My NAS running OpenWRT uses rsync version 3.2.3 protocol version 31 and my Devuan running with a backported kernel uses rsync version 3.1.3 protocol version 31.
beowulf-backports has rsync version 3.2.3-3~bpo10+1, which would be a match.
This is what I get when I try to install it:
:~$ sudo apt install rsync/beowulf-backports
Building dependency tree
Selected version '3.2.3-3~bpo10+1' (Devuan Backports:3.0.0/oldstable-backports [amd64]) for 'rsync'
Selected version '1.4.4+dfsg-3~bpo10+1' (Devuan Backports:3.0.0/oldstable-backports [amd64]) for 'libzstd1' because of 'rsync'
rsync : Depends: libzstd1 (>= 1.4.4+dfsg-3~bpo10+1) but 1.3.8+dfsg-3+deb10u2 is to be installed
:~$ So ...
Does this mean that I cannot install it because beowulf-backports has libzstd1 1.3.8+dfsg-3+deb10u2 and not 1.4.4+dfsg-3~bpo10+1?
Or am I missing something?
Just to check, I thought maybe it was a question of installing libzstd1 1.4.4+dfsg-3~bpo10+1 as libzstd1 1.3.8+dfsg-3+deb10u2 was already installed.
ie: for some reason not being updated and be specifically installed from beowulf-backports.
But when I tried I got this huge list of files that are no longer required/removed:
:~$ sudo apt install libzstd1/beowulf-backports
gstreamer1.0-plugins-base:i386 libaom0:i386 libavresample4:i386 libavutil56:i386
libblkid1:i386 libcairo2:i386 libcapi20-3:i386 libcdparanoia0:i386 libcodec2-0.8.1:i386
libcroco3:i386 libcrystalhd3:i386 libdatrie1:i386 libexif12:i386 libfontconfig1:i386
libfreetype6:i386 libfribidi0:i386 libgcrypt20:i386 libglib2.0-0:i386 libgomp1:i386
libgpg-error0:i386 libgphoto2-port12:i386 libgpm2:i386 libgraphite2-3:i386 libgsm1:i386
libgstreamer-plugins-base1.0-0:i386 libgstreamer1.0-0:i386 libharfbuzz0b:i386
libicu63:i386 libjack-jackd2-0:i386 libmount1:i386 libmp3lame0:i386 libncurses6:i386
libnuma1:i386 libopenjp2-7:i386 libopus0:i386 liborc-0.4-0:i386 libpango-1.0-0:i386
libpangocairo-1.0-0:i386 libpangoft2-1.0-0:i386 libpixman-1-0:i386 libpng16-16:i386
libsamplerate0:i386 libsdl2-2.0-0:i386 libshine3:i386 libsnappy1v5:i386 libsoxr0:i386
libspeex1:i386 libswresample3:i386 libthai0:i386 libtheora0:i386 libtwolame0:i386
libusb-1.0-0:i386 libv4l-0:i386 libv4lconvert0:i386 libva-drm2:i386 libva-x11-2:i386
libvdpau-va-gl1:i386 libvdpau1:i386 libvisual-0.4-0:i386 libvkd3d1:i386 libvpx5:i386
libvulkan1:i386 libwavpack1:i386 libwayland-client0:i386 libwayland-cursor0:i386
libwayland-egl1:i386 libwebp6:i386 libwebpmux3:i386 libx264-155:i386 libx265-165:i386
libxcb-render0:i386 libxcb-shm0:i386 libxcomposite1:i386 libxcursor1:i386 libxinerama1:i386
libxkbcommon0:i386 libxml2:i386l ibxpm4:i386 libxrandr2:i386 libxrender1:i386
libxslt1.1:i386 libxss1:i386 libxvidcore4:i386 libzvbi0:i386 mesa-vdpau-drivers:i386
ocl-icd-libopencl1:i386 vdpau-driver-all:i386
libasound2-plugins:i386
libavcodec58:i386
libgd3:i386
libgdk-pixbuf2.0-0:i386
libgphoto2-6:i386
librsvg2-2:i386
librsvg2-common:i386
libtiff5:i386
libwine:i386
libzstd1:i386
wine32:i386
libzstd1
1 upgraded, 0 newly installed, 11 to remove and 0 not upgraded.
Need to get 249 kB of archives.
