetekben a Calc használatával.
Comment[id]=Melakukan perhitungan, menganalisa informasi dan mengelola senarai pada lembar sebar menggunakan Calc.
Comment[is]=Gera útreikninga, greina gögn og meðhöndla lista í töflureikni með því að nota Calc.
Comment[it]=Calc può essere usato per eseguire calcoli, analizzare informazioni e gestire elenchi nei fogli elettronici.
Comment[ja]=Calcを使用して、スプレッドシートで計算を実行し、情報を分析し、リストを管理します。
Comment[ka]=ასრულებს კალკულაციას, აანალიზებს ინფორმაციას და მართავს სიებს ცხრილებში Calc-ის გამოყენებით.
Comment[kk]=Calc көмегімен есептерді шығару, ақпаратты анализдеу және электрондық кестелерде тізімдерді басқаруды орындауға болады.
Comment[km]=ធ្វើការគណនា វិភាគព័ត៌មាន និងគ្រប់គ្រងបញ្ជីក្នុងសៀវភៅបញ្ជី ដោយប្រើ Calc ។
Comment[kmr_Latn]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[kn]=Calc ಅನ್ನು ಬಳಸಿಕೊಂಡು ಲೆಕ್ಕವನ್ನು ಮಾಡಿ, ಮಾಹಿತಿಯನ್ನು ವಿಶ್ಲೇಷಿಸಿ, ಹಾಗೂ ಸ್ಪ್ರೆಡ್ಶೀಟ್ನಲ್ಲಿನ ಪಟ್ಟಿಗಳನ್ನು ನೋಡಿಕೊಳ್ಳಿ.
Comment[ko]=캘크를 사용하여 스프레드시트에서 계산, 정보 분석 및 목록 관리를 수행합니다.
Comment[lt]=Skaičiuokle galima atlikti įvairius skaičiavimus, analizuoti informaciją, tvarkyti sąrašus lentelėse.
Comment[lv]=Veikt aprēķinus, analizēt informāciju un pārvaldīt sarakstus izklājlapās, lietojot Calc.
Comment[mk]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[ml]=കണക്കുകൂട്ടലുകള്, കാല്ക് ഉപയോഗിച്ച് വിവരങ്ങള് അവലോകനം ചെയ്യുകയും സ്പ്രെഡ്ഷീറ്റിലെ ലിസ്റ്റ് കൈകാര്യം ചെയ്യുകയും ചെയ്യാം.
Comment[mn]=Төлбөрийн тооцоо хийх, Мэдээлэлүүдийг шинжлэн судлах ба Хүснэгт баримт бичигт жагсаалтуудыг журамлах - Хүснэгт баримт энэ боломжийг бүгдэд олгоно.
Comment[mr]=Calc चा वापर करून स्प्रेडशीट् अंतर्गत गणना, माहिती विश्लेषण व यादी व्यवस्थापीत करा.
Comment[nb]=Utfør beregninger, analyser informasjon og håndter lister i regneark ved å bruke Calc.
Comment[ne]=Calc को प्रयोगद्वारा स्प्रेडसिटहरूमा गणना कार्यसम्पादन, सूचना विश्लेषण र सूचीहरू प्रबन्ध गर्नुहोस्।
Comment[nl]=Met Calc kunt u in werkbladen berekeningen uitvoeren, gegevens analyseren en lijsten beheren.
Comment[nn]=Med Calc kan du gjera utrekningar, analysera informasjon og handsama lister i rekneark.
Comment[nr]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[nso]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[oc]=Calc - Calculs, analisis e gestion de listas dins de fuèlhs de calcul.
Comment[om]=Calc fayyadamuun herrega hojjedhu, odeeffannoo xiinxali, tarreewwan wardii keessaa taligi.
Comment[or]=Calc ବ୍ୟବହାର କରି ସ୍ପ୍ରେଡ୍ସିଟରେ ଗଣନା ସମ୍ପାଦନ, ସୂଚନା ବିଶ୍ଳେଷଣ ଏବଂ ତାଲିକା ପରିଚାଳନା  କରନ୍ତୁ।
Comment[pa_IN]=ਕੈਲਸ ਦੀ ਵਰਤੋਂ ਕਰਕੇ ਸਪਰੈੱਡਸ਼ੀਟ ਨਾਲ ਗਣਨਾ, ਜਾਣਕਾਰੀ ਦੀ ਸਮੀਖਿਆ ਅਤੇ ਸੂਚੀਆਂ ਨੂੰ ਰੱਖਿਆ ਜਾ ਸਕਦਾ ਹੈ।
Comment[pl]=Przeprowadzaj obliczenia, analizuj informacje i zarządzaj listami w arkuszach kalkulacyjnych za pomocą programu Calc.
Comment[pt]=Efetue cálculos, analise informações e faça a gestão de listas em folhas de cálculo através do Calc.
Comment[pt_BR]=Efetue cálculos, analise informações e gerencie listas em planilhas utilizando o Calc.
Comment[ro]=Efectuați calcule, analizați informații și gestionați liste în foi de calcul folosind Calc.