After this operation, 241 MB disk space will be freed.
Do you want to continue? [Y/n] n
Abort.
:~$ The first thing I notice is that they are all :i386 but I'm not sure of the consequences.
What were they for in the first place?
I'd appreciate an opinion.
Perhaps you'll need to upgrade the i386 version at the same time, by adding libzstd1:i386/beowulf-backports to the install line?
Use apt install --target beowulf-backports rsync libzstd. The /beowulf-backports incantation doesn't allow for dependencies to be installed from backports.
I think aptitude might be able to figure out the path to installation with the /release syntax where dependencies are involved.
That would seem to do the trick:
groucho@devuan:~$ sudo apt install rsync/beowulf-backports libzstd1/beowulf-backports libzstd1:i386/beowulf-backports
Selected version '1.4.4+dfsg-3~bpo10+1' (Devuan Backports:3.0.0/oldstable-backports [i386]) for 'libzstd1:i386'
libxxhash0
Suggested packages:
openssh-server
libxxhash0
libzstd1 libzstd1:i386 rsync # <- what was needed
3 upgraded, 1 newly installed, 0 to remove and 0 not upgraded. # <- nothing removed
Need to get 840 kB of archives.
After this operation, 41.0 kB of additional disk space will be used.
Abort.
groucho@devuan:~$ I'll try that and report later.
Edit:
Minutes later ...
:~$ rsync -V
Copyright (C) 1996-2020 by Andrew Tridgell, Wayne Davison, and others.
Web site: https://rsync.samba.org/
Capabilities:
64-bit files, 64-bit inums, 64-bit timestamps, 64-bit long ints,
socketpairs, hardlinks, hardlink-specials, symlinks, IPv6, atimes,
batchfiles, inplace, append, ACLs, xattrs, optional protect-args, iconv,
symtimes, prealloc, stop-at, no crtimes
Optimizations:
SIMD, asm, openssl-crypto
Checksum list:
xxh64 (xxhash) md5 md4 none
Compress list:
zstd lz4 zlibx zlib none
:~$ Now the Devuan and OpenWRT versions of rsync match.
Thanks for your input.
No, seems it would not work.
groucho@devuan:~$ sudo apt install --target beowulf-backports rsync libzstd
E: Command line option --target is not understood in combination with the other options
groucho@devuan:~$ I use aptitude very little, usually with the why option.
Isn't this a question of mixing amd64 & i386? Or am I missing something?
... question of mixing amd64 & i386?
Really cannot say for sure.
What I can say is that ~$ apt list | grep installed | grep i386 shows me a list of 203 files.
ie: if I managed to count correctly at this hour.
Save these 10, all the rest are lib***:
~$ apt list | grep installed | grep i386 | more
elogind/oldstable,now 241.4-2 i386 [installed,automatic]
gcc-6-base/now 6.3.0-18+deb9u1 i386 [installed,local]
gcc-8-base/oldstable,now 8.3.0-6 i386 [installed,automatic]
gstreamer1.0-plugins-base/oldstable,oldstable-security,now 1.14.4-2+deb10u1 i386 [installed,automatic]
mesa-va-drivers/oldstable,now 18.3.6-2+deb10u1 i386 [installed]
mesa-vdpau-drivers/oldstable,now 18.3.6-2+deb10u1 i386 [installed,automatic]
ocl-icd-libopencl1/oldstable,now 2.2.12-2 i386 [installed,automatic]
vdpau-driver-all/oldstable,now 1.1.1-10 i386 [installed,automatic]
wine32/oldstable,now 4.0-2 i386 [installed,automatic]
zlib1g/oldstable-security,now 1:1.2.11.dfsg-1+deb10u1 i386 [installed,automatic]
~$Of the whole of them, 183 were installed,automatic while only 2 were installed,local.
~$ apt list | grep installed | grep i386 | grep local | more
libicu57/now 57.1-6+deb9u4 i386 [installed,local]
~$ This leaves 17 that are just [installed].
ie: not [automatic] or [local].
There's probably a way to see what pulled these i386 file in.
One application that comes to mind is wine.
Hope it clears up something.
Sorry, that should have been
# apt install --target-release beowulf-backports rsync libzstdBrianna Ghey — Rest In Power
Sorry, that should have been ...
No worries whatsoever, HoaS. ;^ )
Thanks (again) for your input.