Comment[ru]=Выполнение вычислений, анализ информации и управление списками в электронных таблицах с помощью Calc.
Comment[rw]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[si]=Calc භාවිතා කරමින් ගණනය කිරීම්, තොරතුරු විශ්ලේෂණය සහ පැතුරුම්පත් වල ලැයිස්තු පාලනය සිදු කරන්න.
Comment[sk]=Počítajte, analyzujte informácie a spravujte zoznamy v zošitoch s použitím Calc.
Comment[sl]=S programom Calc izvajajte računske operacije, analizirajte podatke in upravljajte sezname v preglednicah.
Comment[sr]=Изведите прорачуне, анализирајте податке и управљајте листама у таблицама уз Рачун.
Comment[sr_Latn]=Izvedite proračune, analizirajte podatke i upravljajte listama u tablicama uz Račun.
Comment[ss]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[st]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[sv]=Utför beräkningar, anaysera information och hantera listor i kalkylblad med hjälp av Calc.
Comment[szl]=Rachuj, analizuj informacyje i zarzōndzej listami we archach kalkulacyjnych przi użyciu Calca.
Comment[ta]=கணக்கிடவும், தகவலை ஆயவும், விரிதாள்களிலுள்ள பட்டியல்களை மேலாளவும் கால்கைப் பயன்படுத்து.
Comment[te]=Calc వినియోగించి స్ర్పెడ్షీట్లలో జాబితాలను నిర్వహించును,సమాచారమును విశ్లేషించును మరియు గణలను జరుపును.
Comment[tg]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[th]=ทำการคำนวณ วิเคราะห์ข้อมูล และจัดการรายการในตารางคำนวณโดยใช้ Calc
Comment[tn]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[tr]=Calc kullanarak hesap tablosunda performans hesaplamak, bilgi analiz etmek ve listeleri yönetmek.
Comment[ts]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[ug]=Calc ئىشلىتىپ ئۇچۇر ھېسابلاش ۋە ئانالىز ئېلىپ بېرىلىدۇ ھەمدە ئېلېكترونلۇق جەدۋەلدىكى تىزىملىك باشقۇرۇلىدۇ.
Comment[uk]=Виконання розрахунків, аналіз інформації та керування списками в електронних таблицях за допомогою Calc.
Comment[uz]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[ve]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[vi]=Dùng Calc tính toán, phân tích thông tin và quản lý danh sách trong bảng tính.
Comment[xh]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
Comment[zh_CN]=使用 Calc 进行计算,并在电子表格中进行数据分析。
Comment[zh_TW]=使用 Calc 可在試算表中執行計算、分析資訊與管理清單。
Comment[zu]=Perform calculations, analyze information and manage lists in spreadsheets by using Calc.
StartupNotify=true
X-GIO-NoFuse=true
Keywords=Accounting;Stats;OpenDocument Spreadsheet;Chart;Microsoft Excel;Microsoft Works;OpenOffice Calc;ods;xls;xlsx;
InitialPreference=5
StartupWMClass=libreoffice-calc
X-KDE-Protocols=file,http,ftp,webdav,webdavs
Actions=NewDocument;
[Desktop Action NewDocument]
Name=New Spreadsheet
Name[af]=Nuwe sigblad
Name[am]=አዲስ ሰንጠረዥ
Name[ar]=جدول مُمتد جديد
Name[as]=নতুন স্প্ৰেডশ্বিট
Name[ast]=Fueya de cálculu nueva
Name[be]=Новы разліковы аркуш
Name[bg]=Нова електронна таблица
Name[bn]=New Spreadsheet
Name[br]=Renkell nevez
Name[bs]=Novi tabelarni prikaz
Name[ca]=Full de càlcul nou
Name[ca_valencia]=Full de càlcul nou
Name[cs]=Nový sešit
Name[cy]=Taenlen Newydd
Name[da]=Nyt regneark
Name[de]=Neues Tabellendokument
Name[dz]=New Spreadsheet
Name[el]=Νέο υπολογιστικό φύλλο
Name[en]=New Spreadsheet
Name[en_GB]=New Spreadsheet
Name[en_ZA]=New Spreadsheet
Name[eo]=Nova kalkultabelo
Name[es]=Hoja de cálculo nueva
Name[et]=Uus arvutustabel
Name[eu]=Kalkulu-orri berria
Name[fa]=صفحه گسترده جدید
Name[fi]=Uusi laskentataulukko
Name[fr]=Nouveau classeur
Name[ga]=Scarbhileog Nua
Name[gd]=Cliath-dhuilleag ùr
Name[gl]=Nova folla de cálculo
Name[gu]=નવી સ્પ્રેડશીટ
Name[gug]=Kuatia Kálkulo Peguarã Pyahu
Name[he]=גיליון אלקטרוני חדש
Name[hi]=नया स्प्रेडशीट
Name[hr]=Nova proračunska tablica
Name[hu]=Új munkafüzet
Name[id]=Lembar Sebar Baru
Name[is]=Nýr töflureiknir
Name[it]=Nuovo foglio elettronico
Name[ja]=新規の表計算文書
Name[ka]=New Spreadsheet
Name[kk]=Жаңа электрондық кесте
Name[km]=សៀវភៅបញ្ជីថ្មី
Name[kmr_Latn]=New Spreadsheet
Name[kn]=ಹೊಸ ಸ್ಪ್ರೆಡ್ಶೀಟ್
Name[ko]=새 스프레드시트
Name[lt]=Naujas skaičiuoklės dokumentas
Name[lv]=Jauna izklājlapa
Name[mk]=New Spreadsheet
Name[ml]=പുതിയ സ്പ്രെഡ്ഷീറ്റ്
Name[mn]=Шинэ хүснэгт баримт
Name[mr]=नवीन स्प्रेडशीट
Name[nb]=Nytt regneark
Name[ne]=ओडीएफ स्प्रेडसीट
Name[nl]=Nieuw werkblad
Name[nn]=Nytt rekneark
Name[nr]=New Spreadsheet
Name[nso]=New Spreadsheet
Name[oc]=Classador novèl
Name[om]=Gabatee Herregaa haara
Name[or]=ନୂତନ ସ୍ପ୍ରେଡସିଟ
Name[pa_IN]=ਨਵੀ ਸਪ੍ਰੈਡਸੀਟ
Name[pl]=Nowy arkusz kalkulacyjny
Name[pt]=Nova folha de cálculo
Name[pt_BR]=Nova planilha
Name[ro]=Foaie de calcul nouă
Name[ru]=Создать эл.таблицу
Name[rw]=New Spreadsheet
Name[si]=ODF පැතුරුම් පත
Name[sk]=Nový tabuľkový dokument
Name[sl]=Nova preglednica
Name[sr]=Нова таблица
Name[sr_Latn]=Nova tablica
Name[ss]=New Spreadsheet
Name[st]=New Spreadsheet
Name[sv]=Nytt kalkylblad
Name[szl]=Nowo archa kalkulacyjno
Name[ta]=புதிய விரிதாள்
Name[te]=కొత్త స్ప్రెడ్ షీట్
Name[tg]=New Spreadsheet
Name[th]=สร้างตารางคำนวณใหม่
Name[tn]=New Spreadsheet
Name[tr]=Yeni Hesap Tablosu
Name[ts]=New Spreadsheet
Name[ug]=يېڭى ئېلېكترونلۇق جەدۋەل
Name[uk]=Електронна таблиця ODF
Name[uz]=New Spreadsheet
Name[ve]=New Spreadsheet
Name[vi]=Bảng tính mới
Name[xh]=New Spreadsheet
Name[zh_CN]=新建电子表格
Name[zh_TW]=新增試算表
Name[zu]=New Spreadsheet
Icon=document-new
#3 2022-05-07 12:26:03
erdos
i tried with command line prompt and received an error:
erdos@htpc-devuan:~/Documents$ /usr/bin/soffice --version
terminate called after throwing an instance of 'com::sun::star::uno::DeploymentException'
You have new mail in /var/mail/erdos
erdos@htpc-devuan:~/Documents$ lsb_release -a
Release:	4
Codename:	chimaera
erdos@htpc-devuan:~/Documents$ uname -a
Linux htpc-devuan 5.10.0-9-amd64 #1 SMP Debian 5.10.70-1 (2021-09-30) x86_64 GNU/Linux
erdos@htpc-devuan:~/Documents$ locate .desktop | fgrep office
bash: locate: command not found
i updated to chimera from 3.0, maybe libreoffice didn't get updated propperly during the process?  but checking 'synaptics' indicating libreoffice base/core are up-to-date
#4 2022-05-07 17:35:21
alexkemp
You need to install mlocate to be able to use the (command-line) locate command. I would strongly advocate for it.
Well, that was easy.
This page points to the lack of (or faulty) GTK2 causing that error, whilst the latest post points out that nowadays GTK3 is required. That neatly suggests that this is the issue:
Check whether libreoffice-gtk3 is installed and, if not, I suspect that you have found the issue.
PS
I suspect that a simple fix may be to add backports to your repository list, which gives the latest LO and should fully update it at the same time. Here is my current setup:
$ cat /etc/apt/sources.list
deb http://deb.devuan.org/merged chimaera-security main non-free contrib
deb http://deb.devuan.org/devuan chimaera-proposed-updates main non-free contrib
deb http://deb.devuan.org/merged chimaera-backports main non-free contrib
#5 2022-05-08 14:27:12
charliebrownau
Gday
LibreOffice Appimage works with Dev1
https://www.libreoffice.org/download/appimage/
Also if you need a word processor and spreadsheet
You could always install Abiword and Gnumeric
or just type something up in text editor or mark down editor
I really like appimage
I have a folder for them all
I myself control when it updates or not
I can revert back to a older build if needed most of the time (LibreWolf changes the profile so you cant revert)
Anyone else using GhostWriter for Markdown editing ?
https://wereturtle.github.io/ghostwriter/download.html
Its also got a Appimage
#6 2022-05-13 01:54:18
erdos
thank you!
I've removed Libreoffice files from my Chimera since it's broken.
Tried Appimage of Libreoffice and it works out great!
